Can you reference original FAI (First Article Inspection) after Delta?
F
faiguy
Here's the situation:
We created a FAI for a first time build that required the parts to go to an outside vendor. After a few builds we find ourselves in a position that requires us to perform the process that our Vendor did. This required us to make a Delta (partial) FAI. Now that the time constraints are lifted we will be sending the parts back to the Vendor to have the work done. Do we need to create another Delta FAI? If our Travelers (jobs) went back to referencing the original FAI number would that meet the AS9102 requirement?
A little break down might help.
Job # 20012, New FAI (#100), Original build
Job # 20145, Referenced FAI (#100), Repeat build
Job # 21012, Referenced FAI (#100), Repeat build
Job # 22115, Delta FAI (#100A), Went from Vendor to in-house process
Job # 23455, Reference Original FAI (#100), Send back to Vendor for process
Can I go back and reference FAI# 100 or would I have to make another delta (FAI# 100B)
Thanks for your help.
P
Phiobi
Re: Can you reference original FAI after Delta?
It can depend who your customer is. In theory you can revert to the original but I assume you want to maintain the option to use the vendor or not so check with your customer and see what they require. If this is OEM then yes you can so long as less than 2 years have lapsed since you lasted manufactured to that FAI
dsanabria
If you meet the requirements of 5.3 and the following note- the answer is yes
AS9102 Rev A
"5.3 Partial or Re-accomplishment of First Article Inspection
The FAI requirement, once invoked, shall continue to apply even after initial compliance. The FAI requirements may be satisfied by a partial FAI that addresses differences between the current configuration and prior approved configurations. When a partial FAI is performed, the Organization shall complete only the affected fields in the FAI forms.
FAI requirements may also be satisfied by previously approved FAI performed on identical characteristics of similar parts produced by identical means. When FAI requirements (partial or complete) are satisfied in this manner, identify the approved configuration in the index of part numbers on Form 1."
... and check with the customer to see if they accept Delta FAIR.
F
faiguy
Thanks for your help! Logically I couldn't see a reason why it couldn't be done that what but I wanted to see what other people thought.
Hopefully my Quality Director, and end customer, both agree.
Thanks again.
S Reference to original Calibration Certificate - ISO 17025 Section 5.10.9 ISO 17025 related Discussions 4
J Selecting reference standards for calibration General Measurement Device and Calibration Topics 3
V Is it required to recalibrate reference- standard instruments after equipment qualification General Measurement Device and Calibration Topics 0
I Hold Time studies for Primary Reference standards Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
E 510k reference devices US Food and Drug Administration (FDA) 4
G Seeking reference guides/ documentation /tips on verification best practices Other Medical Device Related Standards 6
B Qualifying a reference analyzer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
E MSA Reference Manual 2nd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Reference to an archived template in multiple SOPs ISO 13485:2016 - Medical Device Quality Management Systems 2
R Statistical Methods for comparing test and reference product equivalence for quality attributes US Food and Drug Administration (FDA) 3
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
G GD&T applied to reference dimension. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
M Reference part calibration or verification General Measurement Device and Calibration Topics 12
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
W Do Reference materials for IATF need to be 17025? IATF 16949 - Automotive Quality Systems Standard 15
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 4
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 4
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 8
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
E IEC 60601-2-25 Reference to 60601-1 2nd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
