Capability of new CNC machines
bobdoering
Stop X-bar/R Madness!!
It has come to my attention that there are people out there purchasing CNC machines with contractual requirements for the machine to meet a Cpk prior to payment. Apparently, this is occurring in automotive circles (big surprise.) What an abject travesty of statistics. What is interesting is that in order to meet this incorrect application of statistics, the focus shifts immediately away from tool wear (the actual underlying process) and directly onto the algorithm for auto-compensation. It becomes the process...just like any over-controlling individual would be if they constantly adjusted their process to the target value. So, as the main source of variation, does anyone really understand their auto-compensation algorithm? Do you think you should??
True Position
Why would specifying purchasing machines capable of a target CpK and auto-compensation algorithms be related?
Kales Veggie
People: The Vital Few
Let me be the devils advocate here:
I am an automotive supplier, I spend 500,000 dollar on a CNC machine. I want this machine to produce some selected characteristics of my parts without scrap under normal operating conditions. So, a CpK of 1.67 or 2.0
I do not care what kind of algorithm the manufacturer uses inside that machine to control the slides, the angles, the tool wear. It is their job to design the machine and control the process.
So, what is wrong with my thinking?
bobdoering
Because the auto-compensation will mask the underlying continuous uniform distribution of tool wear with its own distribution from overcontrol. Essentially it becomes the process. So, in the total variance equation, and a CNX analysis, it will overwhelm any other cause of variation. As the major variation, it will be the one that generates the resulting capability. The point is, as the major influence on capability, it should be the variation you understand the best. But....does anyone understand their auto-compensation algorithm? Is is correct, or "close enough"? How does it react to special causes, such as start-up warm-up? Should you be comfortable treating you major cause of variation as "black box"?
bobdoering
If you were doing true precision machining, the only variation would be tool wear. It is a continuous uniform distribution - and is non-normal. Even AIAG states that Cpk is not appropriate for a non-normal distribution in its 4th edition PPAP manual:
2.2.11.5 Processes with One-Sided Specifications or Non-Normal Distributions
NOTE: The above mentioned acceptance criteria (2.2.11.3) assume normality and a two-sided specification (target in the center).
So, essentially you are forcing your supplier to meet a statistically incorrect index for what your really would want to see. Why would you want to do that when you are spending 500,000 dollars? What do you think that is going to force them to do? Why would both you are your supplier not understand the variations in the process if you are spending that kind of money? And, once you own it, how are you going to make decisions on tool change and maintenance when you still don't understand the underlying variation?
Does any of that make you actually feel comfortable using Cpk? I agree you need to understand capability, but a single number calculated using the wrong statistics seems awfully weak for a 500,000 dollar investment. Building a machine to meet that requirement seems even less like a good idea.
True Position
If the process is stable and capable of machining the features in question but not 'true precision machining' I don't think anybody really cares. The goal is in specification parts 100% at the lowest cost. Purity of technique isn't something worth spending money on.
W
WKHANNA
But what happens when production is not 100% in spec?
How do you determine root cause if you can not determine the true tool wear?
True Position
Even with an automatically adjusting machine you can determine your tool wear with the cycle counter. If you can turn off the adjusting as well you could perform a study just like you would on a traditional machine.
W
WKHANNA
I see.
Thanks, I am just trying to get a grasp of this.
bobdoering
Kind of missing the point of understanding the most significant cause of variation, and its impact on the output - as well as ignoring the underlying variation which had been the only cause of variation until an artificial on was implemented to mask it.
Even with an automatically adjusting machine you can determine your tool wear with the cycle counter. .
A cycle counter does not control nor determine tool wear - it tells you when to change it based on a guess - not on ongoing, real data as you would with the X hi/lo-R chart.
If you can turn off the adjusting as well you could perform a study just like you would on a traditional machine. .
Actually, that would be a good start on determining how much variation the auto-compensation is generating as its participation in the total variance equation.
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
N Lot Capability - Forging -> CNC Machining -> Heat treatment -> Packaging Statistical Analysis Tools, Techniques and SPC 3
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Machine Tool Calibration - Machine Capability Studies on CNC Machine Tools Manufacturing and Related Processes 5
M Volumetric Positioning - Machine capability studies for CNC machine tools General Measurement Device and Calibration Topics 4
A How to perform a capability study from 48 pcs? CNC Lathe and Sample Size Statistical Analysis Tools, Techniques and SPC 7
B CNC test pieces for milling and turning - I need to run a process capability study General Measurement Device and Calibration Topics 2
D Machine Capability Studies on CNC Lathes Statistical Analysis Tools, Techniques and SPC 35
S Precontrol and Process Capability - CNC Lathes that run small batches - Short Runs Statistical Analysis Tools, Techniques and SPC 12
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
J Initial capability for injection molding part Capability, Accuracy and Stability - Processes, Machines, etc. 6
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
J Are Capability Requirement(s) Valid for All Characteristics? Capability, Accuracy and Stability - Processes, Machines, etc. 6
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
M CAAC-145 Manuals - Looking for examples of MOM's, MMM's Capability Lists, etc. Federal Aviation Administration (FAA) Standards and Requirements 13
J Powdercoating Capability Employing a Robotic Arm Manufacturing and Related Processes 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
V Capability for Correlated Charteristics Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
