Can Inspection Frequency be based on Cp or Cpk?
csterling
#11
What would you recommend for attribute data? In my case the Inspector not only sample for SPC but also for attributes. Does the 3 to 5 samples apply?
Does the lot or bath size being produced matters?
What would be a good justification for using 3 to 5 samples (in-process inspection) for variable and attribute data idependently of the frequency and lot size?
Thanks in advanced.
bobdoering
Stop X-bar/R Madness!!
#12
I am in the metalworking industry (Milling, Turning, Drilling, Grinding) and i decided to do this, based on common sense:
CPK < 1.33 => Use 100% In-process inspection AND reduce process variability (CPK and PPK) !
CPK > 1.33 AND PPK < 1.33 => Increase In-process inspection frequency (Decreasing time from subgroup to subgroup) in orden to early detect subgroup process variation (PPK) (shifts, drifts or trends) and make adjustments (in order to increase PPK) and have a better long term process performance. Continue reducing short term process variation in order to have a better CPK.
CPK >> 1.33 AND PPK >> 1.33 => I am allowed to decrease In-process inspection frequency (increasing time from subgroup to subgroup).
Optimal In-process sampling frequency if i have:
CPK >> 1.33 AND PPK >= 1.33
In this case if i increase in-process inspection frequency (decreasing time from subgroup to subgroup) i am only increasing costs, not quality.
First, it is important to not that if you are calculating Cpk in precision machining for lengths and diameters, you are most likely not properly controlling your process. Second, attempting to calculate Cpk based on a sample from a properly controlled metalworking process is nearly impossible due to severe effects of sampling error. One needs to control the process correctly, and use the rule of thumb 5 to 7 checks per adjustment driven by the charting methodology, and the problem is solved - for precision machining.
One important clue: If you are precision machining, and you have a normal distribution, your controls are wrong and you are overadjusting.
For information on the correct way to control precision machining see:
Statistical process control for precision machining
M Decrease frequency of inspection based on results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Y FDA's Inspection Frequency for Foreign Manufacturer Other US Medical Device Regulations 1
S How to incorporate a customers special inspection frequency in our control plan FMEA and Control Plans 1
C How to Reduce Inspection Frequency in Metal Stamping Company Quality Manager and Management Related Issues 4
P Reduction in the Inspection Frequency - Is approval required? IATF 16949 - Automotive Quality Systems Standard 1
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Customer Inspection Frequency and Rejection Level Criteria - Sample Lot Size AQL - Acceptable Quality Level 6
W Frequency fo CMM Inspection - Sub Contract Machining of Forgings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B TS 16949 PPAP/ Layout Inspection Frequency Requirements APQP and PPAP 8
T How do I Reduce Frequency of Receiving Inspection Testing for Quality Control Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J Reduction of Pull Off Test Inspection Frequency - Capability Query Quality Tools, Improvement and Analysis 1
L Criteria for Establishing Control Plan Sample Size and Inspection Frequency FMEA and Control Plans 7
D In Process Inspection Frequency and Documentation - CNC lathe/mill work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A Visual Inspection Frequency and is there any standard that for visual attributes? AQL - Acceptable Quality Level 2
T ISO 2859-3 - Skip-lot sampling procedures - Unauthorized Inspection Frequency Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Stuart Andrews Changing Inspection Frequency on the Control Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Process Capability & Inspection Frequency: Is there any relationship? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D FAA inspection at my repair station - Rating Check Federal Aviation Administration (FAA) Standards and Requirements 0
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
R Inspection and Work order process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
S Process Inspection -Sub assembly process inspection sheet Lean in Manufacturing and Service Industries 3
C OEE and In-process Inspection Manufacturing and Related Processes 2
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
A Definition of customer in ITP (Inspection & Test Plan) Contract Review Process 3
A DCMA inspection for a drop-shipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
