Can I use the word 'Template' instead of 'Record'?
E
erwinpeter
I have written a complete set of Manuals and Procedures for the organization and within it I have identified various formats of forms and registers. These formats I have termed as 'Template' in the documents. The numbering system follows the following: <Department>-"TM"(for Template)-<Incrementing Number> (<Version> <Effective Date>)
For example:
MSY-TM-08 - Master List of Records (v1.0 02-Jul-07)
MSY-TM-09 - Complaints Register (v1.0 02-Jul-07)
MSY-TM-10 - Complaints Report (v1.0 02-Jul-07)
MSY-TM-11 - Annual Internal Audit Plan (v1.0 02-Jul-07)
MSY-TM-12 - Internal Audit Schedule (v1.0 02-Jul-07)
In our 'Records Control Process' we have mentioned "All Records generated in <Organization> must use the latest Format/Template published. The Master List of Records is regularly updated (if there are any changes), with details of latest Templates available to generate Records. The identification of a record is based on the format prescribed and the date mentioned on the record or record number (if any)."
Question: I am not sure whether I can use the word 'Template' instead of 'Record' as the standrads does not mention 'Template' enywhere for meaning 'Records'. Appreciate your help.
Thanks,
Erwin Peter
Erwin:
What you've described seems to be a very well thought out system of documentation.
The records that are referred to in the standard (like ISO 9001:2000 etc.) normally mean the actual data recorded on a form (using your template). I therefore see no issue with what you've got, as long as it's clearly defined that the record is the data.
There should be no issue. A Record is a document (hardcopy or electronic) that contains data/information regardless of its name.
R AS9016 - Notice of Change template in either Word or Excel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B AS9110 Audit Check Sheet wanted Excel or Word Document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Usable version of MDR in Word format CE Marking (Conformité Européene) / CB Scheme 0
Y Excel Automation - Printing Word Documents from within Excel Excel .xls Spreadsheet Templates and Tools 0
qualprod NC if word "development" stated in Policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Definition Integrity - The meaning of the word INTEGRITY in ISO 13485 Control of Records Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
J How to understand the word "include" in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
Q Including the Word "Risk" into the Quality Policy (ISO 9001:2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Parts Lists - Use of the word "off" against Quantity Coffee Break and Water Cooler Discussions 2
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Microsoft Word - How to make high-light go away after text is put in Excel .xls Spreadsheet Templates and Tools 5
J Keyboard issue in Word - Making me nuts Coffee Break and Water Cooler Discussions 5
S FDA Forms 482, 483 and 484 - MS Word documents US Food and Drug Administration (FDA) 6
D Scope of ISO 13485 Certification needs the word Production. ISO 13485:2016 - Medical Device Quality Management Systems 9
somashekar Word for the Weekend ~~~ Coffee Break and Water Cooler Discussions 2
S Critical Characteristics of a Word Processor and Excel Software Quality Assurance 2
T "Typing name on MS.Word directly" can be "Electronic Approval Signature" Document Control Systems, Procedures, Forms and Templates 3
M The definition of the word Invalid as in "Password Invalid" Coffee Break and Water Cooler Discussions 7
Manix Exporting Data from MS Access to MS Word or MS Excel Templates Quality Assurance and Compliance Software Tools and Solutions 5
K Definition Audit - Time for a new definition of the word Audit? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
K Verification, Validation or Checking? Definition of the word "Checked" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Disabling Copy Paste option in MS Word After Work and Weekend Discussion Topics 30
M Can the same form number be in Word and Excel for ISIR's and such? Document Control Systems, Procedures, Forms and Templates 9
M Converting PowerPoint Presentations into MS Word Documents After Work and Weekend Discussion Topics 6
V Use of the word 'identification number' instead of 'identification code' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
michellemmm Pagination in Microsoft Word Documents Document Control Systems, Procedures, Forms and Templates 21
H AS9101D Microsoft Word Format: Worth It? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Document Format vs Content Revision - Form changed from MS Word to MS Excel Document Control Systems, Procedures, Forms and Templates 7
S Post Market Surveillance SOP - Word Version EU Medical Device Regulations 42
E Signature of Records - Microsoft Word forms Records and Data - Quality, Legal and Other Evidence 7
U New Part 21.137 Quality Manual format example in Word format Federal Aviation Administration (FAA) Standards and Requirements 5
J What's the meaning of word "map" (Map these requirements with your implemented QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
G Is there an AS9100C to AS9100B word for word comparison chart yet? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Requirements for Changing Documentation to correct typos or wrong word selection Document Control Systems, Procedures, Forms and Templates 15
SteelMaiden Today's word: Frisbeetarianism Coffee Break and Water Cooler Discussions 9
B Question about the word "Design" in AS9100 Clause 8.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N What is the Latin word for 'Layered'? Coffee Break and Water Cooler Discussions 12
V Updating Quality Manual - Adding the word Statutory in front of laws and regulations Quality Management System (QMS) Manuals 3
D Microsoft Word problems Document Control Systems, Procedures, Forms and Templates 11
P Revision History in an MS Word document Document Control Systems, Procedures, Forms and Templates 37
J Where to Purchase an MS Word version of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
A How to do Process Flow Charting in MS Word Process Maps, Process Mapping and Turtle Diagrams 15
I Essential Requirements for Medical Devices - Word copy wanted EU Medical Device Regulations 4
T DPMO (defects per million opportunities) - Key word being OPPORTUNITIES Six Sigma 9
T Accountability… A good word or a bad word... Imported Legacy Blogs 2
J eWOM (Electronic Word of Mouth), what is that? Coffee Break and Water Cooler Discussions 0
SteelMaiden Help with MS Office Word 2007? After Work and Weekend Discussion Topics 10
