Can our QMS Consultant Perform Internal Audits on our behalf (Conflict of Interest)?
Can a consultant hired to implement a QMS also perform 1st. Part audits to the same?
  • Yes
    Votes: 20 74.1%
  • Yes, if the company does not have a suitable Internal Auditor
    Votes: 4 14.8%
  • Better not
    Votes: 2 7.4%
  • No
    Votes: 1 3.7%
  • Total voters
    27
  • Poll closed .
H
Henriqued
As a (external) consultant hired by a Company to help them implementing a QMS (ISO 9001) I recently had a problem when the certification auditor told the management that the internal audit I did was not acceptable, namely as regards the audit to the Quality Manager (a member of the company) and the Quality Management process since I was involved in the process and therefore not an "Independent" person.
My point is to argue that "non conformity" because I say that there is noting in ISO 19011 or 9001 that prevents a consultant contracted to implement a QMS of carrying on a First Part Audit, i.e., an Internal Audit also as an outsourced consultant because he is not responsible for the implementation of the QMS itself but only for giving advice.
Am I right or wrong?...
I would appreciate some URGENT views on this issue, bearing in mind that I am advising the Company to chalenge the respective NC that was raised.
Thank you
Henrique da Silva
(South Africa)
Marc
You are saying you are not involved in the every day processes as an active participant, or I assume this is the case. Usually consultants don't actually play an active part in the 'every day' company systems.
If that is the case, you are technically not in conflict. You are 'independent'.
NOTE: I have made companies I have done internal audits for have someone there audit my audit in so far as my following the company's Internal Audit procedure.
IMPORTANT: By "First Part Audits" you do mean "First Party Audits", correct?
Also see: First Party Audit and 1st, 2nd and 3rd Party Audits - Definition.
ramvaidhya - 2009
Re: Can our QMS Consultant Perform Internal Audits on our behalf (Conflict of Interes
We had consultant audited as internal auditor in UK. This is purely the choise of the management and suitably procedures need to address this as required.
Helmut Jilling
Auditor / Consultant
Thank you
Henrique da Silva
(South Africa)
I agree with Marc. We see this situation in our audits sometimes, and have not had an issue. We generally consider the value to the company vs. the perception of "auditing your own work." You are auditing processes, and can audit any process you do not run. The fact that you helped them implement it some time ago should not be a factor, unless you are not independent of the process.
joshua_sx1
...the only provision in ISO 9001:2000 clause 8.2.2 is that the auditor shall not audit their own work… :rolleyes:
…so, as long as the consultant that is going to audit you (either first, second or third party audit) is not the one who made (developed) your QMS, I don’t think you’ll have problem with that… :cool:
Paul Simpson
I don't believe the intention is to exclude a system developer / documenter from auditing what others are doing. Otherwise a quality manager (MR) cannot have any involvement in audit - as they have overall responsibility.
IMHO the intent is that if I am doing something that is covered by a procedure then I cannot audit that activity. So a QM might, for example be excluded from auditing document approval but not the process covered by the document.
Randy
Yeah, don't get all wrapped around the axle worrying about COI internally because in the end that independance stuff guarantees diddly.....
Can the person audit objectively and impartially?
It's impartiality and objectivity thats truly important.
Besides, in a single person company how could independence occur? And don't say hire somebody to do it or get the local ASQ dude....
Coury Ferguson
Moderator here to help
Let's put another twist on this question:
Case Scenario
A person has been hired by a Company as a permanent employee, to be responsible for the entire Business System (QMS), in a position of authority to make changes.
The company hired a consultant to install a Quality Management System (ISO or AS). The system has been in place for approx. 2 years. There has been internal audits performed, by the Consultant.
The new person comes in and performs a complete round of internal audits including all processes and elements to the required standard.
Being that this new person is responsible for the entire Business System (QMS), would this, in the scenario, be considered auditing their own work (responsible for) or would this be considered independent also?
Added: I extended this poll for 30 days vs 5
Q
QA-Man
A person has been hired by a Company as a permanent employee, to be responsible for the entire Business System (QMS), in a position of some authority to make changes.
This is a good one. I would say it would be considered independent.
The auditor shall not audit his/her own work. In this scenario they have not actually done any of the work they are auditing.
Paul Simpson
Case Scenario
I took out the bit about the consultant as I don't feel it is relevant. :)
The new hire can audit any area (so long as they are competent in auditing) except those they are directly involved in (i.e. they are actually "doing" stuff covered by a procedure (whether documented or not)).
S Can anyone share a Consultant Proposal for QMS Remediation? Consultants and Consulting 5
A How do I find a reputable consultant to review our QMS? Consultants and Consulting 23
L Consultant for QMS, EMS, OHSAS and TS 16949 in India Consultants and Consulting 9
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
V Remote QMS Coordinator Position Job Openings, Consulting and Employment Opportunities 0
A How to prepare QMS manual for purchasing department Quality Management System (QMS) Manuals 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
GreatNate Anyone using the Intellect QMS software? Quality Assurance and Compliance Software Tools and Solutions 1
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
supadrai Remote Opportunity - Large Scale Glove Factory QMS / RA / Legal Job Openings, Consulting and Employment Opportunities 0
C Retention of QMS Plans and Reports ISO 13485:2016 - Medical Device Quality Management Systems 5
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
S AS9120 Store QMS packages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Disappointed in leadership buy-in to QMS Quality Manager and Management Related Issues 67
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Implementing an ISO 13485 QMS Software ISO 13485:2016 - Medical Device Quality Management Systems 6
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Timeframe for updating QMS / transitioning from ISO 14971:2012 to ISO 14971:2019 ISO 14971 - Medical Device Risk Management 10
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Offsite storage of QMS documents ISO 13485:2016 - Medical Device Quality Management Systems 9
L Exemption from the Regulation COVID-19 and QMS requirements EU Medical Device Regulations 2
DuncanGibbons Model-Based procedures and Architecting the QMS as a System Document Control Systems, Procedures, Forms and Templates 2
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Expanding our business and the implications to our QMS Manufacturing and Related Processes 2
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
M QMS for a repair/servicing company ISO 13485:2016 - Medical Device Quality Management Systems 2
A Is there a better way to do a complete assessment of our QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A QMS Overhaul - Reorganizing and Renaming Documents - Internal References Document Control Systems, Procedures, Forms and Templates 24
qualprod Documented actions and changes in the QMS by COVID 19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
DuncanGibbons Enterprise Architecture for QMS Conceptualization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
S Class I MDR Article 10 – QMS EU Medical Device Regulations 1
I Drupal for QMS Quality Tools, Improvement and Analysis 26
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Validation Records - Very young QMS Qualification and Validation (including 21 CFR Part 11) 2
E Sharepoint for ISO 13485 QMS for small IVD company ISO 13485:2016 - Medical Device Quality Management Systems 11
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
