Capability Study for Tapped Hole
I have a PPAP I'm working to get approval on. The part has a HIC on an M6 tapped hole. They are requesting a Capability study on the Tapped hole. I'm not really sure how to do this. Any suggestions? We ran a 300 pc run with no rejections for the tap.
bobdoering
Stop X-bar/R Madness!!
I would provide an attribute capability study.....which you already have the results for. (Minitab: binomial % defective)
You can use the exact binomial or exact poisson to calculate the upper confidence limit for zero defects... the standard formulas are use the Normal approximation and require that you have a moderate defect rate to be useful - or even to complete the calculation. I am away from work right now so I don’t have the formula at my finger tips. But there is an excel approach to calculating this - a simple google search should find it.
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
S What is Cc? Capability Study on Key Critical Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 9
L Capability Study for a Honing Machine Statistical Analysis Tools, Techniques and SPC 3
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
C Subgroup Size in Minitab for Capability Study Statistical Analysis Tools, Techniques and SPC 4
O One Cavity Mold Prototype Capability Study and PPAP Approval APQP and PPAP 1
G How to calculate Subgroup Size for Machine Capability Study Statistical Analysis Tools, Techniques and SPC 4
V How to calculate Machine Capability Study using Minitab Using Minitab Software 4
V JCI standard numbers of pieces required for Capability Study? APQP and PPAP 2
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
P Capability Study for a Specific Thickness of Rubber Sheeting Capability, Accuracy and Stability - Processes, Machines, etc. 6
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
M Capability Study on a New Machining Process - Issues Capability, Accuracy and Stability - Processes, Machines, etc. 40
S Does anyone know what is involved in a HiPot capability study? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
T Machine GR&R (Gage R&R) - Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Capability Study on Extruded Alumin(i)um - How would one define a "batch"? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Capability Study Template Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
K Format for presenting capability study results? Statistical Analysis Tools, Techniques and SPC 7
