Capability Study => Check %Study Variance and NDC?
Black arrow
Hello!
Our primary target is to achieve the acceptance limit of % Tolerance while we are using our measuring equipments for product control situations.
We are also using the m.equipment for cap.studies but i dont think we are using SPC. Here come my question?
Do we also have to analyse % Study Var and Ndc from the MSA result and acieve the acceptance limits for those parameters also?
Thanks in advance!
Re: Capability study => check %Study Var and Ndc?
% Tolerance should be used for inspection devices.
%Study Variation (or preferably % Process Variation) and ndc should be used for the following situations:
  • SPC
  • Capability studies
  • Any statistical studies such as hypothesis tests, DOEs, etc.
Black arrow
Interesting, so that means that we have to also has to focus on % Study Var & Ndc.
What we can see from result from MSA for a measuring equipment is that we do not achieve acceptance limits on those parameters. So this means that we have to invest in another measuring equipment if we should go on we our cap. studies. But i have to say that % Tolerance is acceptable. How do we priority this, achieve % Tolerance or % Study Var /Ndc? Any experience of that?
Black arrow
Perhaps i rephrase my question
We use a m.equipment for product control and process control and lets say that we have following result:
% Tolerance acceptable, % Study var: 36 % and ndc : 2. We can not improve the result more. How do we proceed from here?
We can still use it for product control e.i. secure that no parts is out of tolerance limits. We can not use m.equipment for cap.studies so we can not control our process.
I see only two alterantives: new m.equipment or measure every parts .e.i. 100 % (frequency)
Am i wrong in my conclusions?
New equipment is definitely one option. Another option that is not highly desirable, but does work is to take the average of multiple measurements as a single measurement.
The standard deviation of a group of averages = the standard deviation of the individual measurements divided by the square root of the sample size. Therefore, if you take the average of 4 measurements as a single measurement, you will cut your measurement variation in half. This is not a great alternative, but I have been forced to use it for short term studies on occasion.
Black arrow
So concerning process control i.e cap.studies, you mean that in cap. studies we take the average of multiple measurements as single measurement? As you wrote this could be a temporary solution but it is quite time consuming to do cap. Studies then. 50 measuremtns will results in 200 is that correct? In this example , how will this influence our cap.study? Is there any formula we can use to show other colleagues that if we go on with our cap.studies but instead of 50 measurements we do 200 that will in theory improve the cap.index?
Your understanding is correct, but I was only suggesting it for SPC purposes. The impact on the results of a capability study would be real, but relatively small.
Black arrow
But with a % Study Var of 36 % it will have an impact on our cap.studies and if we keep on doing cap.studies the result will not be realistic. So from cap.study point of view, we should immediately stop doing them? Focus on new equipment instead? Or can we go around the problem?
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
ncwalker Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
S What is Cc? Capability Study on Key Critical Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 9
L Capability Study for a Honing Machine Statistical Analysis Tools, Techniques and SPC 3
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
C Subgroup Size in Minitab for Capability Study Statistical Analysis Tools, Techniques and SPC 4
O One Cavity Mold Prototype Capability Study and PPAP Approval APQP and PPAP 1
G How to calculate Subgroup Size for Machine Capability Study Statistical Analysis Tools, Techniques and SPC 4
V How to calculate Machine Capability Study using Minitab Using Minitab Software 4
V JCI standard numbers of pieces required for Capability Study? APQP and PPAP 2
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
P Capability Study for a Specific Thickness of Rubber Sheeting Capability, Accuracy and Stability - Processes, Machines, etc. 6
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
M Capability Study on a New Machining Process - Issues Capability, Accuracy and Stability - Processes, Machines, etc. 40
S Does anyone know what is involved in a HiPot capability study? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Machine GR&R (Gage R&R) - Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
Barahir Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Capability Study on Extruded Alumin(i)um - How would one define a "batch"? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Capability Study Template Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
sridharafep Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
K Format for presenting capability study results? Statistical Analysis Tools, Techniques and SPC 7
Manix Initial Capability study on N50 parts - Subgroup Size? Statistical Analysis Tools, Techniques and SPC 5
