Can I use Cpk to compare if one part is usable in another part?
QCJS
U can't change a person but u can change yourself
I have raw data of 10 pieces of Metal rollers (Inner diameter specification: Ø10.7 -0.005) and 10pcs Bearings(Outer Diameter specification: Ø10.7 -0.007). The Bearings are meant to be tightly fitted into the Metal Rollers. Can I find Cpk values for the Metal rollers and Bearings, compare the values and conclude that they can be used in production? Is that even the right way?
My purpose is to convince the Engineer that they can be use in production. To convince Customer, can these calculations be used too?
Appreciate all sorts of help, no matter how small it might be.
Thanks,
QCJS
No. First a sample size of 10 is way too small. Requirements for the usefulness of any statistic are that the sample size is adequately large and that the sample selection is representative of the underlying distribution.
To provide useful advice we would need to understand more about the situation.
QCJS
Hi Bev D,
1. Can you explain in simple words on this statement: "sample selection is representative of the underlying distribution. "? Do you mean to say that the the specification selected is dependent on the sample size?
2. So if I increase the sample size to 30 or 50, would Cpk values tell that Roller and Bearing are compatible for use? Can you suggest a way to convince the Engineer, using data, that the bearings can be used in the rollers even when the 2 of the readings are out?
For now, I simply took the averages of each data and compare. Since I want a tight fit, if average Roller reading is equivalent or is more than 1 micron than the Bearing average, then I conclude that it can be used. But something struck me, how did I determine a tight fit? Is it through the ISO tolerance chart? How will I explain that even if it is more than 3 microns but less then 5 microns, I will Use As Is?
3. Customer complains that rollers produces a scratchy sound when rotating. Production supervisor is adamant that it's due to the dimension of the Roller and Bearing. But the QC inspector is unable to take the reading again as the Bearing is press-fit into the Roller. The ID reading of the Roller will not be accurate if we force out the Bearing to investigate the cause. Customer demands an answer from us ASAP or we will need to change the hundreds of rollers at their site. This is one of the scenario faced currently. Can you suggest a way out?
Whoa. are you saying that 2 of the parts (out of 10) are out of spec?
are the bearings a catalog part? and 2 of them are out of your internal spec for fitting into the roller (3microns) or the bearing supplier spc of 5 microns?
Welshwizard
Hello QCJS,
It sounds like you are trying to manage limits and fits for an interference condition of assembly. Going by what you are saying the issue surrounds the sounds coming from the bearing in service, this leads me to think of failed or faulty bearings, which, may or may not have anything to do with the condition of the pre assembled bearing.
To eliminate the dimensional condition of housing and bearing could you carry out a dimensional check of the bore of the bearing after installation and follow it up with a simple functional check e.g. assuming a ball race bearing, spin and check for lack of smoothness?
If the bearing is being crushed its a limits and fits issue, otherwise there's a failure of the bearing in service.
If its limits and fits could you demonstrate the measured values of bore and bearing pre assembly to your customer?
As for the bearings in service, isn't it just a functional check for customer protection?
Lastly, reading you post again it would seem that your fit conditions are set at extremely tight tolerances which don't follow the norm on any transition or interference fits specified by ISO.
For example, looking at a H7 s6 Interference Fit (typical for pressed bearings), the tolerances would be:
Hole - 10.7 to 10.718 mm
Bearing - 10.735 to 10.748 mm
Notice the ranges in the sizes to achieve the condition you may want i.e. 18 micron for Hole and 13 micron for the Bearing. Comparing this against your stated sizes of Hole 10.7 to 10.695 and Bearing 10.7 to 10.693 mm you can see that you could have for example more tolerance to achieve the same fit, in this case for Hole an additional 0.013 mm and for Bearing an additional of 0.006 mm.
Perhaps its worth evaluating the functionality required from the limits and fits?
Hope this helps.
Matt's Quality Handle
This is what you need to be looking at. Interference is what keeps the roller/bearing interface from slipping. It appears from your post that the max interference per your specs is 0.005mm. In the example that Welshwizard quoted, there is 0.048 max interference.
D How to compare Cpk and ppm (bad pieces) Capability, Accuracy and Stability - Processes, Machines, etc. 3
D Ford CSR Cpk/Ppk Requirements Statistical Analysis Tools, Techniques and SPC 8
PQ Systems Cpk: Indispensible Index or Misleading Measure Using SQCpack Software 0
R Cpk demands from automotive customer Capability, Accuracy and Stability - Processes, Machines, etc. 8
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
