CAP for Medical Device Class Is product - Slightly confused - ISO 13485
Camille
First of all: My understanding is, that a class Is product would normally go the route according to Annex VII.
Situation:
- A product is classified as a class Is device
- The ISO 13485 certificate states:
  • several products (sterile and non sterile)
  • Annex II (except 4) and Annex V sterility aspects only.
- The class Is product should be reclassified as a IIb product based on indication extension
Does this mean that
a) the combination of Annex II and Annex V covers a class Is device?
b) the Annex II and V overrule Annex VII in this case?
I am a little confused :confused:
Thanks for your help :thanx:
Roland Cooke
Re: CAP for class Is product - Slightly confused
Situation:
Does this mean that
I'm confused as well!
Firstly, there is no direct relationship between your ISO13485 certificate and your MDD certificate. Classes of products are not described within ISO13485 so I will be surprised if your 13485 certificate actually says what you indicated.
As for your Class I sterile devices (under the MDD), you are correct that have to follow Annex VII (as with all Class I devices), however section 5 requires you to follow additional rules - which is where additional compliance to the relevant sections of Annex V kicks in.
When the revision of the MDD comes into force in 2010 you will also have the option to have your Class I (sterile) devices covered by Annex II.
(In hindsight the original official position of not allowing the use of Annex II was seen to be pointless, and probably counter-productive).
I'm not clear on what the context of this statement is.
Did you advise your Notified Body that you will be changing the intended use, and they in turn confirmed that that will cause the classification to go to Class IIB (for which Annex VII + V will no longer be appropriate)?
Or did you already change the intended use of the device (and maybe placed the device on the market), whilst still (mis)classifying it as Class I (sterile), which presumably resulted in a non-conformity being raised?
Camille
Sorry, for the confusion. My typo. I meant the MDD certificate :)
I understand that as a class IIb device Annex VII or V will no longer be appropriate. It would be either the Full Quality Assurance route according to Annex II or the EC Type Exam according to Annex III followed either by Annex IV, V or VI
BTW: The device is not yet placed on the market
Thanks for your help and input!
Roland Cooke
Annex III is typically only appropriate if
a) there is a full international standard that describes your products.
b) the tests described within the standard can be performed in-house or at a qualified laboratory (or equivalent situation)
c) it is economically worthwhile
Probably only 0.01% of medical devices utilise Annex III.....
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
I CAP/CLIA Environment - Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 3
M Bent Hex Head Cap Bolts Manufacturing and Related Processes 5
R Is IMDS required for Shipping cap received from our suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 7
J Should I file a Customer Complaint as a Nonconforming Material Report or a CAP? Nonconformance and Corrective Action 5
D Measuring Wall Thickness on Socket Head Cap Screws Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Marc Time Warner - Bandwidth Cap Screw - Beware Internet 'brown-outs'? After Work and Weekend Discussion Topics 2
Q Has anyone heard of DST-PDCA or Cap-Do? Quality Tools, Improvement and Analysis 4
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 1
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
T Google Fit Health datas and Medical devices Application Medical Information Technology, Medical Software and Health Informatics 0
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Procedure packs with non-medical devices EU Medical Device Regulations 1
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
D Electrical Medical Devices class I EU Medical Device Regulations 0
J Are complaints applicable to development of medical devices? Customer Complaints 2
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
Brian Benzarti Medical Devices CLP Regulation Quality Assurance and Compliance Software Tools and Solutions 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
dgrainger Informational Medicines and Medical Devices Act 2021 UK Medical Device Regulations 0
S Medical Device MRI Compatibility EU Medical Device Regulations 3
M NICE Medical Technology Evaluation Programme - Recommendations Service Industry Specific Topics 0
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
