Capability - CPk comparison values
Welshwizard
#12
Another angle on your dilemma.
By asking for a Cp your customer by implication wants you to demonstrate that you have "elbow room" such that the natural limits of your process fit inside the tolerance width.
You know and hopefully your customer does too that in order to state your Cp your process has to be stable....in statistical control. You also know that if it's not stable at least with the data you have you can't say the past (as for all data analysis) can be extrapolated into the future and therefore the question of Cp will be moot.
So, if your process is in statistical control, preferably using as many samples as you can get you're hands on you can state an interim Cp in the knowledge that it will solidify and even get better in the future as long as the process remains stable. Of course you would have to agree this with your customer but it's better than stating a Cp where the underlying data is not stable and no one is making any effort to fix the issue, that's just hypothetical.
Cheers
Mike S.
Happy to be Alive
#13
Once you reach 10 data points, consider creating an I-MR control chart. I can't find the reference at this moment, but I recall reading you can start to calculate reasonable limits once you get to 10 data points. See if your resulting control limits are within the spec limits. It would seem more valuable to me than Cpk. JMO.
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
L Cpk after Data Transformation - How to Transform LCL /UCL to get Capability Report Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
J Heat treatment inspection and Process capability index Cpk Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Capability Analysis (Cpk) of torque driver process Capability, Accuracy and Stability - Processes, Machines, etc. 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
C Composite Process Capability Index - Cpk is not additive Capability, Accuracy and Stability - Processes, Machines, etc. 3
B Difference between Ppk (Preliminary), Cpk, Performance Capability Statistical Analysis Tools, Techniques and SPC 2
Tim Folkerts Interpreting the common capability indices: Cp, Cpk, Pk, and Ppk. The Reading Room 5
T Calcuating a one sided (LSL) Cpk for Proccess Capability Capability, Accuracy and Stability - Processes, Machines, etc. 17
Z Low Process Capability - Cpk - Man-made part - What to do? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Capability Indexes for ISO/TS16949 - Cpk & Ppk after PPAP Statistical Analysis Tools, Techniques and SPC 6
B Cpk for 3D data - Capability study from CMM data- Need Help Capability, Accuracy and Stability - Processes, Machines, etc. 1
Marc Definition Process Capability (Cp and Cpk) - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
B Attribute capability indices - Cpk and/or Ppk value for an attribute type of feature Capability, Accuracy and Stability - Processes, Machines, etc. 7
N Capability study - What Values do I have to input to calculate Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 9
Tim Folkerts Is Cpk a good measure of capability? There are several shortcomings of Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 31
A How to measure Process Capability ( Cp and Cpk) Statistical Analysis Tools, Techniques and SPC 3
D Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability Capability, Accuracy and Stability - Processes, Machines, etc. 29
S Cmk and Cpk - When will we need to calculate Cmk? Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Capability: Short Term or Long Term? Cpk= Long term and Ppk= Short term? Capability, Accuracy and Stability - Processes, Machines, etc. 18
J What causes Ppk to be greater than Cpk when a basic capability analysis is run? Capability, Accuracy and Stability - Processes, Machines, etc. 17
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
L Definition Cp Cpk Pp and Ppk Definitions - I'm doing SPC and Capability Analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
B Any ideas on setting up Capability Study spreadsheet in Excel? (CPK/CMK formulae) Excel .xls Spreadsheet Templates and Tools 4
D On-going capability - Can we decide for ourselves how often to measure cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Ppk or Cpk - Preliminary Process Capability vs. Process Performance Capability, Accuracy and Stability - Processes, Machines, etc. 16
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 10
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
