Capability Brain Teaser - Which distribution do you expect to see
bobdoering
Stop X-bar/R Madness!!
Attached is a sketch of the cross-section of a connector. There is a dimension identified from the end of the connector to the tip of the terminal.
Brain teaser question: Which distribution (normal, etc.) do you expect to see for the variation associated with this dimension?
There are as many as three manufacturing processes associated with the part: the pin is probably stamped, the connector shell is probably molded plastic, and the process of inserting the pin into the shell (although overmolding is possible). Because of the interplay of the variables associated with these different processes, I would guess at a normal distribution, but I'd need to do some measuring before I was satisfied with the decision.
bobdoering
You came pretty close to nailing the whole answer. The rest of the answer (and probably the most intriguing) falls in the overmolding approach
F
falconer65
My first thought was "A normal distribution?" Assuming three processes. Further assumptions being the pin process has a normal distribution, the molding process has a normal distribution, and the assembly process has a normal distribution. Thus the variation of three processes is combined the dimension has a normal distribution? That is possible, though I would not be surprised to see a tri-modal bell curve.
Second thought was assume the assembly of the insertion of the pin and the molded part had stops. Each part may have normal distributions, but are irrelevant to the assembly process. They hit against their stops and the distribution would be non-normal, along the lines of a one sided bell curve.
Overmolding: assuming the pin hits a stop and has a half-curve, and the plastic has a normal distribution for shrinkage, then an overlay of the two distributions.
I prefer the EDA method, not classical, so in the end I would let the raw data show me.
Nice teaser.:applause:
:2cents:
Erik Sikora
bobdoering
These are very good thoughts - and the thought process is what I use as a basis of developing the of the total variance equation. You might have a tri-modal distribution (which would no longer be normal) if all of the effects were of the same magnitude. Most likely the overwhelming variation will be the size of the hole in the terminal stamping that the molded tab drops into - and the ending location after the locking tab holds the assembly in place. Most likely distribution will be normal or possibly a "U" distribution if it ends up being truncated. Now you can look at the data and see if it supports the expected results.
Very close, you are correct in that the locating stops for the terminals in the mold create a physical limit, and all of the variation will lie from that point out. However, it would not be technically a "half curve", but there will be non-normal distributions that will "best fit" the resulting data, such as beta distribution, etc. Use of a best fit distribution analysis would be a good tool for this process. Adding the plastic shrinkage, etc. are very good factors to add to the total variance equation for this process, but you will likely find the size of that effect will be much smaller that the location of the terminals in the mold prior to molding. Again, it is always an estimate until evaluated on a case by case analysis.
The data should support a theory, not be the theory.
Bottom line of this brain teaser is this - just because you have a dimension that is bilateral, does not mean the distribution you should expect is "normal". You need to find out what the process is that generates the variation. Here, there are at least two possible processes, with very different distributions. Also, it shows that rubber stamping "Cpks" on a print is equally a rudimentary use of statistics. There is no way looking at the print if Cpk is going to be statistically correct. In this case, for the overmolded approach, it holds no value.
Good work, Jim and Erik!
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
J Are Capability Requirement(s) Valid for All Characteristics? Capability, Accuracy and Stability - Processes, Machines, etc. 6
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
J Powdercoating Capability Employing a Robotic Arm Manufacturing and Related Processes 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Capability for Correlated Charteristics Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
bobdoering Unilateral Tolerance Capability Calculations Capability, Accuracy and Stability - Processes, Machines, etc. 1
bobdoering Unilateral Tolerance Capability Calculation Imported Legacy Blogs 0
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
