Categories for data collection - Designing a form for when errors occur
L
little__cee
We are trying to redesign a form that will be used when an error occurs. I would like to know if there are some common categories used to group errors. I realize some will be specific to company/industry but I'd like a list that would include something like what is listed below, where the person filling out the form either circles or checks a box describing the general nature of the error:
Sales error
Shipping error
Customer error
Purchasing error
The categories above are obviously very broad - can anyone share their categories or an example of a form used to collect data regarding errors?
[I've searched - did not find a thread that dealt with this specifically and found several examples of CA forms but not necessarily a form that would have codes/categories like what I'm looking for. Thanks.]
SteelMaiden
little__cee said:
Sales error
Shipping error
Customer error
Purchasing error
We call these our "Accountable Area". Don't forget each of your major production areas (either equipment areas, or process areas), scheduling, IT, Admin (finance dept?), invalid (for those times when you deny a claim). We even include vendor in this category, and of course, Maintenance and any other area where a mistake could cause customer disatisfaction.
mshell
:agree1:
We also call those our Accountable Area. Below is a list of areas that we use to group errors.
Customer Complaint
Damaged Product
Delivery Time
Inaccurate Documentation
Incomplete Documentation
Lack of Documentation
Misshipment
Off Spec Product
Procedure Violation
Training
SteelMaiden
m, we use some similar categories to summarize the root causes.
We have categories for the area responsible for performing the investigation, area accountable for the area where the root cause of the problem happened and categories for a summarized root cause.
RoxaneB
When it comes to dealing with Abnormalities and internal Nonconformities, we first determine if the issue is Product or Process or System based.
From there, we classify it from a list of agreed-upon categories such as audit-related, safety, maintenance, etc.
Issues such as internal invoicing errors and cheques issued in error are captured on our Key Indicators for the appropriate departments.
Where are you capturing this information, Stacey? On department metrics or on a Nonconformance log?
L
little__cee
It gets complicated!
The quick version: we currently have a form called the "Process Failure Form" - it was originally our intention to change the negative name. Decided that while we were changing the name, let's improve the form too - okay fine.
Now someone suggested that it would be nice (!?$?!) to have various categories on this form (which as of right now has no name!) so that you could just check off whether or not it was related to a cutting error, delivery error, sales error, error pulling material, etc. Right now we currently write the nature of the event on the form and we don't attempt to "code" it until we have our monthly joint supervisors meeting (commonly known as the Pareto Meeting since Pareto charts are presented there) and the data from the process failure forms gets recorded on the charts.
Whew.
To further make things more confusing, our external auditor came in and suggested that we do not need to use Process Failure Form and a CPA form so we should just revise the Process Failure Form to meet the standard as a stand-alone form and go that route.
Wow.
Did I make things any clearer for you, because if I did there's a spot for you here in the States if you want it!
RoxaneB
Wow, Stacey...sounds like you're having a lot of fun with this! :)
Here is our current system stands....
We have:
  • Abnormalities - process-based issues
  • Nonconformances (Major or Minor) - product and system-based issues
  • Customer Complaints
I say "current" because we are revamping this set up a wee bit.
Abnormalities and NCR's are being merged to form the Failure Treatment Report (FTR).
To allow for ease of complete and data collection, we have check boxes on the FTR so that we clearly distinguish the 'type' of Failure we have.
First off...is it an Abnormality or Corrective or Preventive. Abnormality is for issue that may not require Root Cause Analysis and do not require a Verification Plan.
From there, the initiator indicates if the issue is Process, Product or System based. Triggers for Process issues are listed in the footer of the form (as there are not many triggers) - if not listed there, it will be either Product or System.
If uncertain, the initiator reviews the options along side Process, Product and System to determine the applicable check boxes to mark:
  • Process
    • Operational
    • Mechanical
    • Electrical
  • Product
    • Internal product quality
    • Incoming material
    • Supplier/Contractor (includes service)
  • System
    • BMS
    • BMS - Internal Audit
    • BMS - External Audit
    • EMS
    • EMS - Internal Audit
    • EMS - External Audit
    • H&S
    • H&S - Internal Audit
    • H&S - External Audit
    • 5S
    • Other - please specifcy
Of course, the type of issue will be organization-specific and what works for me, may not work for your organization, Stacey. :)
Customer Complaints
There are 4 classifications of Customer Complaints maintained within our Order Entry system. This is separate from our FTR as the FTR is based out of our mill only, whereas the Order Entry system is based off a common server for all of our North American mills to access.
The Sales person entering the Complaint into the Order Entry system must first determine the 'type' of complaint before classifying the specific problem.
  • Responsibility to resolve - Sales
    • Invoice
      • Examples include:
        • Miscommunication between Sales and Customer
        • Wrong grade/length/quantity placed on order
        • Data entry
    • Service-Sales
      • Examples include:
        • Entered wrong location
        • Entered wrong delivery date
        • Double shipment
        • Special instructions not entered
  • Responsibility to resolve - Mill
    • Service-Mill
      • Examples include:
        • Failure to ship
        • Did not meet delivery date
        • Weight discrepancy
    • Quality
      • Examples include:
        • Chemistry
        • Bent bars
        • Rust
        • Out-of-spec dimensionally
M Distinct data categories - [PV / R&R] - May I know what is this equation used for? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Number of Distinct Data Categories - NDC - AIAG's MSA Manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Experience and advice with certifications categories Training - Internal, External, Online and Distance Learning 3
qualprod Internal Audits - Categories of non conformances Internal Auditing 12
D Accident reporting categories Occupational Health & Safety Management Standards 1
Ed Panek Can a single supplier fit two or more categories for risk? ISO 13485:2016 - Medical Device Quality Management Systems 2
J 5 why's in 3 categories Problem Solving, Root Cause Fault and Failure Analysis 9
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
G Nonconformance Categories - QMS web app to support ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Veterinary Devices - CE Marking Categories CE Marking (Conformité Européene) / CB Scheme 6
V Examples of investigation or root-cause categories - Mother Nature (Environment) Problem Solving, Root Cause Fault and Failure Analysis 3
B Help with NDC (Number of Distinct Categories) Please Six Sigma 2
P Where do training documents fit into the ISO 9001 categories? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V Monitoring Specific Reasons and Categories of Yield Loss of Online Rejects ISO 13485:2016 - Medical Device Quality Management Systems 1
T Drop Down ("Standard") Categories for Corrective Actions & Root Cause Nonconformance and Corrective Action 4
R Help defining Eyewear Customer Complaint Categories Customer Complaints 5
M MSA Manual asks for NDC higher than 5 - NDC (number of distinct categories) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Impossible to achieve NDC (Number of Distinct Categories) greater than 2 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28
V Can Anyone Give a Simple Explanation on ndc (number of distinct categories)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Employment Contract Review - Categories of International Mobile Workers Contract Review Process 1
C Gage R&R Results - ?Number of Distinct Categories = 1? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24
G Hazard Identification Categories - ISO 14001 vs OHSAS 18001 Occupational Health & Safety Management Standards 3
Kales Veggie Ford RSMS (Restricted Substance Management System) 2008 released / GADSL categories RoHS, REACH, ELV, IMDS and Restricted Substances 16
S What is NDC (Number of Distinct Categories)? MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
I Evaluation of Medical Device Suppliers - Categories when Initially Evaluated ISO 13485:2016 - Medical Device Quality Management Systems 19
J What are ISO Certification Code(s)? IAF Accreditation Scope Categories ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Role of different categories of auditors in AS 9100 audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Gage R&R - Is there an upper bound for number of distict categories? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Auditing calibration - Different categories in the equipment status General Measurement Device and Calibration Topics 11
P Not enough distinctive categories in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
A Number of distinct categories (NDC) - Non ferrous metal industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Geoff Cotton Minitab GR&R (Gage R&R) - Minitab is giving different results for distinct categories Using Minitab Software 4
Y NDC (Number of Distinct Categories) - Long Gage R&R Study in MSA 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 76
Marc List of Quality Records (Categories) Required by ISO 9001:2000 Records and Data - Quality, Legal and Other Evidence 1
D Prioritized Action Plan - Start by identifying major scrap items/categories/costs? QS-9000 - American Automotive Manufacturers Standard 5
Q AMS 2750 E or F Continuous Furnace TUS Data Collection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Safety data sheets software REACH and RoHS Conversations 2
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
Steve Prevette Informational I am presenting a webinar Thursday - "Data Driven Decision Making" - 19 November 2020 Statistical Analysis Tools, Techniques and SPC 5
