Capability - CPk comparison values
Hi All,
I'm looking for a way to calculate what the comparable CP numbers are for various levels of a sample size.
If my target at 30 samples for example is a CP of 1.33 but I can't obtain the 30 samples and can only obtain 15 or even 20. How would I work out what the equivalent CP figure would be? Obviously I know it would need to be higher given the lower sample size but I don't know how to work it out.
Could any of you help with this please?
thanks in advance
Welcome to the Cove. :bigwave: In short, there is no rational way to do what you're trying to do. In your thread title you refer to Cpk, then you refer to Cp in your question. They're two different but related values. I don't know what industry you're in or what requirements you might be trying to satisfy, so if you could give us more information it would help to give a better answer.
i would add these thoughts:
- smaller sample sizes can result in larger estimates of the standard deviation which would make the Cpk number smaller. You can use a random number generator and sample at different sample sizes to see what happens.
- There is no target Cpk or Cp value for a sample size. (If I’ve interpreted your question correctly?). Such a target would have zero value.
- really small sample sizes are simply NOT appropriate for Cpk/Cp calculations. Stop doing that. It’s just playing with math. A Cpk/Cp calcautlion with 30 samples is pretty silly too.
- of course the whole idea of Cpk/Cp is silly. You’ll learn a lot more about your process capability by plotting your data on a multi-varo chart, then a control chart.
Thanks Jim,
I've browsed for a while and found this to be a really useful site.
Basically I'm looking to buy off a process and we have been given a target of 1.33 for short term capability apologies on my above thread for putting both CP and cpk that is my mistake.
The exam question really is.
If I can't afford to have the min 30 parts which we currently use. And can only have say 20
What would my equivalent capability value be.
Now I do understand this is diminishing returns and that ideally I want 100+ samples to review capability however in a buy off situation this just isn't possible without extension of the programme timelines.
I've racked my brain for a while on how to come up with and solve this and just ran out of ideas really and thought someone else might already do it or have a solution
I agree on the small sample sizes and in using the cp/cpk at all as it is but a snapshot in time. In a buy off situation where we need to be in install and then leave for the next programme.
It was worth a punt if anyone did know of an answer.
Thanks for your response
toniriazor
What is your customer requirement for the sample size ? With such small sample size you won't be able to demonstrate long term process capability and why you cannot produce more sample sizes to complete the study ? No orders from customer or other limitations?
Bill Levinson
Industrial Statistician and Trainer
Cp and Cpk are based on short-term estimates of the process standard deviation, which you could get from the average moving range of 15 or 20 parts, or alternatively, let's say, the ranges of 5 samples of 4 if you have a rational subgroup of 4. The problem is that the confidence interval would be very wide, and probably too wide to be meaningful. This is why people always want 30 or more parts (preferably 100 or more).
You can also get Pp and Ppk from the standard deviation of all the parts, and do a normal probability plot to assess the normality assumption, but you will still have the same problem with the confidence limits.
Steve Prevette
Deming Disciple
I suggest that Cpk is really not a good tool in the first place, and serves little purpose in terms of random sampling. I would recommend considering:
1. Setting up an acceptance sampling plan using MIL STD 105 follow on methods.
2. If this is basically the same item being made in sequential lots, run SPC monitoring across batches which will build up a larger sample size and you will be able to see variations from lot to lot.
A point being is use the data you are willing to pay for, in the best manner possible.
msbettyhunt
Thanks Jim,
Exactly, this is the tough one to solve for me.
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 4
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
L Cpk after Data Transformation - How to Transform LCL /UCL to get Capability Report Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Capability Analysis (Cpk) of torque driver process Capability, Accuracy and Stability - Processes, Machines, etc. 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
C Composite Process Capability Index - Cpk is not additive Capability, Accuracy and Stability - Processes, Machines, etc. 3
B Difference between Ppk (Preliminary), Cpk, Performance Capability Statistical Analysis Tools, Techniques and SPC 2
Tim Folkerts Interpreting the common capability indices: Cp, Cpk, Pk, and Ppk. The Reading Room 5
T Calcuating a one sided (LSL) Cpk for Proccess Capability Capability, Accuracy and Stability - Processes, Machines, etc. 17
Z Low Process Capability - Cpk - Man-made part - What to do? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Capability Indexes for ISO/TS16949 - Cpk & Ppk after PPAP Statistical Analysis Tools, Techniques and SPC 6
B Cpk for 3D data - Capability study from CMM data- Need Help Capability, Accuracy and Stability - Processes, Machines, etc. 1
Marc Definition Process Capability (Cp and Cpk) - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
B Attribute capability indices - Cpk and/or Ppk value for an attribute type of feature Capability, Accuracy and Stability - Processes, Machines, etc. 7
N Capability study - What Values do I have to input to calculate Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 9
Tim Folkerts Is Cpk a good measure of capability? There are several shortcomings of Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 31
A How to measure Process Capability ( Cp and Cpk) Statistical Analysis Tools, Techniques and SPC 3
D Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability Capability, Accuracy and Stability - Processes, Machines, etc. 29
S Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Capability: Short Term or Long Term? Cpk= Long term and Ppk= Short term? Capability, Accuracy and Stability - Processes, Machines, etc. 18
J What causes Ppk to be greater than Cpk when a basic capability analysis is run? Capability, Accuracy and Stability - Processes, Machines, etc. 17
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
L Definition Cp Cpk Pp and Ppk Definitions - I'm doing SPC and Capability Analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
B Any ideas on setting up Capability Study spreadsheet in Excel? (CPK/CMK formulae) Excel .xls Spreadsheet Templates and Tools 4
D On-going capability - Can we decide for ourselves how often to measure cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Ppk or Cpk - Preliminary Process Capability vs. Process Performance Capability, Accuracy and Stability - Processes, Machines, etc. 16
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
