Can we use pin gauges to measure an accurate Cpk ?
Ian Kenyon
We manufacture printed circuit boards. we have a hole with a specification of 1.00 mm +0.09 mm - 0.00 mm with a Cpk of greater than 1.33.
can we use pin gauges in increments of 0.01 mm to measure repeatedly and calculate the Cpk to the above specification ?
It is theoretically possible, but would be difficult in reality. You would have to be on target with a standard deviation of approximately 0.01, including the measurement variation.
maybe a different approach is in order rather than a simple march to calculating a Cpk? I assume(?) that the characteristic is the hole diameter and not a positional characteristic? what does the hole do?
Another problem is that a pin gage doesn't measure the size of the hole. A one-inch cylinder won't fit in a one-inch diameter hole.
Ian Kenyon
The holes are press fit holes for a 7 pin device.
bobdoering
Stop X-bar/R Madness!!
First, to meet 1.33, you would have to be running at 75% of your tolerance or better - meaning the bulk of your data is within .067mm spread. To get decent resolution to determine your distribution, you would need measurement of at least 10 "buckets" - or about 5 micron increments. If your distribution is skewed, you might need to do better than that. A "tenth" set of pins (.0001" or 2.5 micron) would give you some idea what your distribution looks like. Yes, pins are MMC plus fit - but when looking for features that have mating features inserted into them, it is a darn safe measurement technique. Most customers would agree to it. From my experience with circuit board production, I would be comfortable with it.
Welshwizard
Hi Ian,
I agree with Miner, the manufacturing process standard deviation would have to be just over 0.011 mm or better and your pin increments swallow nearly all this up. You could go for smaller pin increments but practically how much can you really "feel" when applying what are essentially plug gauges?
There's a difference between sentencing parts and measuring a feature to ascertain process capability, it may be easier to persuade the customer that go/no go checks are more appropriate for this product than finding a device to measure a hole feature of this size which behaves consistently.
Dhara
There is a possibility to calculate process capability with go/no-go checks using the Z-scores, if calculating process capability is a customer requirement.
Cpk = Z Score (p)/3
bobdoering
Let's not forget, customers often rubber stamp 1.33 Cpk requirements on things with no regard to the practicality of the demand. There is a hole check device for PC holes - but I bet tenth set of pins would be more consistent. Try a gage R&R and see which is best.
Al Rosen
This is the hole check device you are referring to.
  • KAITEKWIKCHECKBrochure2016Rev01LowRes.pdf
