CEDAC (Cause and Effect with Addition of Cards) - Sharing Experiences and Form(s)
luciano
Involved - Posts
Does sombody use CEDAC (Cause and Effect with the Addition of Carts) which wants to share his/her experience in how can use this diagram; or to share a training material ?
Thank you very much
God bless you.
W
wmarhel
Re: CEDAC (Cause and Effect with Addition Carts) - Sharing Experiences and Form(s)
Thank you very much
God bless you.
CEDAC is good tool. I've used it before in a number of instances and it worked will. It is a structured way to problem solve, brainstorm and then gain consensus on a solution.
Unfortunately, all the charts and training material I have are copyrighted by Productivity Inc so I'm unable to share them. My suggestion would be to check out eBay for a copy of the book, or check out Productivity Inc's catalog and/or European office for a suitable version.
There is no mystery or deep secrets to this and because of the simplicity it doesn't seem to scare people away. Let me know if you have any specific questions regarding the approach.
Regards,
Wayne
luciano
Involved - Posts
Regards,
Wayne
Hello, and many greatings.
I am trying to translate in my best possible English.
I found in my language two pages about CEDAC. It’s a part of that.
STEPS:
1. Project start: management choose a situation for improvement, a time line and a train responsible which have the responsibility to update the board and “play” the leadership roll.
2. It’s making CEDAC board, which will be posted in a visible area and will be add up
3. the problem will be define in one phrase
4. the effect will be define and follow on a chart
5. the measure of the effect will be define (frequency, size, responsible, …..)
6. assign the objective (quantity, and date of project end)
7. determine the regulations for method
8. 3-5 persons will choose the main chausses (possible 5M)
9. the “facts” will be posted when are collected
10. “ideas for improvement” received from participants will be posted
11. the group will meet together to select improvement ideas
12. will be perpetuate the activity : facts – proposed ideas – selected ideas, until the goal it’s achieved.
13. the CEDAC group will elaborate a new procedure, which is necessary to be simple, visible (chart) and all interested people are informed to applying the new standard
14. a indicator allow to follow this adhesion and inform the personal
another point in my pages are: Follow the implementation: every improvement idea its marked:
a. in progress
b. in application
c. in waiting
d. out of subject
I don’t undertend the diferece between a. and b
QUESTIONS:
Which situations are proper for CEDAC improvement?
CEDAC is open for all employees?
In my pages it’s nothing about brainstorm and then gain consensus on a solution.
I found this method in a book and I want to implement it in my factory. But it’s a very short explanation ust two pages
Thank you very much for your time
I hope you will understand my poor English.
Best regards,
W
wmarhel
Practically anywhere a problem exists, CEDAC can be used.
I'm familiar with the 9-step process.
1) Organize the team
Define the process by which the group structure, behavorial guidelines, goals and norms are finalized.
2)
Define the project
The reason for this particular improvement project is clearly stated and a measurable outcome is identified.
3) Establish a baseline
Process by which the team gathers data (statistical and anecdotal) about the possible causes of the problem.
4) Collect the "facts"
The team collects as many facts as possible.
5) Sort and organize
The team sorts and categorizes all the collected facts.
6) Develop improvement ideas
The team proposes ideas for corrective action based on the facts posted (brainstorm).
7) Select, test, adopt ideas
Team selects and idea, tests and proves its reliability, and adopts it as a standard.
8) Standardize
Formalize a solution into a reliable method that will produce a consistently good result.
9) Sustain gains
Process by which a team ensures adherence to the stand it just created.
Project definition can be typically one of the harder aspects as all too often the project is defined too loosely and it run in all sorts of directions.
See the attached Word document. My suggestion is to create a file based on the attached file and print out on plotter paper. The print out should be large enough for you to tape onto the wall and use the small yellow and blue post-it notes as well as write on it (just be careful the marker doesn't bleed through onto the wall). No need to get fancy with computer diagrams or such, use post-its, and digital photos in some cases.
Wayne
luciano
Involved - Posts
Hello Wayne,
Thank you very much for your help.
Very precious informations
Just one question to step 6: Why just a team can propose ideas for corrective action ? It's not more efficacious to open CEDAC to a large group of employees to ghater improvements idea, and the team select, test, (step 7) andalso propose ideas ? For exemple can be posted in a work area if the problem is specific for that work area ?
Best regards.
Have a nice day.
W
wmarhel
The larger the group, the more difficult it can be to reach an agreement. The problem-solving team should of course already include people from the area or process that is affected. CEDAC is meant to be a focused problem solving tool, if people need to be brought in at various stages, that is fine.
Something to keep in mind with all any method or approach is that it may require a little modification for your needs and/or company's culture. At the end of the process, if it doesn't look exactly like what's depicted in the book, yet yields positive benefits then you did the right things.
Best of luck,
Wayne
There's a book here that was written by the developer of the CEDAC idea. I can't personally vouch for the book or the process.
BTW, someone should edit the thread title to read "Addition of Cards" instead of "Addition Carts."
Shekhar
Re: CEDAC (Cause and Effect with Addition Cards) - Sharing Experiences and Form(s)
Dear Members,
I have used this tool in my earlier co. wherein nine CEDAC projects worked on different problems. I can share the following details :
CEDAC
Background
• CEDAC stands for Cause and Effect Diagram with the Addition of Cards;
• CEDAC is a visual, team-oriented problem solving methodology developed by Dr. Ryuji Fukuda.
• In 1978 he was honored with prestigious Deming Prize for this contribution to the field of productivity and quality improvement.
• CEDAC has been used extensively in Japan, USA and Europe with excellent results.
Dr. Fukuda’s message
• Management is a practical science.
• A Company must continuously improve its health in order to overcome competition.
• To achieve this, it is important for each person constituting the company to have a mechanism that enables him/her to always make progress on his/her own accord in daily work.
To summarize ………….
CEDAC is useful for organizational improvement for the following reasons:
• It orients all the members of the organization, directs their actions by graphically presenting the project, and allows them to effectively contribute to the improvement process.
• It allows sharing of necessary information with all members, thus promoting autonomous actions.
• It encourages all individuals in the organization to use their strengths.
• It increases chances to generate ideas that enable progress even by at least half a step, as it makes the members keep thinking.
• It integrates external knowledge and the member’s knowledge to create new ideas and technology.
• It standardizes ideas with favorable test results and accumulates them as intrinsic and management technology.
Typical Uses
It is extensively used to encourage employee involvement in shop floor problem solving and to promote small group activities. Typical applications include
For Production & Services
• Lead Time Reduction in production & services
• Inventory Reduction
• Reducing Rework / Scrap / Errors
• Increasing Yield
• Reducing Time and Cost Overruns in projects
• Cost Reduction
For Administration / Sales Offices
• Reduce Late coming / Absenteeism
• Speedy recovery of receivables
• Increase Orders to Enquiries ratio
10 Step Process
CEDAC is a systematic 10 step process as follows:
1. Problem Definition
To define the problem precisely.
2. Improvement Measurement
Methodology for measurement
3. The Target Effect
Team defines the target as per set rules.
4. Fact Cards
Based on observation at workplace
5. Analysis Cards
Breaking down the facts
6. Improvement Cards
7. The Three Dot Marking System
8. Implementation Plan
9. Standard Card
Which has been implemented to yield positive results
10. Adherence
Through Control plans / Work Instructions, Poka yoke devices & FMEA
Each step requires a no. of tools & rules to be followed.
Typically in one organization where Nine CEDAC projects were run could get the following benefits :
1. Total Elimination of two customer complaints through two projects.
2. Saving of Rs. 58 lacs through seven projects.
marketa
Hello Wayne,
I read discussion of CEDAC and I'd ask you, in which companies and in which year did you last used the method CEDAC (if you provide this information). I wonder if this method is still used because the original publication by Dr.Fukudy is almost 20 years old.
I apologize for my bad english
Thank you for your response
Best regards
Marketa
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 5
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
Q Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
S. Moore Technical or Systemic cause for 8D Nonconformance and Corrective Action 7
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Risk Analysis - Events which may cause to Data Loss ISO 14971 - Medical Device Risk Management 12
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
Marc IAQG-OASIS - 9101:2016 Form 4: Cause Code Listing Now Included in Form AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 39
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V Corrective Action for a scenario where Assignable Cause is not confirmed Nonconformance and Corrective Action 4
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
N Root Cause Challenge: The guy at the top ... Problem Solving, Root Cause Fault and Failure Analysis 4
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
H Cause analysis for an Audit Finding - Purchasing Procedure Content ISO 13485:2016 - Medical Device Quality Management Systems 9
somashekar Amtrak crash ... Any news about the cause World News 3
P Is it a rule to fill in all the 5 why in order to get the actual root cause? Quality Tools, Improvement and Analysis 5
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
H Root Cause Corrective Action Examples Nonconformance and Corrective Action 4
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
R Root Cause for "Simple" External Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
U-DOG Root Cause for a Form not having all info (traceability standard and the gage number) Problem Solving, Root Cause Fault and Failure Analysis 14
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
Chennaiite Cause Analysis for Verification/Validation Failures - Seeking Opinions Problem Solving, Root Cause Fault and Failure Analysis 3
bobdoering Is tool wear a special cause? No... Imported Legacy Blogs 0
J Root Cause Determination Training for Production Managers Nonconformance and Corrective Action 6
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
C DFMEA vs. PFMEA Relationship: The cause in DFMEA becomes Failure in the PFMEA FMEA and Control Plans 2
