Capability Study on Extruded Alumin(i)um - How would one define a "batch"?
Mezzaluna
Registered Visitor
Morning / Afternoon Folks,
I've been given some lengths of extruded aluminium to perform PPAP inspection on. I was wondering: How would one define a "batch" of such material to perform process capability on critical dimensions? We will only be requiring a couple of tens of metres of the stuff at any one time, which the supplier will produce in the space of an hour. There is only one die. All critical dimensions are on the inside of the extrusion. Anyone had any similar experiences?
Cheers,
Mezzaluna
ScottK
Not out of the crisis
Hmm..
If it's only 10s of meters at a time and that's all they run, I'd consider each run a batch.
I was in plastic extrusion for a bit.
We stacked the lengths in 3'x4' racks.
Each rack was considered a batch for inspection purposes.
Mezzaluna
Registered Visitor
That's what I thought. Unfortunately we will be getting a 'batch" every few months or so. It will take a while to get my 25 samples for my CAP study :)
Cheers,
Mezz.
ravi3385
Cheers,
Mezz.
I am also working in Extrusion, if that is the case what is the use of taking of spc, anyhow once the order is completed again the die goes nitriding process.. so on, and if the die is loaded it runs maximum of 24 hr based on order, so if the order is of 20ton one day enough. any way what is the die dimension it reflect on the part am i right or wrong???? and one more thing the stretching process affects the dimension of the profile which is extruded!!!
Good post. However, this thread has been idle for four years, so you may not receive a response.
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
ncwalker Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
S What is Cc? Capability Study on Key Critical Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 9
L Capability Study for a Honing Machine Statistical Analysis Tools, Techniques and SPC 3
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
C Subgroup Size in Minitab for Capability Study Statistical Analysis Tools, Techniques and SPC 4
O One Cavity Mold Prototype Capability Study and PPAP Approval APQP and PPAP 1
G How to calculate Subgroup Size for Machine Capability Study Statistical Analysis Tools, Techniques and SPC 4
V How to calculate Machine Capability Study using Minitab Using Minitab Software 4
V JCI standard numbers of pieces required for Capability Study? APQP and PPAP 2
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
P Capability Study for a Specific Thickness of Rubber Sheeting Capability, Accuracy and Stability - Processes, Machines, etc. 6
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
M Capability Study on a New Machining Process - Issues Capability, Accuracy and Stability - Processes, Machines, etc. 40
S Does anyone know what is involved in a HiPot capability study? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
T Machine GR&R (Gage R&R) - Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
Barahir Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
A Capability Study Template Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
sridharafep Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
K Format for presenting capability study results? Statistical Analysis Tools, Techniques and SPC 7
Manix Initial Capability study on N50 parts - Subgroup Size? Statistical Analysis Tools, Techniques and SPC 5
