CE Mark Technical Files as controlled document in ISO9001 QMS
F
fEArmE
Hi there,
I've been searching for information on how the CE mark technical files be integrated to our current QMS system, but to no avail. I was wondering what kinda documents should they be classified under the ISO9001 standard. We have defined our QMS documentation to a 4 tier approach. Quality Manual, Quality Procedures, Work Instructions and records. The CE mark technical files are not really related to the QMS but I'd like to include them as part of controlled documents. I'll be extremely happy if someone could shed some light on this. Thank you!
F
fEArmE
I'm thinking to classify them as record too but the technical files will be revised in the future which makes it kinda weird revising a record.
Le Chiffre
Hmmm, I see it differently. The technical file is made up of records and documents, with an index that cross references the revisions and dates of each part.
somashekar
Hi there,
Your CE mark technical file is indeed related to your QMS, if you have identified say the MDD as a regulatory requirement in your ISO 13485 QMS. As said by Le, its a compilation of several documents and records which by themselves are under your documents and records control process. and thus the Technical file is indeed under document management. I do not see here any problem for you. As long as you have a well maintained and updated technical file covering all engineering changes, significant changes handling, and records meeting to your set harmonized standards, why bother about any classification for the technical file ?
F
fEArmE
Hi Somashekar,
Thanks for your feedback. The reason I'm bothered by classification is that our current document change notice procedure only have room for quality manual, quality procedures and work instructions. Records are considered to be documents that do not need revision(correct me if I'm wrong). If I classify them as record, it sounds weird to revise a record. The other option I could think of is to redefine our documentation procedure to include Technical Files but I'd like to hear what the pro says first. Thanks.
I
iansawyer
Hi fEArmE - You are right that the Technical File does not fall into one of those categories. The best option is to amend your document control procedure to cover "quality manual, quality procedures, records, and technical files".
W
Watchwait
We have, in fact, incorporated our Technical Files into our controlled document system. Maintenance thereof is a bit of a task, but not an overly burdensome one due to the way we structured the TFs. Basically, the TF is a list of documents - some controlled, others not. For the controlled documents, we list the basic document number, but not the revision, e.g. WI-12345-XXX. Then, in the preface of the TF we indicate the the latest revision of any referenced document is contained within the controlled document system itself. This way, we only need to revise the TF when a document is added or subtracted from the DMR - not when they are merely revised, which is by far the more frequent occurrence. To be sure, the TF contains many more documents than those listed in the DMR or the QSR, but those types of documents, once incorporated, rarely change. FYI, our Notified Body has reviewed this approach and is fine with it.
B CE Mark "piggybacking" on suppliers technical files - Looking for contract example EU Medical Device Regulations 6
JoCam Review of Technical File for CE mark EU Medical Device Regulations 6
A CE Mark - Maintaining Technical File and Regulatory Assessment CE Marking (Conformité Européene) / CB Scheme 1
rob73 Transfer of Technical File, CE Mark etc., for an OEM Medical Device EU Medical Device Regulations 3
S MDD Technical File CE Mark - Addition of a Device to our Current CE Marked Family EU Medical Device Regulations 4
C CE Mark Technical Construction File for LVD (LED Luminaire) CE Marking (Conformité Européene) / CB Scheme 6
S Medical Device Technical File/Dossier (CE Mark) review - How many ?experts? available CE Marking (Conformité Européene) / CB Scheme 3
H CE Mark Technical File - Procedure for the generation of a "Technical File" ISO 13485:2016 - Medical Device Quality Management Systems 5
J CE Mark - Technical File Help - Machinery Directive 98/37/ec CE Marking (Conformité Européene) / CB Scheme 1
A Technical Agreement for the CE Mark - Essential Requirements Checklist EU Medical Device Regulations 7
A CE Mark / TCF (Technical Construction File) File sample EU Medical Device Regulations 10
B Technical File for CE Mark declaration - Template or Sample of required contents EU Medical Device Regulations 24
J MDD and CE Mark Registration - What will the technical expert look for? EU Medical Device Regulations 6
N CE Mark Auditing - All they had for CE was a written Technical Justification EU Medical Device Regulations 5
V New Product Model CE Mark Certification under MDR EU Medical Device Regulations 0
P Violation of CE mark - Re-use of single-use Products CE Marking (Conformité Européene) / CB Scheme 2
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
A First CE-mark class III implantable device under MDD EU Medical Device Regulations 8
F List of countries that 'prefer' a CE Mark CE Marking (Conformité Européene) / CB Scheme 1
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
M MDR EU Distributor for our CE Mark product in the for Netherlands EU Medical Device Regulations 6
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
Ed Panek CE Mark Requirements on Kits (off the shelf product requirements met) CE Marking (Conformité Européene) / CB Scheme 2
R IVDR CE Mark for Class A products - Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
G UVC sterilizer CE Mark CE Marking (Conformité Européene) / CB Scheme 5
C Does a CE mark infer meeting all applicable standards? CE Marking (Conformité Européene) / CB Scheme 4
M CE Mark and 510(k) -Global registration requirements for every country Other Medical Device Regulations World-Wide 3
A CE Mark and PMCF study EU Medical Device Regulations 3
T CE mark start date for a device EU Medical Device Regulations 7
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
S CE Mark - Classification Confusion EU Medical Device Regulations 12
S Until when can we CE-mark and sell MDD class 1 devices? CE Marking (Conformité Européene) / CB Scheme 17
N CE Mark for Class 1 medical device CE Marking (Conformité Européene) / CB Scheme 11
Y CE Mark - Placing the CE mark on medical device labels EU Medical Device Regulations 2
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
D Vietnam requirement of CE mark for medical devices CE Marking (Conformité Européene) / CB Scheme 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
S CE mark on a medical device - Textile product CE Marking (Conformité Européene) / CB Scheme 2
V CE Mark under MDD or IVDR - IVD company doing Virtual Manufacturing Other Medical Device Regulations World-Wide 3
S REF and CE mark symbols on multi-component device EU Medical Device Regulations 3
D Who are the accredited Certified Bodies for CE Mark for Medical Devices? CE Marking (Conformité Européene) / CB Scheme 7
Ed Panek GTIN (Global Trade Item Number) for non CE Mark Other Medical Device Related Standards 4
S Can we still manufacture whilst awaiting return of our CE Mark? Other Medical Device Related Standards 1
J EC REP information and CE Mark - Component of a system that is not a medical device EU Medical Device Regulations 2
F Interpretation of MDR 2017/745 Article 23 - CE Mark Requirements EU Medical Device Regulations 8
C Is CE Mark needed for a small DAC audio board on top of a Rasberry PI? CE Marking (Conformité Européene) / CB Scheme 1
B Do CE Mark associations exist? CE Marking (Conformité Européene) / CB Scheme 1
E EU Class 1s CE Mark Regulatory Pathway EU Medical Device Regulations 9
K CE mark transition and new regulations CE Marking (Conformité Européene) / CB Scheme 0
L Class IIa Medical Device, CE Mark & 510k - Labeling Content CE Marking (Conformité Européene) / CB Scheme 4
