CE marking of MD and IVD set
Hi all,
I was hoping for some clearance and guidance.
We have an already marketed a class IIa single use and sterilised medical device and a self-certified single use and sterilised IVD, which is classified as a General IVD (self-certified) under the current EU IVD Directive.
Now we want to market above products as one "new product. In our new product we are combining the MD and IVD and giving them a sterilisation together and new packaging. So you could say, we are now providing the two seperate products as one "sample set".
Would both products then require a CE mark with notified body number? The IVD will still remain as self-certified, so it does not make sense to put the CE mark for notified body on that - or will the notified body see this new product as "one" unit?
Please let me know what you think about this or if you have any concerns, Thank you in advance :)
LukasLosigkeit
You can combine products in a system or procedure pack. Each component, if an individual product, bears its own CE mark (the CE mark they received during product registration independently from the system/procedure pack. You do not change these CE marks.
The system or procedure pack will be assigned a CE mark.
If you add the NB number to the self-declared IVD, you falsify the labeling. Do not do that.
L_O_B
Systems and procedure packs are not assigned a CE mark on their own. Assigning a CE mark would imply that someone declared conformity for the combination with regulatory requirements. For the procedure described in article 22, this is not the case. Additionally, systems and procedure packs are not "devices" by the meaning of the regulation (see article 1(4)). Therefore, they are not required to bear a CE mark according to article 20(1).
@gkrehal
You are not allowed to use article 22 until the MDR applies in May next year. If you want to place your combination on the market as a procedure pack, you must follow the national requirements transposed from the MDD article 12.
Regarding the CE markings, the requirements are the same:
1. Each device retains its individual CE mark.
2. The packaging of the procedure pack does not bear a CE mark.
LukasLosigkeit
Clarification regarding when the system / procedure pack receives a CE under MDR:
"Where the system or procedure pack incorporates devices which do not bear the CE marking or where the chosen combination of devices is not compatible in view of their original intended purpose, or where the sterilisation has not been carried out in accordance with the manufacturer's instructions, the system or procedure pack shall be treated as a device in its own right and shall be subject to the relevant conformity assessment procedure pursuant to..."
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
F CE Marking Algorithm for an IVD use only Medical Device EU Medical Device Regulations 7
M CE Marking - RTTE Directive & IVD Directive CE Marking (Conformité Européene) / CB Scheme 7
S Is CE IVD marking required on CoA and CoC? EU Medical Device Regulations 4
T CE Marking - Bench mark Device from same manufacturer CE Marking (Conformité Européene) / CB Scheme 2
F Lithium polymer battery, venting and CE Marking CE Marking (Conformité Européene) / CB Scheme 4
A Migrating from whole product CE marking to modular approach CE Marking (Conformité Européene) / CB Scheme 5
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
S CE marking for OEM Brand CE Marking (Conformité Européene) / CB Scheme 11
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
M CE marking for NON-EU EU Medical Device Regulations 0
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
S CE marking for a product upgrade CE Marking (Conformité Européene) / CB Scheme 0
P CE Marking UK Membership CE Marking (Conformité Européene) / CB Scheme 1
J Powered wheelchairs (Class IIa) in the process of CE marking and use in hospitals CE Marking (Conformité Européene) / CB Scheme 4
D CE Marking Requirements MDD & MDR - new product development covered under same scope EU Medical Device Regulations 1
N CE marking colour for Medical Devices CE Marking (Conformité Européene) / CB Scheme 4
A EAC Marking in Medical Device Other Medical Device Regulations World-Wide 0
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Clinical investigations of medical devices - not for CE marking EU Medical Device Regulations 0
P Marking Machinery for Israel CE Marking (Conformité Européene) / CB Scheme 3
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Does cFDA accepts FDA approval or CE marking? China Medical Device Regulations 1
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
Ed Panek Is Shelf Life Change a significant change? CE Marking CE Marking (Conformité Européene) / CB Scheme 7
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
N How to Write and Compile a Technical File for CE Marking CE Marking (Conformité Européene) / CB Scheme 4
CPhelan Do you require MDSAP for CE Marking of a Medical Device or is ISO13485:2016 with clinical data sufficient? CE Marking (Conformité Européene) / CB Scheme 6
P CE Marking EN ISO 13849-1: Electrical Panel behind interlocked doors CE Marking (Conformité Européene) / CB Scheme 9
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
H Safety and efficacy study for CE marking CE Marking (Conformité Européene) / CB Scheme 1
S Difficulty Finding A Notified Body for CE Marking - No Capacity Registrars and Notified Bodies 5
K Post Market Clinical Follow up and CE Marking for Class IIb medical X-Ray products CE Marking (Conformité Européene) / CB Scheme 1
J CE Marking for vibrator personal pleasure toy CE Marking (Conformité Européene) / CB Scheme 17
JoshuaFroud CE Marking and Brexit - Product shipped to a distributor prior to the March deadline EU Medical Device Regulations 2
M Informational Design for new product safety marking for the no-deal Brexit scenario Medical Device and FDA Regulations and Standards News 1
E Safety work instruction if the equipment have the CE Marking and a Manual with safety instruction Various Other Specifications, Standards, and related Requirements 16
Z Direct Part Marking (DPM) requirements for Class II Medical Devices Manufacturing and Related Processes 0
M Medical Device News FDA Guidance - UDI: Policy Regarding Compliance Dates for Class I and Unclassified Devices and Certain Devices Requiring Direct Marking Other US Medical Device Regulations 0
J Virtual Manufacturer and CE Marking EU Medical Device Regulations 8
N CE marking for distributed product CE Marking (Conformité Européene) / CB Scheme 1
S CE Marking requirements - A Medical device with different config sold under same name EU Medical Device Regulations 0
J Class 1 CE Marking - Can this be removed from the label on the product? CE Marking (Conformité Européene) / CB Scheme 4
I Tool Control Marking Voiding Warranty AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
