CAR (Corrective Action Request) Due Dates
embedded
Hi All,
Super simple question from a new quality manager. We keep a CAR spreadsheet to keep track of all open CARs. I understand we need to close all CARs in a timely manner typically 1 month from initiation. My questions becomes what qualifies as closing a CAR? It seems like there are 3 phases.
1.) Identify root cause and establish a plan for as to what corrective actions need to be taken.
2.) Implement corrective actions.
3.) Verify corrective actions are effective.
From my experiences it seems like the due date is typically 1 month (or request an extension) and in this time period we must identify the root cause and a corrective action plan with anticipated implementation date. This leads to my questions:
  • Do you close the CAR once the root cause and corrective action plan and planned implementation date has been identified?
  • I'm thinking a CAR is open, then closed waiting for implementation(sometimes we skip this phase), then closed waiting for verification, and finally closed. Does this sound reasonable?
  • When ever asked how we verify CARs are effective I simply say we ensure the problem doesn't recur, but to be honest I don't have a verification date, it's more like if a problem pops up and a CAR is already closed for the same issue then we need to reopen the CAR. Is this approach OK?
  • Lastly I work at a small company, where I wear many hats, and quality is my new hat(not a full time job). I'm trying to find an efficient way to keep track of all these dates. I'm thinking once a month I'll take a look at my CAR spreadsheet and follow up with anyone that is late or has a due date approaching. Is this a reasonable period, or does anyone have any suggestions on a better approach that doesn't take a lot of my time to essentially be a project manager for quality issues?
Thanks in advance,
Eddie
Kronos147
Hi Eddie,
This is a good discussion.
One thing I know is you can't check for effectiveness of the actions right away. It takes a while to see if the change takes hold.
Another thing is if the root cause is "the big machine" is broken, containment is to outsource, and correction is to get a new "the big machine", sometimes it may take more than 30, 60, 90 days to save up the $.
What if it starts with a customer complaint and the parts are never sent back? They say they are figuring out how to pack, working on it, blah, blah, blah. How do you close that in a month?
The standard says "timely." Are not the critical time frames containment and root cause analysis? As long as the action has evidence of continued management, isn't it ok to keep open?
Johnson
We should not say the CAR is closed at this phase.
This is reasonable and good practice. But it is not mandatory to have a close at each phase.
  • When ever asked how we verify CARs are effective I simply say we ensure the proble doesn't recur, but to be honest I don't have a verification date, it's more like if a problem pops up and a CAR is already closed for the same issue then we need to reopen the CAR. Is this approach OK?
The simpliest way to verify it's effectiveness is to check if it recur. It should have a verifictaion date. It the problem happend again. You may re-open it or create a new CAR and indicate it is a repeat problem. But re-open it is more complicated to handle the documents.
  • Lastly I work at a small company, where I wear many hats, and quality is my new hat(not a full time job). I'm trying to find an efficient way to keep track of all these dates. I'm thinking once a month I'll take a look at my CAR spreadsheet and follow up with anyone that is late or has a due date approaching. Is this a reasonable period, or does anyone have any suggestions on a better approach that doesn't take a lot of my time to essentially be a project manager for quality issue.
  • You may maintain a CAR log sheet or spreadsheet with all these dates recorded. I believe monthly review is reasonable but it is depending on the priority and complex of the problems.
Kronos147
Thanks in advance,
Eddie
Outlook calendar reminders are an option.
I also like the concept of centralized calendars. For example, our organization leans heavily on our Internal Audit Plan. It has follow up actions for checking the effectiveness of CARs. We manage the CAR fine, because it is an issue and we are intent on nipping it in the bud, so to speak, but it's easy to move onto the next thing and forget. The Internal Audit plan for us keeps us on track.
There's nothing magical about 30 , 60 or even 90 days. These are constraints put on us by customers and/or Certification Bodies. As far as internal requirements go, it's going to be driven by how important (top) management see the issue. I've had a plant manager initiate corrective action within minutes of understanding the issue being reported. To have allowed 30 days would have been totally unacceptable to him.
While keeping a calendar for due dates might have some utility, it certainly isn't sufficient.
I've found that if we keep our corrections at a manageable number and we have regular management reviews on the progress we get timley and effective corrective actions.
Prioritization is essential. too many and too many trivial corrective actions bog the system down and nothing gets done. While it is 'seductive' to try to solve everything at once the reality is that when we overload the system we bog it down. issuing corrective actions on only the highest effect problems allows the organization to work through problems much faster. for all other problems ask only for correction.
Regular frequent reviews of the progress allow leadership to provide appropriate guidance as well as sets the expectation that corrective actions are important. If you are involved in those reviews you will gain a deep understanding of how corrective actions work so you can optimize your system, you will know how each CA is progressing (you won't need to look at your spreadsheet), and you will have a much better understanding of how and when to verify effectiveness and when to close the CA.
tony s
Information Seeker
I just want to share the spreadsheet I'm using in monitoring when the target completion date of the corrective actions are already due for verification. The spreadsheet has an adjustable "warning days" prior to the target completion date. Once the target completion date approaches the current date less the "warning days"you are automatically prompted to arrange on when you can pay a visit to the person responsible for the corrective action. You can set your own "warning days". Be careful to unintentionally delete the formula on the Verification Status column.;)
rickpaul01
Involved in HankyPanky
Generally speaking, I do pretty much what you have outlined. (And it has worked for me.)
You did forget to list the first step - containment.
Best practices would dictate a due date (and actual completion date) for each step.
Also, consider both a corrective action and a preventive action section.
Ninja
Looking for Reality
Agreed...if...
I would NOT open and document two things, CA and PA.
As PART OF the CA you have a section for "How do we prevent recurrence"...that makes perfect sense.
Starting a PA every time you have a CA and documenting them separately makes no sense.
I figure that's what you meant...'cause you said "section"......just wanted to say it out loud is all...
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
5 Expediting Internal Corrective Action Requests (CAR) Closures Nonconformance and Corrective Action 3
Mikishots How to handle CAR (Corrective Action Request) Scope vs. Timely Response Nonconformance and Corrective Action 9
M Audit Interview as Evidence to issue a CAR (Corrective Action Request) General Auditing Discussions 13
H Acceptable Time to provide proof of CAR (Corrective Action Report) Nonconformance and Corrective Action 4
N Combining Multiple CARs (Corrective Action Request) into One CAR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Operator Mistakes (Errors) and responding to CAR (Corrective Action Requests) Nonconformance and Corrective Action 20
B Issue CAR (Corrective Action Request) When KPI Fails to meet Goal Quality Manager and Management Related Issues 8
B CAR (Corrective Action Request) from Management Review Meeting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T CAR (Corrective Action Request) for On Time Delivery Nonconformance and Corrective Action 9
C AS9100 Rev C Clause 8.5.2 - CAR (Corrective Action Request) Format AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S Supplier Corrective Action Request (SCAR) vs. Corrective Action Request (CAR) Food Safety - ISO 22000, HACCP (21 CFR 120) 15
D NC (Nonconformance) on an Auditors CAR (Corrective Action Request)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Corrective Action Audit Form to close a CAR Document Control Systems, Procedures, Forms and Templates 6
M Corrective Action Report (CAR) for CB (Certification Body) required? Registrars and Notified Bodies 8
S CAR to Assessor - Is it allowed to issue a corrective action to an assessor? General Auditing Discussions 28
F Can we reply to a CAR (Corrective Action Request) without Root Cause? Problem Solving, Root Cause Fault and Failure Analysis 24
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I How do you classify/name your CAR (Corrective Action) types? Nonconformance and Corrective Action 6
P Question in auditing regarding CAR (Corrective Action) Logs Internal Auditing 7
Crusader Registrar CAR (Corrective Action Request) Trend Analysis Benchmarking 6
C CAR (corrective action request) report form for automotive application Nonconformance and Corrective Action 5
5 CAR (Corrective Action Report) for low-buck import Nonconformance and Corrective Action 7
D What is the scope of a CAR (Corrective Action Request)? Nonconformance and Corrective Action 15
M Preventive Action in Corrective Action Report (CAR) Nonconformance and Corrective Action 14
J How to write a CAR (Corrective Action Report) for a Customer Nonconformance and Corrective Action 24
M Issue CAR (corrective action request) TO our Customer? Nonconformance and Corrective Action 20
A CAR (Corrective Action Request) form sans Cause analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T To CAR or not to CAR (Corrective Action Request) - Sales changing prices ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Are Supplier CAR's (Corrective Action Requests) a Requirement Supplier Quality Assurance and other Supplier Issues 12
A How to Write CAR (Corrective Action Request) based on scenario Nonconformance and Corrective Action 3
M Supplier completed CAR (Corrective Action Request) is unacceptable Nonconformance and Corrective Action 16
J Log in EVERY SINGLE defect caught and demand Corrective Action for each CAR? Preventive Action and Continuous Improvement 11
B CAR/PAR (Corrective Action / Preventive Action) process flow - Seeking example Nonconformance and Corrective Action 7
C Definition CAR - Corrective Action Request - What is the Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
R Car (Corrective Action Request) Responsibility - Manufacturer Per Avl Or Supplier Supplier Quality Assurance and other Supplier Issues 3
D No response to CAR's - Supplier refuses to answer a corrective action Supplier Quality Assurance and other Supplier Issues 12
I Hardcopy or electronic CAR (Corrective Action Request) form (& others)? Document Control Systems, Procedures, Forms and Templates 18
A Customer's Web Based CAR (Corrective Action Request) Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Corrective Action Request (CAR) to Customer - Has anyone done this? Nonconformance and Corrective Action 10
D Operator Error - Not an Acceptable CAR (Corrective Action Request) Response Nonconformance and Corrective Action 26
M Corrective Action Report (CAR) & Non-conformance Report (IQA) - Computer vs. Paper Document Control Systems, Procedures, Forms and Templates 2
G Corrective Action Request (CAR) Form Examples and Discussion Document Control Systems, Procedures, Forms and Templates 257
B CAR (Corrective Action Request) Format Document Control Systems, Procedures, Forms and Templates 1
B CAR/PAR (Corrective Action / Preventive Action) Systems - How to Centralize? Nonconformance and Corrective Action 17
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
A Supplier Corrective Actions - EFFECTIVE corrective actions on CAR's Supplier Quality Assurance and other Supplier Issues 7
Melissa CAR is not good enough! Operator Error! ISO 13485:2016 - Medical Device Quality Management Systems 48
G CAR & 5Whys Problem Solving, Root Cause Fault and Failure Analysis 21
