Capability for a Injection Mold Machine (35 Cavities)
Bill McNeese
#12
Attached are two workbooks. One shows the individuals chart for cavity 1. You can easily see the presence of chunky data in the range chart - two few values. Your measurement process appears to be masking the process variation. You probably need to start with how you do the measurement.
The second workbook contains the Cpk chart for Cavity 1 based on specs 2 to. Doesn't mean much until you fix the measurement process.
F
FAndrade
#13
Thanks Bill. I now took the raw data of the measure system (Volume from Weight and Density using a software. Is the most exact system). You can find it attached on this post. On this measurement, no parameters were changed.
As I can see, the overall process capacity can be measured from 1 cavity? Is that correct having on mind that cavity 1 is obviously different from cavity 2?
Thanks in advance.
Bill McNeese
#16
When I run the numbers in Minitab, I get the results I had before. What subgroup size are you using for the capability analysis? I used n = 1 for an individuals chart. You will have values for Cp, etc. You did not have any vales for Cp, etc., just Pp, etc.
F
FAndrade
#17
Using n=1 in minitab, I get the same results ;)
I need to proove that my machina is capable to fill plastic ampoules on using this specs min = 2mL max = 2.9mL
What is the best result to represent what I need to show? cpk? ppk? No parameters were changed during the data aquisition.
Thanks in advance.
EDIT: I got this cavities with ppk <1,33 but cpk > 1.33
#18
Ppk (using the total variation directly calculated from all of the data) is the estimator you should use. It reflects actual performance capability
Cpk (using within subgroup variation as to estimate the total variation) is only useful as rough estimate of the 'potential' better variation if you were to eliminate the subgroup to subgroup variation....it estimates potential capability.
...of course the caveat is that you took a random sample that represents the full range of variation that the process is expected to experience...
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Machine Capability (Cm) for Plastic Injection Molding Capability, Accuracy and Stability - Processes, Machines, etc. 1
B Injection Molding Capability Studies for PPAP Submission Capability, Accuracy and Stability - Processes, Machines, etc. 19
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
J Are Capability Requirement(s) Valid for All Characteristics? Capability, Accuracy and Stability - Processes, Machines, etc. 6
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
J Powdercoating Capability Employing a Robotic Arm Manufacturing and Related Processes 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Capability for Correlated Charteristics Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
bobdoering Unilateral Tolerance Capability Calculations Capability, Accuracy and Stability - Processes, Machines, etc. 1
