Can Uncertainty be larger than the Specification on a Certification
adamt
I have a certification on an electrical device that states a larger measurement uncertainty than the specification of the UUT. I have not seen this before. Can someone give me guidance.
I have always been under the impression that if your uncertainty was larger than your specification that you could not be sure of your measurement results were within the stated tolerance allowed.
Jen Kirley
Quality and Auditing Expert
At the face of it my answer would be "no." But the subject is not so simple. An article titled "Uncertain about uncertainty?" is available to (I hope) help understand the subject. An excerpt from the article is as follows:
Uncertainty, on the other hand, is a range of values likely to be encountered during a measurement. A simple example is a format such as 10 mm ± 0.005 mm. This means that a measurement of 10 mm will have values ranging from 9.995 to 10.005 mm. And that range of results may be made up of both systematic and random errors.
The literature by itself is not all there is to the subject - I think you would be more interested in Test Uncertainty Ratio (TUR) as described in the paper TEST UNCERTAINTY & TEST UNCERTAINTY RATIO (TUR), and A2LA has put out a piece of guidance titled Guide for Estimation of Uncertainty of Dimensional Calibration and Testing Results that I hope will also be of some use.
adamt
Thank you for your reply. I have read the documents you posted. It is interesting that you bring up A2LA do to it is an A2LA accredited certification that is in question. It still does not answer the question out right.
I don't understand the uncertainty on this issue. :mg:
Maybe I should be asking for a opinion pole on this issue.
Jen Kirley
I was concerned about whether or not my reply answered your question. Let me make sure I understand you: are you saying your instrument's stated uncertainty (as listed on calibration certificate) exceeds your dimension acceptable tolerance window?
If so, let us begin again with a paper I found on the uncertainty subject, titled IMPORTANT FEATURES OF ESTIMATION & INTERPRETATION OF MEASUREMENT UNCERTAINTY. Sections of particular interest to us are 3.1 and 3.2.
Uncertainty is a big subject that is beyond what most of us do; A2LA (I like A2LA for putting out these nice guidance documents) has published a guidance document titled A2LA Guide for Estimation of Measurement Uncertainty In Testing that goes into more depth than the first paper.
The uncertainty scenario you describe seems very unusual. So I have questions:
Does your instrument have a resolution at least 10 times greater than the increments of your specification tolerance?
What is the range of your instrument as compared to the specification window?
adamt
Thanks for your quick response.
The instrument is a temperature calibrator with a 30 to 400 deg C range. Resolution is .1 deg C accuracy is +/- 2.1 deg C.
The uncertainty on the cert is 2.66 deg C. There are four other data points listed and all have uncertainties greater than the specification of the UUT.
BradM
I would suggest the 2.66 deg C is the total uncertainty calculated by the vendor for performing the calibration on the temperature calibrator. It takes several variables into account when estimated. I would hope their uncertainty would be better than that.
It could be the uncertainty for your Unit Under Test though, and may include additional factors other than the calibrator itself. The best way to find out would be contact the vendor and see how they estimated that value.
Without seeing the certificate it's difficult to say.
adamt
Hi Brad,
I have talked to the lab in question and they said that an uncertainty for a measurement data point can be larger than the specification. I asked them how and I did not agree and now am asking for advice and trying to get documentation that tells me if I am right or not.
Believe me I have been wrong before. I would like a more definitive answer before I take them off our vendor list. If I am wrong them I will eat crow. I am a CCT and have done lots of uncertainty budgets for our CMCs and UUT. I believe the more information I have the better I can understand this point.
Jen Kirley
It's plain enough that I'm in over my head with this one. I have PMed two fellow Moderators with 17025 specialty, to see if they can lend a hand with this question. :cfingers:
BradM
Ok, I'm still unsure what uncertainty the vendor is reporting.
Are they reporting their testing uncertainty or an uncertainty for the UUT?
Either way, that's not a very good uncertainty they report. :)
What standard are they using?
adamt
They say that it is the uncertainty of each calibration test point with standard and test included. They are using a Hart 1502A and 5618B. The accuracy for these is very good.
I believe they are using the right equipment per manufactures procedure. It is the uncertainty they list on the certification that I have a problem with.
The question still looms can you list an uncertainty larger than the specification and have confidence that the unit is still in tolerance.
L Uncertainty calculation for an average Measurement Uncertainty (MU) 1
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
F Issues in Uncertainty Estimation Measurement Uncertainty (MU) 5
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
F Learning Uncertainty Budget for Novice - Fluke 5520A Measurement Uncertainty (MU) 1
S Uncertainty Budgets - Phase Noise (SSB), Harmonics Measurement Uncertainty (MU) 2
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
A Uncertainty Budget - Externally produced sensor module Measurement Uncertainty (MU) 1
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
M Medical Device News FDA news - 05-09-18 - Draft - Uncertainty in Benefit-Risk Determinations Other US Medical Device Regulations 0
G How to include machine error in uncertainty calculations? Measurement Uncertainty (MU) 5
M Calibration certificates avowing accuracy beyond the uncertainty limits? Measurement Uncertainty (MU) 7
G ANAB ISO 17025 Accreditation - Uncertainty and systematic error? ISO 17025 related Discussions 6
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
G Uncertainty Experts - ISO 17025 - If the Distribution is Rectangular Measurement Uncertainty (MU) 2
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
P Uncertainty and Significantly Different Means - Buffer Solutions Measurement Uncertainty (MU) 4
S Pressure Gauge Calibration Uncertainty Calibration and Metrology Software and Hardware 5
E Uncertainty of Mean - Test rig that measures water temperatures Measurement Uncertainty (MU) 3
J Internal Laboratory Scope and Measurement Uncertainty (MU) IATF 16949 - Automotive Quality Systems Standard 1
G Manual Procedure with Uncertainty Budgeting for either a Caliper or Micrometer General Measurement Device and Calibration Topics 6
C MU (Measurement Uncertainty) in an Internal Calibration Laboratory Measurement Uncertainty (MU) 1
N How to Convert Micro Volts into Temperature Uncertainty Measurement Uncertainty (MU) 1
N Include homogeneity uncertainty into budget table for thermocouples Measurement Uncertainty (MU) 1
J CMM Uncertainty Calculation Question - Deviations Measurement Uncertainty (MU) 9
M Uncertainty Budget for a Micrometer Measurement Uncertainty (MU) 5
C Uncertainty Trainer in Texas? Measurement Uncertainty (MU) 3
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
C Uncertainty Estimation for Spark Optical Emission Device Measurement Uncertainty (MU) 1
B Measurement Uncertainty using Minitab Measurement Uncertainty (MU) 2
J Uncertainty budget for IR thermometry at high T - 1000 - 1500?C Measurement Uncertainty (MU) 1
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
M Help with uncertainty calculation in the calibration of a Pyrogen Test Processor Measurement Uncertainty (MU) 7
