Capability Study on a New Machining Process - Issues
mayor
All,
I am doing a capability study on a new machining process and have run into some issues. I'll start with a little background info:
- the process is thinning plastic sheets (19"x19") to a targeted thickness = 0.035"
- we take thickness measurements at each corner and halfway between the corners, resulting in 8 measurements per sheet.
- when subgrouping, I use a subgroup size of 8 because this would represent one sheet. Is this OK?
- I have data on 43 sheets.
- Issue one: controll chart (X-bar) indicates the process is out of control.
- Issue two: non-normal distribution.
- I am using Minitab for analysis.
I plan to investigate the process further to see what is causing the issues mentioned but I did run Cpk just to see what I would get. I was surprised that it was ~1.5. I don't think a process can be out of control and be capible at the same time, correct? Am I going about the capibility study the right way? Should I be doing something different?
Thanks.
bobdoering
Stop X-bar/R Madness!!
Re: Capability Study - Issues
All,
Thanks.
Might want to share the data - hopefully point 1 is the same point on all data sets, etc., for accurate analysis.
For normal distribution calculations, and X-bar-R charts - there is not relation between capability and control.
If it is non-normal, what distribution does it fit?
mayor
All points are the same for each sheet. Example: upper left corner always location 1, upper right always location 3, etc...
I'm not sure what type of distribution I have. I looked at transforming the data using Box-Cox and got a lambda value of -5. I was not sure about this approach given the non-normal dist and being out of control. I have looked at the data and it does look like I have an issue with my sheet holding vacuum table. I noticed that location 1 is always low and location 4 is always high. I have attached the data.
bobdoering
Thank you. I am sure several people will offer to look at the data and respond - but it may take a little time.
One suggestion right off the bat is to do run charts on each location individually and see what capability you have.
yes you can be "capable" and out of control. Purists will say that fi you are not in statistical control then you are not stable adn tehrefore not predictable. but in most of these cases there are underlying subgrouping issues and/or systemic yet cycles or trends which can resutl in 'out of control' conditions yet you still have a stable and capable process.
One question: what formula did you use for Cpk?
I plotted your data on an XBar R chart and a Multi-vari. You do have some systematic differences in thickness based on position. notably position 1 is almost always the thinnest, 4& 6 the thickest. SOyou dont' have a random distribution within the sheet or the subgroup. within sheet is your largest component of variation...the difficulty with this from a 'vanilla' control chart standpoint is that the within sheet variation is not driven by the same source as the between sheet variation: for vanilla control charts, the within subgroup variation msut have the same basic sources as the between. (this is a rough way of stating it...)
What we can say is that you definitley had changes in the within sheet variation and at a different time ahd shifts in the sheet to sheet variation.
I have attached my first pass analysis
mayor
I see the same thing and have indicated our vacuum table with results that match the data. Looks like I will be flattening the table. I use Minitab, so the Cpk formula used is min(CPU,CPL), which uses the within sigma. Spec limit is +/-0.0005".
I also looked at the control chart (I-MR) for each location and they are out of control as well, so there is variation sheet to sheet, but I agree that within is larger.
So is it correct to say that the process is currently not capable? Hopefully after correcting the table flatness the process will be improved and be capable.
Thanks for the feed back.
janedoe
I am not able to open the data file, but you are describing several (nearly) normal distributions collected on one chart. I don't doubt your 'out of control' conclusion, but I suggest you look at the data vales (from each location) independently; test for normality at each location. You may have 8 locations...each one stable...but as a group...they look out of control and possible one (or more) locations is, indeed, out of control; unstable.
Whit a subgroup size of 8, I would expect the data to be normal. (That's the beauty of th XR chart....individuals data from a non-normal distribution will have averages that are normal).
brahmaiah
All,
Thanks.
Your sub-grouping method is wrong.Firstly all eight measurements of one sheet should fall within the range of half the tolerance for thickness.You should take the mean of eight readings as the size of the plate measured.Thus the mean size is one sample. you have to take a minimum of 3 sheets as one group of samples for Cpk calculations.About 15 to 25 groups of such measurements make one set of readings suitable for Cpk calculation.More groups give more accurate estimate of Cpk value.One important note is you cannot calculate Cpk with out-of-control plots.you may delete out of control points from calculations if only one or two such readings are found.But the right thing to do when you see out of control points is to investigate the causes and eliminate those causes immediately.You can calculate Cpk only after eliminating assignable causes of out of control points.
If you are getting your Cpk as 1.5 inspite of out of control points it is unusual.Investigate causes.
Remember the main purpose of SPC is not a postmatem of calculting Cpk.Its purpose is to eliminate assignable(special) causes as and when you encounter them during the production operation.
V.J.Brahmaiah.
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
S What is Cc? Capability Study on Key Critical Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 9
L Capability Study for a Honing Machine Statistical Analysis Tools, Techniques and SPC 3
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
C Subgroup Size in Minitab for Capability Study Statistical Analysis Tools, Techniques and SPC 4
O One Cavity Mold Prototype Capability Study and PPAP Approval APQP and PPAP 1
G How to calculate Subgroup Size for Machine Capability Study Statistical Analysis Tools, Techniques and SPC 4
V How to calculate Machine Capability Study using Minitab Using Minitab Software 4
V JCI standard numbers of pieces required for Capability Study? APQP and PPAP 2
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
P Capability Study for a Specific Thickness of Rubber Sheeting Capability, Accuracy and Stability - Processes, Machines, etc. 6
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
S Does anyone know what is involved in a HiPot capability study? Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
T Machine GR&R (Gage R&R) - Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Capability Study on Extruded Alumin(i)um - How would one define a "batch"? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Capability Study Template Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
K Format for presenting capability study results? Statistical Analysis Tools, Techniques and SPC 7
