CE marking for OEM Brand
Sumie
We are the OEM manufacturer for brand owner located in EU. However, the brand owner wants us to put our company name as the manufacturer and their brand on the product packaging and asked us to do all registration, CE marking and wants to use our importer to bring in the product to Europe. They also want us to put their company name as the distributor. Is it possible for the brand owner to also play a role as distributor? Also, is it possible for us to do product registration and CE marking for other brands which are trademarked by other companies?
monoj mon
Yeah, some companies do that. Perhaps to avoid all those responsibilities related to regulatory compliance. We are also on the same boat as yours, can't argue more. Before proceeding to do that, I would suggest to establish a proper discussion channel between the two companies to share the roles and responsibilities. When things go like this, during any unforeseen event both of the companies will realize multiple unshared responsibilities and may eventually start pushing the responsibility to each other. Better to sort things out at the beginning.
Sumie
Thanks Monoj Mon.
CharlieUK
Always worth reviewing the definitions of "Manufacturer", "Importer" and "Distributor" in the applicable directives
If the manufacturer is outside EU/EFTA then the person bringing the product in becomes the importer (whether they want to be or not)
There is no real issue with doing this as long as you are careful with the product marking to make sure who the product manufacturer is. As the OEM it often make sense for you to own the compliance task as you have control of the manufacturing process which is the main cause of changes likely to cause a non conformance. A key question however is who has designed the product. If you have done it then you should have the capability to asses the product and any relevant standards and keep up with them. If the brand holder has done the design work then life is a lot more complex as you need to keep the design authority in the loop for any changes.
With all the companies I have worked for it has be the manufacturer rather than anyone rebranding the product who has owned the compliance task. In my opinion this makes more sense as it is much simpler for the product designer to maintain product compliance than for a VAR to do so.
You also as Charlie says need to be careful about who is the product importer (see the blue guide). Where the importer is not the same as the manufacturer then you may feel the creation of and EU Authorised Representative makes sense
CharlieUK
It's not about whether you "need" an importer - it's whether a company becomes an importer:
The NLF aligned directives define: ‘importer’ means any natural or legal person established within the Union who places radio equipment from a third country on the Union market;
If the manufacturer is not in EU/EEA, then the 1st person in the EU/EEA to receive the product becomes the importer
remember the Importer is a role defined by the legislation. It could be your distributor, it could be yourself or it could be someone else.
Remember the importer has to be established in the EU/EEA so if you are a UK company then (since Brexit) you cannot be the importer into the EU/EEA. The importer becomes the first EU/EEA entity you transfer ownership to. If the Manufacturer is either established in the EU/EEA or has an authorised Representative within the EU/EEA then the roll of the importer is not particularly onerous as they can pass most issues back up the line. Where the Manufacturer is not an EU/EEA entity then pretty much the full responsibility for ensuring compliance falls to the importer, which is why many importers require non EU/EEA companies to provide an EU Authorised Representative.
ChloeArmstrong
After your answer, I understood what was going on , thank you for clarifying.
O OEM vs. Supplier - CE Marking EU Medical Device Regulations 1
A Technical documentation ce marking pippete tips CE Marking (Conformité Européene) / CB Scheme 0
S Device with different options for a sub-component - CE marking implications EU Medical Device Regulations 2
R CE and UKCA marking Own Brand products CE Marking (Conformité Européene) / CB Scheme 0
C CE Marking - Medical Device Accessories EU Medical Device Regulations 0
J Using of CE marking - Two CE markings on the product CE Marking (Conformité Européene) / CB Scheme 5
T CE Marking - Bench mark Device from same manufacturer CE Marking (Conformité Européene) / CB Scheme 2
F Lithium polymer battery, venting and CE Marking CE Marking (Conformité Européene) / CB Scheme 4
A Migrating from whole product CE marking to modular approach CE Marking (Conformité Européene) / CB Scheme 5
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
G CE marking of MD and IVD set EU Medical Device Regulations 3
M CE marking for NON-EU EU Medical Device Regulations 0
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
S CE marking for a product upgrade CE Marking (Conformité Européene) / CB Scheme 0
P CE Marking UK Membership CE Marking (Conformité Européene) / CB Scheme 1
J Powered wheelchairs (Class IIa) in the process of CE marking and use in hospitals CE Marking (Conformité Européene) / CB Scheme 4
D CE Marking Requirements MDD & MDR - new product development covered under same scope EU Medical Device Regulations 1
N CE marking colour for Medical Devices CE Marking (Conformité Européene) / CB Scheme 4
A EAC Marking in Medical Device Other Medical Device Regulations World-Wide 0
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Clinical investigations of medical devices - not for CE marking EU Medical Device Regulations 0
P Marking Machinery for Israel CE Marking (Conformité Européene) / CB Scheme 3
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Does cFDA accepts FDA approval or CE marking? China Medical Device Regulations 1
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
Ed Panek Is Shelf Life Change a significant change? CE Marking CE Marking (Conformité Européene) / CB Scheme 7
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
N How to Write and Compile a Technical File for CE Marking CE Marking (Conformité Européene) / CB Scheme 4
CPhelan Do you require MDSAP for CE Marking of a Medical Device or is ISO13485:2016 with clinical data sufficient? CE Marking (Conformité Européene) / CB Scheme 6
P CE Marking EN ISO 13849-1: Electrical Panel behind interlocked doors CE Marking (Conformité Européene) / CB Scheme 9
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
H Safety and efficacy study for CE marking CE Marking (Conformité Européene) / CB Scheme 1
S Difficulty Finding A Notified Body for CE Marking - No Capacity Registrars and Notified Bodies 5
K Post Market Clinical Follow up and CE Marking for Class IIb medical X-Ray products CE Marking (Conformité Européene) / CB Scheme 1
J CE Marking for vibrator personal pleasure toy CE Marking (Conformité Européene) / CB Scheme 17
JoshuaFroud CE Marking and Brexit - Product shipped to a distributor prior to the March deadline EU Medical Device Regulations 2
M Informational Design for new product safety marking for the no-deal Brexit scenario Medical Device and FDA Regulations and Standards News 1
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
Z Direct Part Marking (DPM) requirements for Class II Medical Devices Manufacturing and Related Processes 0
M Medical Device News FDA Guidance - UDI: Policy Regarding Compliance Dates for Class I and Unclassified Devices and Certain Devices Requiring Direct Marking Other US Medical Device Regulations 0
J Virtual Manufacturer and CE Marking EU Medical Device Regulations 8
N CE marking for distributed product CE Marking (Conformité Européene) / CB Scheme 1
