Can 'Not Applicable' Fields on Forms be Left Blank?
H
Hoosierken
In this case, I am talking about forms that are filled out by hand. Some of our forms cover a very wide array of customers and products. These forms will have many fields left blank during the process. Do these blanks have to be filled with the "NA" or is a blank field ok? This came up in a recent audit. I think I will have a lot of trouble convincing the production formans to get the floor personnel to make sure every line has something there.
ScottK
Not out of the crisis
Re: Fields on forms left bank?
ISO9001 doesn't require it. Although it's a good practice getting people to do it when it's not an explicit requirement by a standard you follow is tough. Very tough. Tough to the point that I don't bother with it in my current company - and we've never had an external auditor comment on it.
FDA GMPs do require it and at a prior job I used to have to do training twice a year to reinforce how to deal with blank spaces and corrections.
somerqc
I have had this come up too.
I don't mind though because we have used it to find documents that may be unofficially obsolete (re: areas on form were for old products that are no longer produced). This allows us to update forms.
However, I have "convinced" my auditor that not all forms will be updated as an update is not needed and we are saving paperwork (and confusion) by having a multi-purpose form. He seems ok with this.
He is a reasonable auditor so I don't tend to use the "where is the shall" on him, but, he got my point without have to go to that extent.
John
ddunn
I have had an auditor write a minor nonconformance due to blank fields on some forms. It is a good practice to enter “NA” in blank fields to indicate that the field is intentionally blank and not missing data.
If different information is required depending on product and/or customer, you can provide work instructions that tell what information must be provided in each instance, thus avoiding the blank fields issue.
Jimmy the Brit
I agree - the "problem" with blank spaces is that in theory something could be added after the form is finished/approved/filed, essentially falsifying the whole form. As I am so risk adverse (many say paranoid) I always insist on having an NA in all blanks fields, supervisors will not add the final sign off until this has happened, as, according to our procedures the form is not complete until every field is filled.
Where possible design the forms to avoid the whole issue - specific forms for specific tasks.
Jimmy
Marc
Hunkered Down for the Duration
Best Practice --> Enter NA
I agree that this is the best practice.
Jimmy
We should be able to assume that all of the fields on a controlled form are there for a purpose. If they're not, the form should be changed. If they are there for a purpose, they should be appropriately filled in, and "NA" shouldn't be necessary. As I suggested earlier, in the case of multipurpose forms where not all fields are applicable in all cases of use, there should be instructions which describe which fields are relevant for each instance of use. In other words, if forms are properly designed and maintained and users are trained, the use of "NA" is obviated.
Marc
As I suggested earlier, in the case of multipurpose forms where not all fields are applicable in all cases of use, there should be instructions...
Or training...
...if forms are properly designed and maintained and users are trained, the use of "NA" is obviated.
Not necessarily. I have seen many companies where jobs are so different (especially low volume work) that forms often have fields which will be applicable to one customer / job, but not another, and where it is impractical or inefficient in one way or another (such as having 10 very similar forms) to have multiple forms to cover every possible aspect.
Whether or not the company allows the fields to remain 'blank' is often a function of the criticality of the product/process.
Like Jimmy the Brit, in my life I have found it is better to have the employee(s) put in an NA than to leave a field entirely blank. My early background was in military electronics and there were a lot of multi-purpose forms of all kinds. I was taught very early that if a field was not applicable I had to put in NA or N/A or something to show that I had not 'forgotten' the field for any reason. It was totally unacceptable for any field to be left blank on any form.
That said, in non-critical processes/products it's probably not a big deal.
Personally I wouldn't take the chance. I'd ensure every field was addressed in some manner to ensure there will be no question as to whether something was 'forgotten' or overlooked.
Just my :2cents:
somerqc
What we have done for our multi-purpose forms is to colour code the appropriate areas (re: green for particular product group). Basically, we known by the general information whether that area needs to be completed based on the product type.
This has worked well so far; however, a different design may not work and lead to a great deal of confusion.
John
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 1
R An indication that the device is a medical device (MDR, Annex 23.2q) - applicable for accessories? EU Medical Device Regulations 5
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
G App - Local regulations applicable EU Medical Device Regulations 2
M Do you need an Applicable general safety and performance requirements Checklist? EU Medical Device Regulations 2
S SOPs applicable for Regulatory Affairs department Other ISO and International Standards and European Regulations 1
DuncanGibbons Who are ISO/IEC 17065 and 17025 applicable to? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
G Is impact test according to IEC 60601-1 applicable for HAND-HELD equipment if also classified as BODY-WORN? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B EU MDR Quality System Requirements - Applicable to Class I? EU Medical Device Regulations 5
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 2
C Is IEC 60601 applicable to our smart bed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
D Applicable MDR Annex's for Class IIa Medical Devices EU Medical Device Regulations 0
M Dilemma about choosing the most applicable clause related to Risk ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
DuncanGibbons To what extent are NASA standards applicable to commercial aviation? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
M Accelerated Ageing Test for Orthopedic Implants -- ASTM F 1980 or ISO 11607 or both are applicable ? Other Medical Device and Orthopedic Related Topics 2
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
M CEP requirements in MEDDEV 2.7/1, rev 4 and MDR - Are all MEDDEV requirements still applicable? EU Medical Device Regulations 7
MrTetris GDPR - General Data Protection Regulation - Only applicable to EU data? Other ISO and International Standards and European Regulations 6
Q Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
L Pneumatic powertool (Drill) - Is IEC 60601-1 applicable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Q Applicable Medical Device Wifi regulations for various Countries Other Medical Device Regulations World-Wide 7
pcoltsqe AS9100 - The statement 'applicable statutory and regulatory requirements' AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
Q Is it a NC, if a clause is not declared as non applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A ISO 13485:2016 Applicable regulatory requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T To Identify the Applicable MDD Directive - Prepared blood smear EU Medical Device Regulations 13
Q Non applicable clauses in a reseller? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Class I 510(k) exempt - Applicable Standards 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T IATF16949:2016 8.7.1.4 Control of non-applicable reworked product IATF 16949 - Automotive Quality Systems Standard 3
B Standards Needed In House - Determining what standards are applicable Various Other Specifications, Standards, and related Requirements 3
M ISO13485:2016 - Exemption vs. Not Applicable ISO 13485:2016 - Medical Device Quality Management Systems 16
Y ISO 9001 Cl. 8.3 - Design and Development of Products and Services not applicable ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
1 Applicable ISO 9001:2015 Clauses for Remote Site(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C ISO 9001:2015 - Non Applicable Design and Development (Power Plant Operator) Design and Development of Products and Processes 2
B Is IEC TR 80002-1:2009 applicable to stand-alone medical device software? ISO 14971 - Medical Device Risk Management 1
R IEC 60601-1 and 60601-1-2 - Not Applicable for My Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 23
N ISO 13485 - Other Documentation specified by Applicable Regulatory Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
M "Partial Design" Designation and Applicable ISO 9001:2015 Exemptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M ISO 13485:2016 - IQ/OQ Requirements applicable to Electronic Component Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 4
hogheavenfarm OSHA Regulations as Applicable ISO Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Randy Is TS 16949 applicable for "Fuel" manufacturing or blending? IATF 16949 - Automotive Quality Systems Standard 1
E 8.2.3 Monitoring and measurement of processes - What is "Where applicable" IATF 16949 - Automotive Quality Systems Standard 20
P Is Internal and external audit of Account Department applicable to any ISO standard Internal Auditing 5
L When are Statistical techniques not applicable? Service Industry Specific Topics 16
S Applicable standards for CE marking of Spinal Intervertebral Body Fixation Devices EU Medical Device Regulations 3
