Can you Set Inspection Frequencies Scientifically?
SteveL
Firstly, apologies if this is the wrong forum but I couldn't find one related specifically to Inspection.
To my main point. As a Quality Engineering Dept have been tasked with devising a methodology for determining Inspection Frequencies of parts we measure on our CMM's. This is proving very difficult to acheive scientifically.
We clearly want to relate inspection frequencies to process performance and therefore we've initally used both Cpk outputs and Est Reject % as our 'drivers' ie Cpk < 1.00 measure 1 in 1
The problem we have is whether or not this rationale is valid and if so is there a recognised scale with which to adopt this approach to
ie Cpk <1.00 = measure 1 in 1, Cpk 1.00 - 1.33 = measure 1 in 2, Cpk 1.33 - 1.67 = measure 1 in 5, etc.
Thanking you in advance for your input.
Steve
Benjamin28
I think Jenn has led you down the correct path here. What you're looking for is an acceptable sampling plan. You can read about sampling plans here on the forums and get some good information from a google search. But yes, you can set inspection frequencies (sampling intervals) by using an established sampling plan which will allow you to base your inspections on a statistically valid system.
Good advice from Jennifer and Benjamin so far. Keep in mind that what you're trying to do is find a level of acceptable risk--the risk of not doing inspection as frequently as you do presently. I would forget about trying to correlate Cpk with this sort of risk. If you're currently doing control charting, you should already know what you need to know about the likelihood of NC production. What remains is a rational sampling plan that will allow you to have a reasonable level of confidence in finding defective items, and there's lots of information here on statistical sampling.
D First Piece Set-Up Inspection question Manufacturing and Related Processes 11
R Need to set up sampling plans in Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
G Label Inspection - How to Set Goals for Inspectors - Label Manufacturer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q To set frequency to review documents in ISO 9001 7.5? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
B Set RH spec from dewpoint spec General Measurement Device and Calibration Topics 2
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
N When to record values if a spec for a mfg process is set Manufacturing and Related Processes 3
Marc Time Zone - Set your Time Zone Elsmar Xenforo Forum Software Instructions and Help 1
D As a newcomer to QMS, I really appreciate how ISO is set up. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949 Cl 8.5.1.3 - Verification of job set up IATF 16949 - Automotive Quality Systems Standard 4
D How to set equipment calibration/verification criteria General Measurement Device and Calibration Topics 1
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
G What to Check - Set Up vs. In Process Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N The known set of all root causes Nonconformance and Corrective Action 11
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
G Training Employees about Quality - Philosophy / Mind set Misc. Quality Assurance and Business Systems Related Topics 1
renenatasha MDD Classification for Pressure Monitoring Set CE Marking (Conformité Européene) / CB Scheme 1
U Are all manufacturers required to set up eMDR system? Other US Medical Device Regulations 4
Sean Kelley Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
E How to use the Standard Error and how to set the error limits? Reliability Analysis - Predictions, Testing and Standards 2
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S How to set up the Accupoint 2 ATP sanitation monitoring system Quality Assurance and Compliance Software Tools and Solutions 1
L How do I set a limits to cfu in an ISO class 7 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 2
4 Quality vs Production on CMM Set Up Requirements Manufacturing and Related Processes 1
A What is the definition of Installation that requires Record Keeping vs Set-up 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G AS9120 - What should we be expecting once we set forth into becoming certified? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A IEC 60601-2-24 Question: Free Flow Clamp on Set? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
L How to set up a basic electronic test equipment calibration laboratory General Measurement Device and Calibration Topics 3
Q Inquire TS 16949 standard - Clause 7.5.1.3 Verification of 'Job Set-Up' IATF 16949 - Automotive Quality Systems Standard 7
M AS9100C Document Control for Machine Set Up Work Instructions AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
J Appropriate In-Process Monitoring Frequency for 2X per day Change Set-Up. Statistical Analysis Tools, Techniques and SPC 3
S Insufflation Tubing & Filter Set Product Classification question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M New Calibration Laboratory Set Up Measurement Parameters and Equipment General Measurement Device and Calibration Topics 4
B How to set Cleanroom Alert and Action Limits as part of Microbiological Evaluation Quality Assurance and Compliance Software Tools and Solutions 8
F How to set-up a Dual Company QMS (Quality Management System) Quality Manager and Management Related Issues 2
R Can the same Biocompatibility Report for Infusion Set be used for its Components? ISO 13485:2016 - Medical Device Quality Management Systems 7
insect warfare How is the Management Review structure of your company set up? Management Review Meetings and related Processes 5
AnaMariaVR2 Legal Flash: 8 Regulations set to impact the Pharma & Biotech Industry in 2013 US Food and Drug Administration (FDA) 0
F Receiving a new Gage Block Set with an old Certificate Calibration Frequency (Interval) 3
L Gauge to test and verify a Set Square Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Barahir Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
