Can Non-conforming outputs & Non-conformity & Corrective Action procedures be merged
I am developing procedures addressing Non-conforming Outputs and Non-conformity & Corrective Action.
My manager indicated that we should be able to merge these two procedures. My reservation was that non-conforming outputs clause 8.7 of the ISO9001 Standard is based on processes outputs such as assembly outputs, supplier non-conformance etc whilst Non-conformity & Corrective Action clause 10.2 refers to the overall non-conformity Detected within the Quality Management System.
Results from procedure addressing Non-conformity Outputs can then be fed into Non-conformity & Corrective action which can be discussed at the Quality Management Review meeting.
Any thoughts and help on the above is appreciated.
Regards
Hari Varma
Zero_yield
"You can observe a lot by just watching."
Hello Hari,
I'm not sure I understand how you're defining "non-conforming outputs". I don't necessarily see a distinction between a "nonconforming output" and a nonconformance.
Non-conforming outputs (clause 8.7 of ISO9001 Standard) - these non-conformities that are detected in a process and correction is made to rectify the non-conformity. Hence, no further investigation is performed.
Non-conformity & Corrective action ( clause 10.2 of ISO9001 Standard) - this process reviews trends of similar nature within the Quality Management System that would require investigation and determine the root cause(s). In addition , the effectiveness of the solution is assessed to ensure the non-conformity is eliminated.
Non-conformance is both cases has the same meaning. The distinction between the two clauses of the Standard is that 8.7 makes the correction to the non-conformity but 10.2 goes further to review trends of similar nature and investigates.
Ed Panek
QA RA Small Med Dev Company
Possibly. A failure to meet specifications is documented, the root cause is determined, a correction is identified, implemented, and verified its effective, and continuance of monitoring for that failure bucket.
Enghabashy
*The integrated process to merge NC & corrective action in one process is applicable’ although it's maybe more complex rather than the separation ; because also the findings & Ncs are the inputs of coreective action process
**regarding the standardized company form / formal report; it' more effective if the NC &CA report contain atleast 3 parts :
1-1st part for NCs. found , the relevant objective evidences & the relevant reference / clause number of company requirement / standard clause # " -- this issue should be recorded by the auditor /the responsible inspector "
2- 2nd part are reflecting the causes / root causes ; the actions /action plan taken "all should be recorded by the process owner "—the details should contain :
-the correction " controls/repair" related products findings / /--etc. & - the corrective actions " to prevent the re- occurrences" -- the actions should be nominated within time frame for the completion by date & signature
3-the follow up & verification for the effectiveness of actions taken " it's responsibility of the auditor / inspector / Q mgr " whatever the statement in organization process
*** in many cases of NCs/ findings ; the relevant risk assessment / FMEA/control plan, -- could be submitted for reviewing accordingly and for addressing new threats / additional controls
Ed Panek
Another thought, combining external and internal failures (NC) could create a problem. We handle failures in a customer complaint very differently from a risk perspective than a production failure. The risks are vastly different. We have regulatory reporting requirements for customer complaints (Possibly) while that would not happen for production failures.
malasuerte
Regards
Hari Varma
Yes. We call this Issue Management. We then build off that for all the topics in a single document.
Enghabashy
This could be defer from company to company also, it's depend on the complex & sophisticated degree of activities & processes ; manufacturing activities including automotives ; metal forming /cutting/--- maybe more complex rather than one or two process of total final assembly or limited commercial activities , the numbers of processes & relevant inputs & outputs , the risks issues , the measuring issues , the track of people competences ; the heritage of maturity , the Quality culture, the track of repeated deviations & NCs discovered , --etc, -- all could be considered when we merge or separate the processes & the relevant forms
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Non-Conforming Work ISO 17025 related Discussions 1
J ISO 13485- 8.3.1 Non-conforming material high volume ISO 13485:2016 - Medical Device Quality Management Systems 4
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
F Non conforming locked? Manufacturing and Related Processes 13
S Advice on how to reduce overhead of handling non-conforming material Nonconformance and Corrective Action 7
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Looking for RED ESD Bags that preferably say NON-CONFORMING Manufacturing and Related Processes 5
C Method of Monitoring our Internally Produced Non-Conforming Products Quality Tools, Improvement and Analysis 7
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Control of stock (Off the Shelf) Non-Conforming Material & Product Tags ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Combined Procedure - Control of Non-conforming Product, Corrective and Preventive Document Control Systems, Procedures, Forms and Templates 14
N What is the Cost of Tracking Non-Conforming Product Nonconformance and Corrective Action 5
A Non-Conforming Material Control and Inventory Software System Recommendations Quality Assurance and Compliance Software Tools and Solutions 5
C NCM (Non-Conforming Materials) Procedure questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N ISO 17025 clause 5.8.3 Records of Non-Conforming Test Items ISO 17025 related Discussions 3
P Non Conforming Material in the Warehouse..to tag or not? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Salvaging Components of a Non-Conforming Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R How to Handle 'Scrap and Replace' of Non-Conforming Products Nonconformance and Corrective Action 9
K Link between Control of Documents, CPAR & Control of Non-Conforming Product Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J API Q1 - Control of Non-Conforming Product - Use-As-Is or Repair Dispositions Oil and Gas Industry Standards and Regulations 2
C AS9100 8.3 Procedure for Non-Conforming Parts - When should an NCR be filled out? Nonconformance and Corrective Action 5
J Feedback on NCP (Non-Conforming Product) Procedure Nonconformance and Corrective Action 2
T Non Conforming Product from a Supplier - How to proceed Other ISO and International Standards and European Regulations 3
J Positive Control of Non Conforming Material at Machines AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
A Non Conforming Product in an IT (Information Technology) Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J AS9100 Control of Non Conforming Product - Personnel who make Disposition Decisions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 31
J Kindly Review my Control of Non-Conforming Product Procedure Nonconformance and Corrective Action 8
D Non-Conforming Holding Area Methods and Size Nonconformance and Corrective Action 9
G Knowingly Shipping Non-Conforming Product Quality Manager and Management Related Issues 4
Q Nonconforming Material Control - Gap in the Control of Non-Conforming Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Non-conforming product procedure - For a Service Company Document Control Systems, Procedures, Forms and Templates 8
H Known non-conforming samples in attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Non-Conforming Material Hold Tracking Software Quality Assurance and Compliance Software Tools and Solutions 2
B Control of Non-Conforming Material - Location issue AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
V Control of Non Conforming Product procedure explaining the process for approval Nonconformance and Corrective Action 3
L How to apply the clause "control of non-conforming product" on services company ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B 8.3 Non-Conforming Product Aerospace AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
A Control of Non Conforming Service Procedure to Review Service Industry Specific Topics 10
A Service base Non-conforming Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Control of Non Conforming Process Procedure Document Control Systems, Procedures, Forms and Templates 10
G Need template for Non Conforming Report to Supplier (Excel/MS Access format) Supplier Quality Assurance and other Supplier Issues 2
D Non-Conforming Parts and Material Review Board Nonconformance and Corrective Action 7
J Ranking Severity of Non-Conforming Material Defects Nonconformance and Corrective Action 5
J Access Database to Track Non-Conforming Material Quality Assurance and Compliance Software Tools and Solutions 8
Z Non Conforming Material Process for Mechanical and Electrical Assemblies Nonconformance and Corrective Action 2
D Examples of Non-conforming Service for a Recruitment Agency Nonconformance and Corrective Action 6
