Cast Part with a Flat Base Tolerancing help
Mezzaluna
Hi everyone!
I have a question regarding tolerancing - don't know if this is the right place for it, but here goes:
I have a drawing of a cast part with a flat base. this base has a flatness of 0.5mm applied, and is a datum face: A
In the middle of the part is a boss with a shoulder. This shoulder has a parallelism tolerance on it: "0.2mm //" to datum A.
Question: is this a contradiction? if A is allowed to be 0.5mm out of flat, can we still specifiy the "0.2mm // A" for the shoulder? I can't make my mind up.
Can someone help?
Stijloor
Re: Tloeranceing help required
Hi everyone!
Can someone help?
Hello Mezzaluna,
The paralellism of the shoulder can still be specified at 0.2 mm.
The relationship with datum feature "A" is to the "true geometric counterpart" of datum feature "A". That is the imaginary plane between the datum feature and a simulator such as a surface plate or probe movements on a CMM.
So the datum feature can still be "wavy" within 0.5 mm and still be utilized as a datum feature.
Also see this interesting thread; "GD&T Parallelism Interpretation."
Hope this helps a little.
Stijloor.
David DeLong
I agree with Stijloor.
Datum A qualified with a flatness tolerance of 0.5 mm. Once it meets that requirement, one must assume that the surface is perfect. You now have datum A.
A parallelism tolerance of 0.2 to datum A is OK and quite legal.
Mezzaluna
Re: Tolerancing help required
:thanx:
Thanks guys - I thought as much but I had has this questioned. Here's another one if you would be so kind...the drawing has specified the 0.2mm as below:
[//][ 0.2 (S in a circle in the style of maximum metal)][A]
I've never seen an "S in a circle" symbol before - can you offer any explanation?
Cheers again,
Mezz.
Stijloor
:thanx:
Cheers again,
Mezz.
"S" in a circle means RFS (Regardless of Feature Size). It is an older symbol that is not used in the ASME Y14.5M-1994 Standard anymore. It means that the stated tolerance requirement must be complied with regardless the size of the controlled feature. No bonus tolerance permitted.
Stijloor.
Mezzaluna
Stijloor.
Thanks Stijloor.
If is symbol is not used in the ASME Y14.5M-1994 Standard, what would be the current controls?
Cheers,
Mezz.
Thanks Stijloor.
Cheers,
Mezz.
In the absence of a modifier, RFS is assumed.
Added in Edit: Rather than using "assumed," I should have said that in the absence of a modifier, RFS is the default requirement.
D Cast Part Machining Procedure Recommendation Manufacturing and Related Processes 2
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
C Small Cast Iron Part Cleaning Manufacturing and Related Processes 7
L Locating cast (both diecast & sand) parts consistently for machining Manufacturing and Related Processes 1
A Plaster of Paris Medical Immobilization Cast - International Standards? ISO 13485:2016 - Medical Device Quality Management Systems 6
P Re-Cast RoHS 2 - Due Dilgence procedures for a Fastener Distribution company Document Control Systems, Procedures, Forms and Templates 4
G Clear-Cast - Indoor digital tv antenna Coffee Break and Water Cooler Discussions 5
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
K Heat Treatment (Softening) on Cast Iron before it can be drilled to form Thread? Manufacturing and Related Processes 4
S Filling Up Porosity - Grey Cast Iron Casting Manufacturing and Related Processes 4
H Porosity in Aluminum Bronze Cast Gear Teeth Manufacturing and Related Processes 2
M Are there any 'Standard' for radiographing cast surgical implants like hips & knees? Other Medical Device Related Standards 1
J Special gauge design to check the bending of cast parts before machining General Measurement Device and Calibration Topics 2
T Cast iron melting - 100 % A type graphite achieving methods. Manufacturing and Related Processes 3
P Inspection Help need to make a cast impression Manufacturing and Related Processes 6
W How can I deterime the load of the DCM? Die cast machine loading Lean in Manufacturing and Service Industries 4
T CE Marking for cast iron, cast steel, and bronze Industrial Valves CE Marking (Conformité Européene) / CB Scheme 10
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V Part selection for R&R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M 2xMOPP insulation for Applied Part B. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A ISO 41001:2018 - Clause No.8 Operations Part Quality Management System (QMS) Manuals 2
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
DuncanGibbons How are part cut out specimens made and tested? Manufacturing and Related Processes 1
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
T Overvoltages consideration in Applied Part for RMS Calculation. IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
