CAPA (Corrective Action and Preventive Action) after Correction always?
Q
QAMTY
Hello everybody
I want to ensure that after a Correction
a CA/PA must be implemented.
ON where document should I include this statement?
On the NCR, CA/PA, or in the Claim and complaint
procedure?
But still have doubt in this issue.
For example when a NC, appears
and disposition is "use it as is", then,this is fixed
but is not eliminated the root cause.
Then in this case a CA/PA is needed in my opinion.
But if disposition is Scrap, then this part/equipment
is replaced for a new one.
In here I suupose is not needed a CA/PA
is it correct my assumption?
Should I then, that CA/PA is needed only in
disposition like Use it as is, Rework, Repair
and not needed when disposition is Degrade and scrap?
Please help me in clarifying this.
samsung
Re: CA/PA after Correction always?
Still you need to find out the root cause of the problem as to how & why it happened and take CA as appropriate. You take corrective actions on the root cause of the problem encountered, not on the nonconforming product which you have already decided to scrap.
Nonconformance and nonconforming product are two separate things although it's the former that results into the NC product.
somashekar
Hello everybody
ON where document should I include this statement? <snip>
Hi, This is a very common place where clarity gets missed. You have to be very clear about what you will do to control a NC product as said in 8.3. This is to prevent the unintended use or delivery.
Having done this you will most probably get data about :
1. Non-conformity of product to requirements
2. Characteristics and trends of processes and products
You have to analyse this data and where you find that the NC data or the characteristics and trends show lack of suitable and effective realization processes against your set objectives as said in 8.4, then you have to take up corrective actions to detect the root cause and eliminate the detected cause of nonconformity so as to prevent further occurance, as said in 8.5.2. thereby able to meet your set objectives going forward.
Please note that :
Corrective actions shall be appropriate to the effects of the nonconformities encountered
Now to help you further:
If your yield target is 97% and you find 1% visual defects that you take a decision to use "as is" and you find another 1% scrap that you replace with good products, you have data to analyse and see that you are still meeting the target. See what you can do by any means to maintain or improve your performance, but if you happen to get 1% visual defects and 5% scrap than you may have to take up a formal CA/PA to find the root cause of the 5% scrap and then take actions to eliminate.
succinctly: not all nonconformances (product or process) require Corrective action. In many cases correction is sufficient.
Q
QAMTY
Thanks Bev D
So I think that it depends on the NC, ok?
We should define what applies for CAPA.
Doesn´t ISO states is a must
a CAPA after a correction?
THanks
NO it doesn't. Read it again.
try to find where YOU think it says to utilize Corrective Action whenever a correction occurs...
tbsiva
Hello Bev D - Can u tell us an example where you will only do only correction, but no CA/PA??
atitheya
THanks
Answer to this question is in ISO9001:2008 '8.5.2 c) evaluating the need for action to ensure that nonconformities do not recur.'
Take a corrective action, where required, for effectiveness and improvement of your system.
I am in agreement with Mr Somashekhar and will like to add that his post be read adding this clause.
sure: most of our customer "complaints" are simply corrected, either we walk them thru a solution, replace their product or return and repair their product.
Most of our test and inspection failures are simply reworked. Any components removed are placed in MRB ("NCR") for disposition of the part.
We do not issue corrective actions for every nonconformance.
We DO trend and track our complaints, failures, NCR material etc. and we launch improvement projects (Corrective actions) for the highest impact Problems.
ChrissieO
sure: most of our customer "complaints" ar esimply corrected, either we walk them thru a solution, replace their product or return and repair their product.
IMHO you haven't addressed CA only applied the sticking plaster (bandaid). After this has been done you then need to look at route cause and implement your CA.
PA doesn't come into this scenario as something has already gone wrong. PA is applicable when controls/improvements have been identified before the non conformance.
Chrissie
M Root Cause and Corrective Action for CAPA's lacking validation/verification ISO 13485:2016 - Medical Device Quality Management Systems 19
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
B CAPA (Corrective Action) For A Typo? Nonconformance and Corrective Action 18
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
C SCAR (Supplier Corrective Action Request) as part of NC/CAPA? Nonconformance and Corrective Action 3
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
paul van oppen Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R CAPA (Corrective Action Preventive Action) Procedures Separate or Combined Nonconformance and Corrective Action 9
P Complaints & CAPA's (Corrective Action Preventive Action) for Clinical Trials ISO 13485:2016 - Medical Device Quality Management Systems 4
K CAPA (Corrective Action Preventive Action) Training Exercise Training - Internal, External, Online and Distance Learning 2
Q Corrective Action - CAPA - Root Cause - Not following the training procedure! Problem Solving, Root Cause Fault and Failure Analysis 13
Q How to measure CAPA (Corrective Action Preventive Action) System Performance Nonconformance and Corrective Action 20
M Can this Nonconformance have suitable CAPA (Corrective and Preventive Action) Nonconformance and Corrective Action 9
D A true example of CAPA - Accident that show its cause and the corrective action Nonconformance and Corrective Action 8
P When to issue a CAPA (corrective action preventive action)? US Food and Drug Administration (FDA) 11
C CAPA (Corrective Action Preventive Action) example to provide training wanted Nonconformance and Corrective Action 7
V How to create a CAPA (Corrective Action Preventive Action) Database Nonconformance and Corrective Action 3
C High Level CAPA (Corrective Action Preventive Action) SOP Example Needed Nonconformance and Corrective Action 6
kedarg6500 Corrective Action (CA) vs. Preventive (Predictive) Action (CAPA) Preventive Action and Continuous Improvement 18
K NCR Corrective Action vs. Systemic CAPA Nonconformance and Corrective Action 8
M Issue a CAPA if there is a corrective action associated with a complaint? Preventive Action and Continuous Improvement 7
J What should generate a CAPA (corrective action - preventive action) US Food and Drug Administration (FDA) 16
R CAPA (Corrective and Preventive Action) Discussions are Getting Out of Hand Nonconformance and Corrective Action 41
I Example(s) of simple CAPA (Corrective and Preventive Action) forms Nonconformance and Corrective Action 11
S Top level CAPA (Corrective and Preventive Action) procedure ISO 13485:2016 - Medical Device Quality Management Systems 26
J CAPA (corrective action preventive action) Effectiveness - Medical Device Industry Nonconformance and Corrective Action 3
F Chronic Lateness of CAPA (Corrective and Preventive Action) Responses Nonconformance and Corrective Action 25
S Simple CAPA (Corrective Action and Preventive Action) Example for Training? Nonconformance and Corrective Action 8
a_bardi Corrective & Preventive action templates for CAPA in telecom industry Document Control Systems, Procedures, Forms and Templates 2
D Quality Management Book On Capa (Corrective Action Preventive Action) Book, Video, Blog and Web Site Reviews and Recommendations 4
E Audit Program and CAPA (Corrective Action - Preventive Action) Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discussion Preventive Action and Continuous Improvement 177
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 22
M Management Team "Actions" vs. CAPA (Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A To CAPA or not to CAPA? Requirement to close our Corrective Actions before Audit? Nonconformance and Corrective Action 8
