Can identical gages in different facilities be in the same family?
V
vfliberty
I was given a minor in our recert audit because I used a study done by another plant on identical attribute gages. I've read forums and meet the criteria for a family - identical gages, manufactured at the same time, calibrated properly, same product and process... There just happens to be 500 miles between us and different operators.
The auditor insists that the R&R MUST be unique to our facility and people. FORD MSA or TS are not too specific on this. I've already started the R&R's because that's what we do, but...
What do you guys think?
tomvehoski
I would tend to agree, unless your employees are traveling back and forth to use the gages. Training in the gage use at facility A could be different than facility B, causing differences in operator variation. Facility A might be temperature controlled while facility B is not, causing variations in the equipment.
Wes Bucey
For what it's worth, I never found two gages to be "identical," regardless if they are next to each other on a bench in a temperature controlled lab or 5,000 miles apart. I've found them to be "very similar" (certainly within most tolerances), but, ultimately, depending on the discrimination and reliability and repeatability of the various instruments and standards used to check them, variation between gages CAN be detected. Obviously, this variation is even more likely to be found between human operators. When you encounter variation, how do you really know what is attributable to the gage and what to the operator when the gages are 500 miles apart?
Welcome to the Cove. Can you provide the text of the nonconformity statement, including reference(s) to the standard? You say it's an attribute gage; what kind of parts, and what sort of characteristics are being verified?
V
vfliberty
[FONT=T3Font_12][FONT=T3Font_12]
Thanks for responding guys. I agree that no 2 gages are ever the same and I don't normally use family gage studies. In this case the FORD MSA requires use of parts in and out of tolerance and it is impossible for me to create enough variation in the process to do this.
The finding:
The process for ensuring that GR&R studies are done is not effective in practice.
Section 7.6.1 of TS 16949 requires the organization to conduct studies to analyze the variation present in the results of each type of measuring and test equipment.
Evidence of GR&R studies being conducted for attribute gauges referenced on the control plan could not be found during the assessment.
It is an attribute gauge - stab pin checks location of a hole, and a feeler checks gap along a contour, tolerances are +/-2mm. The parts are welded assemblies.​
[/FONT]
[/FONT]
The finding:
[/FONT]
[/FONT]
For a start - the nc doesn't give any evidence that the GR&R process is not 'effective', so, on that basis alone, I'd reject it on the auditor! Since this is using a 'golden' standard for acceptance, it seems to me that you'd have to show, firstly, that they are 'identical', for the GR&R to be valid. I see no problem with conducting the GR&R on one gauge and then shipping the other (as when they were new) to another location. As Wes says, the 500 miles or 50 feet doesn't mean anything.
Are you having problems with the customer/parts acceptance/performance? Would 1 location see a difference that the other doesn't? Only then should the auditor truly have an issue...
Ron Rompen
This is probably the most interesting question I've seen here in a long time. :applause:
My initial response (as Lead Auditor) is no, you can't use the 'family' clause for separate facilities....but then I stopped to think about it.
We have two plants here, about half a mile apart. They run different products and processes, but both are the same in essence (assembly of outsourced fabricated products). We have used the 'family' clause for such gauges as micrometers, digital calipers and height gauges, and the issue has never (to the best of my knowledge) been raised. So where do you draw the line?
I'm now unsure as to how I would write this as a finding; definitely it could be an OFI, but would it be a nonconformance or not? It will be interesting to see what some of our other members have to say.
V
vfliberty
In response to your question AndyN - perfect Q1 score and 0 PPM since Job 1. The product and process is the same in both facilities. GR&R was done on these attributes when they were new, then shipped here.
To Ron - our products are the same, not just in essence. We ship to different customer plants normally, but are PPAP'd to both locations.
I might add that these gages also take 30 variable points. GR&R's were done initially and annually on each feature, no family gage there. It's not like there's evidence we don't understand the requirement.
Then, clearly, the process is effective, isn't it? Hence, I'd push it back to the auditor to - at the very least - reword the nc. It's just bizarre that the distance between one gauge and another would make it an issue! What would he have you do, another GR&R or move the factory...DOH!
V
vfliberty
Another GR&R is what the auditor wants. The feature is on the control plan even though it's not an SC - if it's on the control plan you have to have an R&R - that's a given. My alternate approach is to take it off the control plan.
What bothers me most about this is the cost of this R&R.
50 parts measured on CMM - $937.50
3 operators measuring 50x3 parts - $1125
QE project time - $320
TS Auditor satisfaction - PRICELESS!
M Validation of two nearly identical products Other Medical Device Regulations World-Wide 5
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
M Identical Sales Package in Different Countries Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
G How to Fix Mis-Identified Dimensionally Identical Parts Nonconformance and Corrective Action 5
A Two Identical Medical Devices put in different Classes - Class I and Class II 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Back to Back MSA - Two "identical" automatic measuring systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Are IEC 60601-1:2012 and BS EN 60601-1:2006+A11:2011 still identical? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Auditor found Form with Identical Contents but different Format - is this an NC? Document Control Systems, Procedures, Forms and Templates 28
D Recall, Safety Notice or Training? - Medical Device with two identical complaints 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
Q Repeating Identical Processes in different Procedures? Document Control Systems, Procedures, Forms and Templates 8
C Equivalence Studies - Validation Activities for several Identical Pieces of Equipment Manufacturing and Related Processes 1
C Equivalence Studies - Validation Activities for several Identical Pieces of Equipment Qualification and Validation (including 21 CFR Part 11) 2
Icy Mountain TS 16949 Requirement for New MSA for Identical Replacement Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D How to audit identical processes? TS 16949 Clause 8.2.2 General Auditing Discussions 2
N Hypothsis test - Problem with an in-process test machine - Almost identical product Statistical Analysis Tools, Techniques and SPC 7
D Gage R&R on one tape measure to represent all identical tapes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P How many SPC charts for Bolt Torque? 4 identical Nut/Bolts in the same part Statistical Analysis Tools, Techniques and SPC 14
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
PastorBee13 Source for the blades for Reef Snap Gages General Measurement Device and Calibration Topics 2
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
A Adjusting Calibration Intervals for Welding related Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Calibration Recall - Lost Gages procedure example wanted General Measurement Device and Calibration Topics 4
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
M Control Plan MSA's - Pressure Gages IATF 16949 - Automotive Quality Systems Standard 2
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F Checking Gages In and Out and Verifying Calibration Status Calibration and Metrology Software and Hardware 8
D Calibration requirements for New Gages General Measurement Device and Calibration Topics 11
Q Number of Calibration Verification Points - Calipers, height gages, etc General Measurement Device and Calibration Topics 6
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
J Verification of Gages Before Use Calibration Frequency (Interval) 10
L Inexpensive Gage Management Software recommendations for less than 75 Gages Calibration and Metrology Software and Hardware 8
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
V How to measure radius without radius gages APQP and PPAP 4
N When and which gages require a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
BHobbs_Busche ISO/TS16949:2009 - MSA requirements for common gages IATF 16949 - Automotive Quality Systems Standard 5
D Calibration and Tolerance Ranges of Pressure Gages General Measurement Device and Calibration Topics 8
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
