Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab
aufa_fadhli
Hi All,
I am very appreciate if you can help me. I have tried to learn the related article but still don't understand.
I have project to validate blister pack machine. In this case, I have collected 30 samples for each setting parameter (each pack will have 4 location of seal strength to be measured). The spec. only one sided: >0.10 Kgf/15mm. So, the total measurement is 120.
My question is how to perform capability analysis using minitab (especially minitab 17)?
What to do if my measurement (data) is not normal?
for better understanding please find the attachment.
Thank You So Much
Aufa
re: Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab
We would be happy to assist. Can you clarify a few things about your data set?
  1. Sealing Time. Did you deliberately change sealing time as part of an experiment, or are these random variations?
  2. What do you mean by "Shot"? Are the blister packs molded? Are these consecutive shots?
  3. Could you attach a diagram of the positions of the cavities and the locations on each cavity?
It is likely that you have multiple process streams that would have a big impact on how the data are analyzed, so the answers to these questions are important.
aufa_fadhli
Hi Miner,
Thanks for your response,
1. Yes, I deliberately changed the sealing time, to find the optimum seal strength we used "trial and error" method to get the best result. As you saw on my data, we challenge sealing time vs sealing temperature. for the pressure we set to the maximum setting (set as constant parameter).
2. The blister pack are molded one. In one mold, it has 7 cavities. So, in 1 shot (cycle) we will have 7 pack after cut.
3. Please find the attachment for detail of seal strength location and 7 cavities, sorry if I can't give proper image since the machine is not running now.
Thanks in advance
Aufa
This was an extremely detailed data set that can be analyzed a multitude of ways. However, you are interested in the capability analysis. Since you performed a designed experiment in addition to the capability, you will first have to determine which combination of sealing temperature and sealing time is optimum for you (e.g., 140 seal temp and 4.0 seal time).
Focus on the data for this combination. First, you should verify that you do not have distinct process streams with different means. The variation across cavities is similar enough that they may safely be combined. However, there is a significant difference between test location C and the other test locations (A, B & D). A, B & D are similar, but C has a higher mean. There is an opportunity to reduce variation by bringing these means closer together.
Physical test results such as strength are frequently right skewed. You have several options available to you in Minitab 17. You can perform a nonnormal capability analysis using the Largest Extreme Value distribution, or perform a normal capability analysis and using the Box-Cox transformation. Lastly, you can perform a nonparametric capability analysis using the ECAPA macro.
All three approaches will give you a Cpk ~ 1.5 for the 140 seal temp and 4.0 seal time data.
aufa_fadhli
Hi Miner,
Thank a lot for your explanation. According to your explanation you have done some analysis regarding my data. However, I have some questions,
1. You said, "However, there is a significant difference between test location C and the other test locations (A, B & D). A, B & D are similar, but C has a higher mean. There is an opportunity to reduce variation by bringing these means closer together.". what statistical tool you used to say that C has significant different? one way or two way ANOVA?
2. You said, "You can perform a nonnormal capability analysis using the Largest Extreme Value distribution". How you determined to use largest extreme value distribution during capability analysis?. I already know from the normality test my data is non-normal. However, honestly I still don't understand how to choose the correct "fit distribution" on minitab 17. Could you explain to me?
3. Since I have 4 location of seal strength with sample size 30ea. Hence total measurement is 120ea. How to arrange the data in minitab for capability analysis? do I only need to arrange all the data in one row and distinct the data based combination of seal temp. and seal time?
Very appreciate for your assistance:)
Thanks in advance:thanx:
Aufa
  1. I used a 1-way ANOVA with paired comparisons.
  2. I used Stat > Quality Tools > Individual Distribution Identification. You pick the best fits by examining the graphs, and looking for lower Anderson-Darling (AD) statistics. There were a number of reasonable fits. I chose the Largest Extreme Value because it is used to model the distribution of maximum results such as the peak water heights of rivers during floods. A tensile strength is the peak value of a tensile curve, so it will often fit this distribution.
  3. Arrange the measurements in a single column for a given Sealing Temperature/Sealing Time. I recommend that you add another column to indicate the test Location and use that to indicate the subgroups.
aufa_fadhli
Hi Miner,
Thanks a lot for your complete explanation.
I will try to do what you advise to me.:)
Aufa
:thanks:
PQ Systems Control Charts & Capability Analysis 101 Using SQCpack Software 0
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
J Capability Analysis - Unusual Statistical Distribution of my Proccess Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
C P value not greater than 0.05 for Capability Analysis Statistical Analysis Tools, Techniques and SPC 3
M Sample size when conducting capability analysis with OK and NOK parts Statistical Analysis Tools, Techniques and SPC 3
R Capability Analysis (using Histogram) for Subgrouped Data Statistical Analysis Tools, Techniques and SPC 16
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
Q JMP Measurement Capability Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Data Analysis - Johnson Transformation/Weibull Distribution/Capability Analysis Capability, Accuracy and Stability - Processes, Machines, etc. 15
L Capability Analysis - Help with Minitab results Using Minitab Software 15
P Capability Analysis for Limited Resolution (thickness of sheets) Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Capability Analysis and Sample Size Capability, Accuracy and Stability - Processes, Machines, etc. 8
B Capability Analysis of a Repeated Feature Quality Tools, Improvement and Analysis 9
B Capability Analysis of a Small Sample Size (as small as 2 and as large as 30) Statistical Analysis Tools, Techniques and SPC 14
S "Normal" vs. "Between/Within" Capability Analysis Capability, Accuracy and Stability - Processes, Machines, etc. 2
S How to conduct Capability Analysis for this data? Statistical Analysis Tools, Techniques and SPC 12
S Free or Opensource Software that can do Multivariate Capability Analysis Statistical Analysis Tools, Techniques and SPC 8
T Capability Analysis in the Real World Capability, Accuracy and Stability - Processes, Machines, etc. 7
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
I Machine Capability Analysis in Multi-Dimensional Cases Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Capability Analysis of Non-Normal Data Statistical Analysis Tools, Techniques and SPC 23
T Process Capability Analysis Binomial or Normal using Minitab 15 Using Minitab Software 54
P Capability Analysis in Minitab - Subgroup size Misc. Quality Assurance and Business Systems Related Topics 2
J Capability Analysis (Cpk) of torque driver process Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Process Capability Analysis for a Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Regarding: Describing Graphical Overview and Capability Analysis for main dept leader Quality Manager and Management Related Issues 1
M Macro that will perform a normality test and capability analysis - Minitab help Using Minitab Software 1
C Does a Chronically Unstable Process need a Capability Analysis? Statistical Analysis Tools, Techniques and SPC 10
F Multi Capability analysis with MINITAB Using Minitab Software 2
A Whats the rationale for a Sample size of 30 for Capability Analysis? Statistical Analysis Tools, Techniques and SPC 5
D Normal vs. When a Between / Within Capability analysis should be used? Statistical Analysis Tools, Techniques and SPC 12
A Capability Analysis - Dealing with non-normal data in Minitab Using Minitab Software 8
E MSA vs. Measurement Capability Analysis - What are the differences? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 33
J What causes Ppk to be greater than Cpk when a basic capability analysis is run? Capability, Accuracy and Stability - Processes, Machines, etc. 17
A Sample size for Capability Analysis in PPAP APQP and PPAP 2
L Definition Cp Cpk Pp and Ppk Definitions - I'm doing SPC and Capability Analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
T Capability calculation of surface profile Capability, Accuracy and Stability - Processes, Machines, etc. 15
PQ Systems Understanding Capability and Control Charts Series Using SQCpack Software 0
J Process Capability - Determining the process capability of certain equipment Lean in Manufacturing and Service Industries 6
K Initial capability studies on similar parts APQP and PPAP 7
S Capability Study for Leak Tester Capability, Accuracy and Stability - Processes, Machines, etc. 9
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
