CAPA Closure for a seldom produced item
I
ISODOC
Can a CAPA be closed if the action that needs to be taken to correct the problem cannot be done until a new order comes in, which in this case may be months or a year away?
sagai
Re: CAPA Closure
Hi !
I do not think so.
CAPA can be closed when it was verified and the effectiveness of the correction/ca/pa testified.
We also have cases when regardless we have already almost ready, the effectiveness check is in a "far" future time. These are mostly process related CAPAs, when you can not immediately check whether or not it was implemented properly, or for example internal audit findings, when due to the nature of large organization, the CAPA depends on a different team and we will not check the effectiveness till the time of the next internal audit, typically a year later.
br
Sz.
qusys
Re: CAPA Closure
However you should have a plan in place with responsibilities defined as well as due dates.
You should demonstrate a percentage progress and continual monitor and set a date for follow up to control the status.
In the successive audit we can verify if the process owner has completely closed the action , by also verifying the effectiveness:bigwave:
Jen Kirley
Quality and Auditing Expert
Re: CAPA Closure
Welcome to the Cove! :bigwave:
The answer to your question is a resounding "maybe."
Could you share what the nonconformance was for, in specific terms? We could perhaps discuss the actions taken and the various positions (arguments) for closing, closing with a plan to re-audit as soon as the next order comes in, or keep open.
Re: CAPA Closure
Welcome to the Cove. :)
Why would you want to close it? More details would be good, but in general the record should be complete, including everything that happens as a result of the original NC.
I
ISODOC
Re: CAPA Closure
We currently have over 175 CAPA's open at this time. We're having a hard time keeping up with them with the limited resources we have and more are written weekly. We are a job shop that makes tubing that are run in small batches and each one is unique (special tooling, etc.). When the job runs and the part is out of specification its written up on an NCR and we usually request a deviation from the customer. Some customers agree to the deviation request while others don't. The ones that don't accept the deviation we re-run and try to make some changes to the run to get acceptable product. It's a very dynamic environment as you can imagine. Most engineers have 7-15 CAPA's at one time. Any advice you can give would be greatly appreciated.
Re: CAPA Closure
<snip>
That seems a bit extreme. Either your business is wildly out of control in one way or another or you're producing documentation unnecessarily, or it's some combination of the two. The problem isn't open CAs, it's too many CAs. That's the problem you need to solve.
Sidney Vianna
Post Responsibly
If the corrective action is job specific or product specific or customer specific, you should wait until you run the part number again, so you can assess the EFFECTIVENESS of the corrective action. Now, if the corrective action was related to a process that can be verified in a similar product, you should be able to "close" the corrective action request accordingly.
Much better than to rush a closure of a CAR, is to ensure that, indeed, the problem does not recur. When it comes to corrective action closure, assurance of implementation and effectiveness is MUCH more important than promptness.
Marc
Re: CAPA Closure
<snip> That seems a bit extreme. Either your business is wildly out of control in one way or another or you're producing documentation unnecessarily, or it's some combination of the two. The problem isn't open CAs, it's too many CAs. That's the problem you need to solve.
Or - It's a relatively large company.
Al Dyer
Call me an old broken 78 record, but the only one that can really close the action is the customer, internal or external.
Al...
F NCMRs and its relation to CAPA Nonconformance and Corrective Action 7
C Projects in the CAPA system Preventive Action and Continuous Improvement 6
S EU MDR CAPA - GAP Assessment on CAPA SOPs EU Medical Device Regulations 1
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
B Do you use paper or web-based templates for CAPA processes? ISO 13485:2016 - Medical Device Quality Management Systems 3
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
B CAPA - Extensions vs Overdue Nonconformance and Corrective Action 11
G New CAPA Work Flow with Revised 8D Approach Process Maps, Process Mapping and Turtle Diagrams 35
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
V CAPA effectiveness check Nonconformance and Corrective Action 3
Ed Panek CAPA against Notified Body? EU Medical Device Regulations 5
CPhelan Nonconformance opened as incorrect expiration date placed on received product. Escalate to CAPA? Nonconformance and Corrective Action 4
N How to monitor the effectiveness of the CAPA system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
Q Raising A CAPA on Current CAPA system US Food and Drug Administration (FDA) 3
Z Security for Approvals - Cloud based Complaint, NC, and CAPA systems Qualification and Validation (including 21 CFR Part 11) 8
S FDA requirements and CAPA's Qualification and Validation (including 21 CFR Part 11) 2
J MDR reporting and CAPA thoughts? Classifying Complaints on Risk 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
Don Fardie CAPA vs. Risk Assessment - Changing a product material for better performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A NCR, NCMR, CAPA, Deviations - Medical Device Distributor Nonconformance and Corrective Action 2
S CAPA Investigation Methods Nonconformance and Corrective Action 3
qualprod Should I initiate CAPA for a nonconformance not recorded? Nonconformance and Corrective Action 25
R CAPA Verification - ISO 13485:2016 Requirements and Objective Evidence ISO 13485:2016 - Medical Device Quality Management Systems 2
J CAPA and other Log Requirements ISO 13485:2016 - Medical Device Quality Management Systems 8
D Any Elsmar members using Traqpath to manage CAPA? Nonconformance and Corrective Action 2
D CAPA - Suggested Action vs Action Plan Nonconformance and Corrective Action 5
A Audit Finding - CAPA, Improvement Initiatives not filed in CAR System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Issue with CAPA system - Should Over Due CAs warrant a CAPA? Nonconformance and Corrective Action 17
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
A Escalation to CAPA - Assessing if an NC warrants a CAPA Nonconformance and Corrective Action 4
P Trending CAPA's in our Management Review Meetings ISO 13485:2016 - Medical Device Quality Management Systems 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 2
P How CAPA's are trended in Management Review Nonconformance and Corrective Action 1
P Sample FDA compliant CAPA procedure wanted Document Control Systems, Procedures, Forms and Templates 2
Q Effectiveness Plan for CAPA initiated from External Audit US Food and Drug Administration (FDA) 3
A Risk Management, complaint handling and CAPA system ISO 14971 - Medical Device Risk Management 5
G Come up with a solution to our CAPA system Nonconformance and Corrective Action 3
B CAPA (Corrective Action) For A Typo? Nonconformance and Corrective Action 18
P Example Risk Assessment for CAPA's Document Control Systems, Procedures, Forms and Templates 5
A Complaint Evaluation vs. Complaint Investigation vs. CAPA Investigation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
E CAPA Management Software Tool Recommendations for Small Companies Quality Assurance and Compliance Software Tools and Solutions 3
