CCP Critical Limit and Corrective Action - Plastic Brush Parts
P
patriot19472001
Dear Food Professionals,
We have a Frozen French Fries production line. In line the 3rd step is Brush Peeler which removes the skin of Potatos with the help of small plastic brushes. During Hazard Identification stage in HACCP we declared it a CCP. But now I'm confused with following questions:
1-In Hazard Analysis this Step has a very Low Severity(1) and also no past occurance History. So is it correct to declare it a CCP?
Moreover If we Declare it a CCP then:
2- What will be the critical limit for a Plastic Food Grade Brush?
3- If we defined a descriptive critical limit(like physical inspection) then it be acceptable or not?
4- And finally if we found that some plastic brush pieces aren't with the brush then what can we do with the product as its not possible to inspect the whole product and we also don't have any X-Ray(example) type or any other scanner to scan the product.(We only have metal detector)
Attached file will clear the situation more.
A huge thanks for an early (and obviously for the late) response.
Regards,
Ghulam Mustafa
P
patriot19472001
Dear All,
Hope that you will be in good health and spirits. I have replied by my Boss on the aforesaid issue. Can anyone/auditor confirm it!
1- We have cooking guidlines on our label that there's a need to cook the Frozen French Fries at Temperature of atleast 150 C for 5 mins. My boss claims that our plastic brushes are food grade and if these include in product(even with non occuring history) then these small pieces will melt during cooking hense no hazard for the consumer(because brush is food grade).
Is this logic applicable?
Thanks in advance.
Ghulam Mustafa
K
K-dix
Dear All,
Thanks in advance.
Ghulam Mustafa
OK, the question is, is the next step -which is even out of your control (cooking by the customer) supposed to be done to control the physical contamination by plastic bristles on the product? and worst, what if the customer notice any bristle on the product the moment is about to cook them? are you going to tell them is food grade and they can eat them anyway? or are brush bristles in the list of ingredients on the product label? (!)
P
patriot19472001
Dear K-Dex,
First of all thank you so much for your response. I'm agreed with you but i have some other questions also!
Thanks in advance:)
Regards,
Ghulam Mustafa
jmann
Dear K-Dex,
Thanks in advance:)
Regards,
Ghulam Mustafa
I would first ask yourself what hazard are you trying to control at this step? What physical/chemical/biological hazard will be either eliminated or reduced to an acceptable limit at this step? Your hazard analysis indicates this as low severity so it would appear it might not designate itself as a CCP but moreso a Control Point or Operational PRP.
If I am reading you right, the hazard is physical contamination from parts of the brush getting in with the product. The questions relate to that risk.
What would be the risk/effect of having brush bristles (or fingers, or whatever you call them) mix into your fries? You claim it has a low severity, meaning that it will not do much damage. You also state there is no record of this occuring, which would indicate that it is not expected to occur. Those two items typically would mean that it would not be a high risk item.
But, just because ther is no record of it happen, do we know it has not happened? You can still control the risk. But you need to determine what the thresholds (or limits) would be, and how you measure it.
P
patriot19472001
Dear Jmann and Dave B,
Thank you so much for your questions and guidance. Please consider the below points:
1- These brushes are at 3rd and final step of manufacturing.
2- This is a physical hazard and we don't have any subsequent step to remove these pieces so i Declare it CCP even the severity was low with NO PAST OCCURANCE HISTORY.
3- Can you guide me please that how can it be an OPRP or how any modification/operation can control it?
4-What will be the critical limits for pieces of a plastic food grade brush?
5- We have only visual checking method once/week earlier (now its more frequent checked). Can we put another checks on it?
Thanks again for your comments and guidance and Obviously waiting for guidance on above points.
Regards,
Ghulam Mustafa
jmann
Regards,
Ghulam Mustafa
Regarding point 2, if this is declared as a Physical Hazard, what severity rankings are used to establish its impact to the consumer. It appears that you may have combined occurrence rate into that severity ranking. If that's the case, you should treat them separately. If you find that the severity is high due the hazard impact to the consumer, then you'll have to understand how best to control this step.
I would argue it is a CCP if you do not have any further downstream process steps that would monitor for any foreign material introduced at this step. If that is how your process is set-up, then you should consider improving your monitoring activities. Look to make this decision based on known risk, capability, and production needs.
Regarding point 4, this is a sensitive area in which you may look to regulatory guidelines but ultimately, you should look to your customers as understanding their expectations.
As another forum member pointed out, can you further eliminate this hazard by modifying this process?
Hope these questions help.
P
patriot19472001
Dear Jmann,
Heartiest thanks for your reply. Please consider the following points
1- For determining severity rankings please see the below table we use
Severity if controls fail
Severity of affect if Hazard Occurs
Multiplier
Little Damage
Mild disappointment to the consumer. May lead to a complaint, no business interruption. Minor consequences.
1
Damage
Very minor medical treatment, (for example a broken tooth). Consumer disappointed and likely to lead to a complaint to the Company.
2
Serious Damage
Illness at home. Medical treatment not necessary. A disappointed consumer very likely to lead to a complaint to a regulatory authority.
3
Very Serious Damage
Illness at home with medical treatment necessary. A very disappointed consumer. A significant risk of proscecution.
4
Disaster Serious Illness
Hospitalization required. Significant risk of proscecution. Media coverage. Intervention by ?Crisis management team?. Damage to ?branded ? image.
5
Catast-rophic
Death. Top level ?crisis management? Certain risk of proscecution. Destruction of ?brand?
6
2- Hazard to consumer is very low so severity is low
3- We also don't have any past occurance about this HAZARD. But there is a chance of occurance.
I think now it is more clear. I'm still confused that may i declare a frequency for change of brushes after studying the condition of brushes(rupturdness) but what about the particles passed in the product(if any)?
One form is attached for more clarification.
Regards,
Ghulam Mustafa
J Decision Tree using for CCP (Critical Control Points) Food Safety - ISO 22000, HACCP (21 CFR 120) 2
J Defining CCP (Critical Control Points) in a Rice Mill Plant Food Safety - ISO 22000, HACCP (21 CFR 120) 9
M Determining Critical Control Points (CCP's) in Food Safety Food Safety - ISO 22000, HACCP (21 CFR 120) 4
M Critical Limits for CCP in a food storage warehouse Food Safety - ISO 22000, HACCP (21 CFR 120) 4
P Critical Limits for Air Blower as CCP (Critical Control Point) Food Safety - ISO 22000, HACCP (21 CFR 120) 6
K Must every CCP (Critical Control Point) have a (documented) procedure? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
R Still confused on OPRP and CCP in an ISO 22000 Catering Business Food Safety - ISO 22000, HACCP (21 CFR 120) 3
F ISO 22000 Clause 7.4.4 to determine whether a control is a CCP or and OPRP Food Safety - ISO 22000, HACCP (21 CFR 120) 2
P CCP Monitoring Sheet/Record in ISO 22000 Food Safety - ISO 22000, HACCP (21 CFR 120) 3
L oPRP or CCP? Practical example Food Safety - ISO 22000, HACCP (21 CFR 120) 2
A HACCP Plans - OPRP's and CCP's - Difference, please Food Safety - ISO 22000, HACCP (21 CFR 120) 10
M CCP Validation and Pre-Requisite Program Reassessment Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
K When, whom, how to conduct hazard analysis of PRP?s, OPRP?s and CCP?s? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
C CCp : Composite Cp. A new star born (?!) Statistical Analysis Tools, Techniques and SPC 8
Marc Acronym CCP - Acronym Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
M Critical Characteristics APQP and PPAP 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B ISO 11607-2 "Critical Parameter" vs. "Process Parameter" Other Medical Device Related Standards 6
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
C Critical Suppliers for EU medical device approvals May 2020 EU Medical Device Regulations 1
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 15
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
H Critical Supplier Agreement acc. to NBOG 2010-1 Annex II EU Medical Device Regulations 10
andika_untoro What are a good Critical to Quality (CTQ) metrics for a biotech manufacturing production? Lean in Manufacturing and Service Industries 0
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 18
M Does a CDR (Critical Design Review) have to have a moderator that is unconnected to the team? Design and Development of Products and Processes 4
S Critical supplier - Obligated to have an ISO-certified QMS? ISO 13485:2016 - Medical Device Quality Management Systems 8
A Critical Supplier/Quality Agreement Procedure ISO 13485:2016 - Medical Device Quality Management Systems 8
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J What level PPAP for 5 critical parts? APQP and PPAP 8
C Partial Design Validation and changes to a critical supplier 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
S Financial status of critical vendor IEC 27001 - Information Security Management Systems (ISMS) 7
Ajit Basrur CDRH Premarket Approval Application Critical to Quality Pilot Program US Food and Drug Administration (FDA) 0
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
Q Is a Domain Registrar a Critical Supplier? ISO 13485:2016 - Medical Device Quality Management Systems 11
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
