Can PC Plastic Material be used in Medical Device Cases?
maple68
#11
Thanks Kuyakut.
You mentioned handheld device. I was reading an artical discussing if biocompatibility is nessassary for handheld casing. From your experience, what do you think?
Thanks again,
Maple
JeantheBigone
#12
Skin contact is skin contact.
I had a funny discussion one time when I was on the phone with someone at the FDA. It was concerning a device with a part approx 4" diameter which was to be placed on the patient's body for a total of about 20 minutes / day. The FDA employee said we needed biocompatibility because of the skin contact. As I was talking with him, I realized that I was holding the phone under my chin. I said "you know, I spend about an hour on the day with this phone receiver touching my face. Is that biocompatible?"
He replied, "we're not responsible for phones, only medical devices."
You can try getting clearance without it if you can't get the datasheet from the plastic supplier, your worst case fallback is to put a caution on the label to wear gloves while handling it.
maple68
#13
:) Thanks a lot.
Is the caution on label sufficient, or we have to get the material tested?
Also I have another question. When a material is classified as medical grade, does it mean it passed the IEC 10993 test?
Thanks again,
JeantheBigone
#14
I dug a little bit on the internet and found myself back in the Cove!
"Medical Grade" is a loose definition. Apparently it refers to testing to USP Class VI, which is not the same thing as the battery of ISO 10993 test which may be required.
http://elsmar.com/Forums/showthread.php?t=16152
That makes sense to me, since "medical grade" can take on different meanings depending on on whether the device has skin contact, bone contact, blood contact, etc and correspondingly the required ISO 10993 tests are different.
So the short answer is "no" they are not the same thing.
As far as how you proceed, I cannot say what is best for you. What happened to us is we got a deficiency letter because we had not demonstrated biocompatibility in our 510(k). Rather than spend the $10,000 or whatever to get it done, we simply added a caution in the labeling to wear clothing. You can try submitting it and see what happens. If you get a deficiency letter you can add the caution. Maybe in the future if you submit a modification you can change your polymer to one where the supplier has done the testing and can give you a datasheet.
kuyakut
#15
Hi Maple,
For biocompatibility we do for most of our handheld device on my current company . Not that it is necessary but because someone from RA department drafted the procedure that all medical device components - including handheld device must comform biocompatibility. With my previous company we dont do biocompatibility on our medical handheld device components whether it has skin contact to the patient.
Kuyakut
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
J Relative Humidity and Plastic Raw Material Moisture Manufacturing and Related Processes 4
N Can I get a PPAP sample of Bulk Material (Plastic Resin)? APQP and PPAP 2
M Raw Material Handling & Mixing in Plastic Injection Moulding Manufacturing and Related Processes 5
C FM (Foreign Material) Specifications for Plastic Molded Devices & Glass Containers Other Medical Device Related Standards 5
G Plastic Flexibilty - Polypropylene H1500 material Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Material Review Board Process in a small plastic manufacturing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Plastic Identification/Test - Melt Flow Index to Determine Correct Material? Manufacturing and Related Processes 16
B About FMVSS302 - What frequency do I have to test burn plastic material Various Other Specifications, Standards, and related Requirements 23
W DFMEA (Design FMEA) for Bulk Material - Resin for Plastic Injection Moulding FMEA and Control Plans 1
B TS16949 - PPAP Material Analysis Requirement - Plastic component supplier APQP and PPAP 10
M Restricted Plastic Material in the manufacturing of automotive parts? Customer and Company Specific Requirements 3
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
C ABS plastic : which IEC 60601-1 tests to redo? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Glass and brittle plastic Policy - Required per FSSC 220002-4? Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Nicole Desouza Plastic Extrusion of Medical Device Components - No ISO or AS 9100 Certifications Other Medical Device and Orthopedic Related Topics 7
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Fernando Drumond Calibration and Control of Plastic Volumetric Measurement Instruments General Measurement Device and Calibration Topics 1
erozas2003 Color test on molded plastic parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
M Informational 2019 Meeting Materials of the General and Plastic Surgery Devices Panel Medical Device and FDA Regulations and Standards News 0
M Informational The USFDA Announces General and Plastic Surgery Devices Panel of the Medical Devices Advisory Committee Meeting on March 25-26, 2019 Medical Device and FDA Regulations and Standards News 0
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
John Broomfield Cleaning plastic from our oceans - The Ocean Cleanup Venture Sustainability, Green Initiatives and Ecology 33
A Cleaning plastic parts for sterilized medical devices ISO 13485:2016 - Medical Device Quality Management Systems 15
smryan Chemistry and physics of plastic behavior - Any plastics experts in the house? Coffee Break and Water Cooler Discussions 1
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
J Finishes on Plastic Molded Parts Manufacturing and Related Processes 9
D Hot Plate Welded Plastic Strength Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Testing Large Plastic Pipe Imported Legacy Blogs 0
L Product Requalification for Plastic Injected Parts APQP and PPAP 3
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
M How to fix a plastic bag on leg with a bandage to take a shower Coffee Break and Water Cooler Discussions 15
M Kinds of plastic for molded parts in a main frame as structure Manufacturing and Related Processes 7
M Best Type of Grease for Vex Plastic Gears Manufacturing and Related Processes 5
M Lot Numbers of Plastic Disposables in an LDT (laboratory developed test) ISO 13485:2016 - Medical Device Quality Management Systems 6
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
N What Can I Do With Plastic Pellet Scrap? Manufacturing and Related Processes 17
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
S ECH (ethylene chlorohydrin) residues - Plastic catheter packed in a sterile bag Other Medical Device Related Standards 5
J Plastic Compatibility tests with the contact of mucous membranes Other Medical Device Regulations World-Wide 3
E Cosmetic Standard for Sheets of Extruded Plastic Manufacturing and Related Processes 1
