Cause Analysis for Verification/Validation Failures - Seeking Opinions
Chennaiite
Never-say-die
Deeper cause analysis during verification/validation phase can many times get into research mode. While the learning out of such analysis will help in future projects, the flip side is that it delays the Start of Production of the project under development. Therefore we are facing the need to give up analysis at some point and take corrective actions accordingly. I am interested to know how this situation is managed generally?
For Example, lets say a Brake liner is not meeting the target life during vehicle level validation. Typically the DFMEA of the liner addresses some potential causes for this failure mode - liner not meeting target life. Preliminary analysis will zero in on one of the causes, example lets say grade of the liner material. Now one option is to stop the analysis here and take actions to upgrade the liner and revalidate. The other option is to further drill down and understand as to what characteristics of the particular grade of liner is not acceptable, etc. The analysis sometimes become even more complicated when the same grade meets required life in a different application. Drilling down further sure helps in enhancing the Design capability of the Organization, but then usually project timelines do not allow the team to do that and hence more often they are merely documented as Things gone wrong at the end of the project. What are your views on this?
TWA - not the airline
Re: Cause analysis for Verification/Validation failures - seeking views
For me this is simple (though I'm well aware of the fact, that life in this world is anything but simple...): A failed validation results an a CAPA and for that there is a system/procedure you follow to determine your root cause and define your corrective and preventive actions.
The issues you described are the same for any quality problem that needs a CAPA to resolve: the more time/ressources you invest, the more you'll know in the end about that issue and the better your CA will be and the more good PAs you'll implement that prevent problems in the future but the flip side is that your hands are tied while this process is ongoing...
Options you have are the same as for any quality problem: Differentiate between safety/function related issues which need to be corrected immediately and anything else, for which it is a bussiness decision to decide how much you want to invest to get rid of it and how this is prioritized.
Chennaiite
Never-say-die
Verification/Validation problems in my opinion are little tricky. The difference is, in case of production, problems are failures of a proven and established idea. Stray cases notwithstanding, the analysis in such cases will generally revolve around what went wrong against the established standard. Whereas, the fact that verification/validation are performed to prove an idea, when faced with problems, it takes to generate new ideas sometimes. I am not saying this happens everytime when problem happens, but good number of times to ignore.
I understand your reasoning. In my system the cause of such failures is already determined in the NCR phase, like typically "production did not follow SOPs", faulty components that were used because they were not found during incoming QC etc. Only the tricky ones become CAPAs...
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 3
N Why is RCA (Root Cause Analysis) essential? Problem Solving, Root Cause Fault and Failure Analysis 23
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Risk Analysis - Events which may cause to Data Loss ISO 14971 - Medical Device Risk Management 12
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
H Cause analysis for an Audit Finding - Purchasing Procedure Content ISO 13485:2016 - Medical Device Quality Management Systems 9
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
F Need advise on Root Cause analysis for printing issue Problem Solving, Root Cause Fault and Failure Analysis 3
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
B Root Cause Analysis and Corrective Action Program for Inventory Inaccuracies Nonconformance and Corrective Action 8
R Root Cause Analysis of Audit Findings - New Quality Manager Quality Manager and Management Related Issues 20
A Recommend good Root Cause Analysis Training Courses in the UK Training - Internal, External, Online and Distance Learning 8
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
R Triggering Root Cause Analysis for Hardware Returns Nonconformance and Corrective Action 3
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Root Cause Analysis and "Comprehensive List of Causes" Nonconformance and Corrective Action 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
K Complex Cause Root Cause Analysis Quality Tools, Improvement and Analysis 3
P Smart or Sexy (CAR) - Poor Root Cause Analysis and Poor Effectiveness Check Nonconformance and Corrective Action 8
Moncia How to do a Root Cause Failure Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
K Do all Customer Complaints require Root Cause Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Incident Investigation vs. Root Cause Analysis ? What?s the difference? Customer Complaints 16
Anerol C Root Cause Analysis Coding System Nonconformance and Corrective Action 11
J Root Cause Analysis in a ISO 17025 Testing Laboratory ISO 17025 related Discussions 6
S EMI/EMC Failure Cause Analysis per IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Noneffective Root Cause Analysis: 6M Fish-Bone Template Problem Solving, Root Cause Fault and Failure Analysis 1
L Root Cause Analysis Training Training - Internal, External, Online and Distance Learning 12
W What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products Problem Solving, Root Cause Fault and Failure Analysis 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
