Capability Studies and Monitoring Runs at a Metal Stamping Facility
H
haueyman
I have recently moved to another company as a quality engineer and what I came from was checking parts on the CMM on a constant frequency to monitor the capability of our parts. I must mention that this was a CNC machining facility. Now I am at a stamping facility that rarely uses their CMM for production use only annual PPAP's or some problem solving issues.
Does anyone have experience with stamping facilities and what they have done in the past to monitor your quality of the parts from run to run whether it is with the CMM or gages.
Chris Ely
Re: Capability studies for a Stamping Facility, is it good to
Good question. I work in a stamping facility as well. We use our CMM for initial PPAP and also for an annual dimensionals of product. We also use it when a change to the part or process has occurred. The significance of the change that would require new capability studies on the CMM is determined by the QA Mgr., Production Mgr. and Process Eng
For normal production (high volume) we use gauges to check the critical aspects of the product at a rate determined by the Cp/CpK in our intial prove-out runs.
Hope this helps.
H
haueyman
I guess my question is should we be running more parts on the CMM to help with statistically looking for trends and that sort of thing.
David DeLong
Stampings are a bit different than products made in a CNC machining company.
Hard tooling created characteristics (cut during the blanking operation) do not change significantly during the run and performing ongoing statistical studies on a shape or dimension isn't that practical.
Critical dimensions (significant) shown in the Control Plan that are created during the drawing operations can vary and should be monitored. An X bar and R chart (maybe individuals and moving range chart) could be used. There are limited uses for ongoing stats though in stamping operations.
You will find attribute characteristics such as short blank, crack and burrs are more prevalent in this environment. One would also find that holes patterns are frequently checked with a checking fixtures in this type of operation.
Hope this helps.
H
haueyman
Re: Capability Studies and Monitoring Runs at a Stamping Facility
So then my primary objective must be to verify that my gages are correct, is that a safe assumption?
If there are any other things that might be helpful I would appreciate.
David DeLong
Yes, make sure that the gauges are correct especially the ones for positional tolerances. Do not assume that Gage Makers know GD&T. What gages tolerances were used and how was it applied. Can an attribute gauge accept a nonconforming product?
I would also go over the Control Plan. Are the characteristics confirmed at the correct process step? Are the confirmation methods correct? Have the correct gages been allotted?
Of course, are people doing what they are supposed to do?
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
B For a measuring instrument, should MSA be done first or the Capability studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Excel 2003 and Capability Studies for Dummies - Help needed! Excel .xls Spreadsheet Templates and Tools 4
L Capability studies on machine types - Supplier has over 1000 machines Quality Manager and Management Related Issues 7
M Capability Studies in Engineer to Order Small Batches Capability, Accuracy and Stability - Processes, Machines, etc. 5
S Specification Limits and Capability Studies in Minitab Statistical Analysis Tools, Techniques and SPC 9
A Capability Studies for Profile (GD&T Callout) Capability, Accuracy and Stability - Processes, Machines, etc. 6
O Capability Studies: Can I combine Attribute Data and Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Injection Molding Capability Studies for PPAP Submission Capability, Accuracy and Stability - Processes, Machines, etc. 19
Chennaiite Interpretation of Short term vs. Long term Capability Studies Statistical Analysis Tools, Techniques and SPC 3
M Machine Tool Calibration - Machine Capability Studies on CNC Machine Tools Manufacturing and Related Processes 5
M Volumetric Positioning - Machine capability studies for CNC machine tools General Measurement Device and Calibration Topics 4
I Reason for pre-production machine/process capability studies / SPC during production Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Differences between Machine Capability and Product Capability studies Capability, Accuracy and Stability - Processes, Machines, etc. 9
F Capability studies in Process Plants - E-coat of galvanized flat carbon steel coils Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Safety Characteristics & capability studies Statistical Analysis Tools, Techniques and SPC 3
D Machine Capability Studies on CNC Lathes Statistical Analysis Tools, Techniques and SPC 35
D Machine Capability Studies: How many parts needed? Statistical Analysis Tools, Techniques and SPC 11
J Capability Studies - Do I need to use subgroups? Statistical Analysis Tools, Techniques and SPC 1
J Multi-Cavity Capability Studies Statistical Analysis Tools, Techniques and SPC 1
D Capability Studies - 5 different dimensions - How many parts? Statistical Analysis Tools, Techniques and SPC 6
D Capability studies with less than 125 individual samples. Statistical Analysis Tools, Techniques and SPC 12
I Capability Studies - Fewest Number of Parts for a Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Capability Studies - Combining parts from two lots Statistical Analysis Tools, Techniques and SPC 17
Marc PPAP Preliminary Capability Studies - Batches - Paint Company APQP and PPAP 3
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Pre-Production Capability Assesment Reliability Analysis - Predictions, Testing and Standards 5
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
