Can I calibrate Optical Comparators internally?
  • Thread starter Bob Gallinger - 2007
  • Start date
#11
Re: Optical Comparators - Can I calibrate Optical Comparators internally?
jane_ackerman said:
Sorry if I am beating a dead horse here... but what would you use to certify your angle (and radius) gages besides an optical comparator?
Two thoughts:
1) Calibration masters, reasonably cared for, won't significantly change. There is generally no need for calibration of masters beyond an initial certification.
2) If, for some reason, someone does want to calibrate masters, it's cheaper than having an outside service calibrate the comparator.
Hershal
Metrologist-Auditor
#12
Jim Wynne said:
Two thoughts:
Actually, though the masters may or may not change a lot, they do change. That is why they require calibration. Often - depending on how the item is cared for - the cycle can be extended to perhaps 3 years.....but the master still needs calibration, otherwise how much change there has been, and how much error the master device has will not be known. The error of course is meaurement uncertainty.
Using a master as a check internally I certainly support.....but proper calibration is not cheap.....I support having trained and qualified metrology professionals taking care of this technical function, just as a machinist takes care of CNC machines, or a black belt heads up the six sigma functions.
Hope this helps.
Hershal
Hershal
Metrologist-Auditor
#13
Oh, one other point.....it may well be cheaper to have an outside service cal the comparator.....
Why? Here is what must be considered.....
Price to acquire the master device to calibrate the comparator.
Price to have the master device calibrated properly.
Time required for the company person to obtain or write a procedure.
Time required to train the person in the procedure.
Cost to assure control of the procedure in the QMS.
Time for company person to actually calibrate the comparator.
If the calibration is also to be traceable, time and effort to calculate measurement uncertainty, plus any costs involved for MU training.
Time is calculated at whatever the overhead rate is for the personnel involved.
Hope this helps.
Hershal
roland_lu
#14
Hershal
How do we know the master will not change significantly during these 3 years? The argument will never end.
For small companies, the cost for calibration is really unbearable. I used to work for a small tier-2 auto supplier, we changed the master blocks and CMM external calibration interval to 4 years, backed-up by the facts that they are well cared for and used not very often (how to define often?). The auditor did not challenge us, I guessed he understood the business is tough.
G
Grizz1345
#15
The best way I know of to check angle blocks is to use a sine plate (calibrated), gage blocks and height gage with indicator. Radius gages you can use pins. I had my radius gages checked by an outside lab and now just do a visual for damage (nicks and burrs). Hope this all helps.:)
#16
The question is how "change" is defined. Of course it depends on the nature of the standard (master) itself, but it's not unusual to see blocks, radius and angle masters remain unchanged for practical purposes for many years.
Hershal
I agree :agree1:
#17
I mean certified by a 17025 accredited lab, with NIST tracablity.
I believe I would need a couple of good class (tolerances) of angle blocks. Once I have the certified externally then I should be able to use them for my internal calibration of opticals, along with my certified gauge blocks. What else do I need ????? and what class (tolerance) of angle blocks should I purchase ????
Hershal
Metrologist-Auditor
#18
One question.....why NIST traceability? Since you are in Canada, why not traceability through NRC?
Just curious.....
Hershal
#19
Good question, NRC is the canadian equivalent to NIST correct ?????
Pretty much all the external Labs up here that we use report NIST tracable equipment/standards used when certifing. This question has never been brought up during our annual audit.
Hershal
Metrologist-Auditor
#20
NRC is in fact the Canadian NIST, both are signatory to BIPM, and either is equally acceptable in North America for traceability.
Hershal
S How to calibrate AOI (Automated Optical Inspection) for IOPQ Qualification and Validation (including 21 CFR Part 11) 3
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
I Can I Calibrate On Demand? General Measurement Device and Calibration Topics 9
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
F Crimper Calibration - How do you Control & Calibrate your crimpers? Calibration Frequency (Interval) 13
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
B Choosing not to calibrate (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 6
K New Kilogram - The process we use to calibrate the standards General Measurement Device and Calibration Topics 6
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
L Re-calibrate after software update? Calibration Frequency (Interval) 3
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
N Calibrate temperature on refrigerated Centrifuges? General Measurement Device and Calibration Topics 2
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
D Lesser expensive to calibrate various test weights General Measurement Device and Calibration Topics 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
P How do you calibrate a VNA (Vector Network Analyzer) cal kit? General Measurement Device and Calibration Topics 4
V How to Calibrate Ring Force Gauges Service Industry Specific Topics 1
bobdoering Who says you can't calibrate a steel rule! Funny Stuff - Jokes and Humour 14
S How can I Calibrate a Biosafety Cabinet? General Measurement Device and Calibration Topics 1
C How to Calibrate a Viscosity Tester General Measurement Device and Calibration Topics 3
0 Is it possible to use a threaded ring gage to calibrate the M8 gage? Calibration and Metrology Software and Hardware 4
C How to Calibrate a Medical Infrared Thermometer General Measurement Device and Calibration Topics 3
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
B Calibrate Hole Presence Detection Device? General Measurement Device and Calibration Topics 5
J What do you use to Calibrate 40" Calipers General Measurement Device and Calibration Topics 10
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
C Tolerance Estimation of a Load Cell I want to Calibrate General Measurement Device and Calibration Topics 9
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
B ISO/TS 16949 Section 7.6.3 - Use of Manufacturer to Calibrate IATF 16949 - Automotive Quality Systems Standard 21
W How to verify/calibrate a Neptune Water Meter General Measurement Device and Calibration Topics 4
N Laboratory that is able to Calibrate Dew Point Meter up to 60?Cdp - Needed General Measurement Device and Calibration Topics 1
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
C How to calibrate or control patterns for fiberglass General Measurement Device and Calibration Topics 4
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
I Need help finding an Accredited Lab that can Calibrate Brunson 76-RH Survey Transits General Measurement Device and Calibration Topics 5
M Controlling Temperature and Time - Do I need to calibrate the thermostat? IATF 16949 - Automotive Quality Systems Standard 4
D How much Tolerance do I use to Calibrate a 150kgs capacity Scale? General Measurement Device and Calibration Topics 5
M To Calibrate or Not to Calibrate various Weight Scales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
N Thermocouple Inhomogeneity - Need to calibrate a roll of 50m thermocouple type K General Measurement Device and Calibration Topics 3
J Calibrate before use required? Inspection Gages and Measurement Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Traceability for Mercury Argon Calibration Source to Calibrate a Spectrometer? General Measurement Device and Calibration Topics 5
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
S 3 Point Calibration or Calibrate to Extreme High and Low? General Measurement Device and Calibration Topics 9
C Seeking a holder/jig to calibrate large OD micrometer calipers (up to 23") General Measurement Device and Calibration Topics 8
S Is it OK to calibrate a measurement device tighter than manufacturer specifications? General Measurement Device and Calibration Topics 18
B Difference between Calibration & Verification and How to calibrate Go/No Go gauge? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
