Capability & GDT Features - Surface Profiles, Line Profiles & Symmetries
P
Peter A
Ok, I have read a few threads on the forumn but feel I need my own thread.
We have been asked to measure Surface Profiles, Line profiles & symmetries on injection moulded components. All have a unilateral tolerance ie 0-0.1mm.
How do we correctly upply capability to these? Currently we are using MiniTab to calculate a PPU value, only having an upper boundry. Our customer has queried this thinking we should be using 0 +/-0.05mm.
Any views on this?
Stijloor
Any views on this?
Welcome to The Cove Forums! :bigwave: :bigwave:
Do you have a sketch that shows the actual callouts? The default for profile of a line and profile of a surface is that the tolerance zone is equally disposed about the true profile. But without an actual drawing, I can not tell.
bobdoering
Stop X-bar/R Madness!!
It would be nice to see some data, but my guess is your process variation distribution is a beta or Weibull distribution, non-normal - unless you are very far away from 0. Using Ppu alone is incorrect. It has a totally different meaning than Ppk. You most likely will need to transform the data to get an accurate understanding of your capability with "centering" - Ppk.
Paul F. Jackson
Profile is a tolerance with max and min boundaries that the surface must reside within. Those boundaries may be oriented and/or located to datum references or free to float.
No matter whether the limits are specified equal bilateral, unequal bilateral, or unilateral relative to the basic they can be treated as equal bilateral by figuring the offset for contour boundaries that have a specified basic displacement from datum references.
Since profile specifications may often be used to control non-generic forms... each measured point can be examined for its variability within the bilateral zone to an offset target mean (if necessary).
When a profile tolerance is applied to co-planar (or other) surfaces without datum references... then it is treated similar to flatness where one boundary "ZERO" is only approachable but never attainable... whether the surface is curved, flat, or other... as long as there are no opposed surfaces in the contour tolerance zone (eliciting a size situation) this would be a "one-sided" tolerance (zero to max).
If the profile zone is linked to a datum reference with a basic or is not linked with a basic but the contour wraps around any contour where there are opposed points it then it is not a "one-sided" tolerance.
Paul
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
J Are Capability Requirement(s) Valid for All Characteristics? Capability, Accuracy and Stability - Processes, Machines, etc. 6
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
J Powdercoating Capability Employing a Robotic Arm Manufacturing and Related Processes 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Capability for Correlated Charteristics Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
bobdoering Unilateral Tolerance Capability Calculations Capability, Accuracy and Stability - Processes, Machines, etc. 1
bobdoering Unilateral Tolerance Capability Calculation Imported Legacy Blogs 0
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
