Centrifuge Calibration using Photo Tachometer - SOP Needed
Mohammed Gouda
Dear Sirs,
Please i need to help me about you try to found to me the SOP for the
calibration of the Centrifuge using photo tachometer, but please must be based on the international reference.
Thanks.
Best Regards,
Hershal
Metrologist-Auditor
Folks may not be able to post specific procedures here regarding this, but those who are more knowledgable should reply shortly.
Marc
This may end up being such a specialized type of calibration that few, if any, visitors here will be able to help with. I would expect the manufacturer of the centrifuge to have some type of recommended procedure.
BradM
Hello Mohammed!
As far as an international standard, I am unaware of such an item. Most procedures I have seen for a centrifuge are home grown, and are based on specific mfg. specifications.
There are many different centrifuges; notably ones with a speed display, and ones without a speed display. There is typically a temperature indicator which may need to be verified also.
Most of the time what I have seen is 1 of 2 test setups. First, a disc or a fixture is attached to the main spindle with a piece of reflective tape on it. Usually, you will probably want to use clear tape to hold the reflective tape, due to the high speeds sometimes throwing the reflective tape off. Second, you can find a place on the shaft and attach the piece of reflective tape (again, with clear tape on top of that). Then using a hand-held tachometer, one can measure the RPM of the centrifuge. That reading is then compared to the display, or the mfg. specification for the speed is verified (within appropriate tolerance range).
The temperature could then fall into removing the sensor and placing into an appropriate test environment, or placing a standard probe next to the centrifuge temperature probe and compare.
This is fairly general for calibration. The instruction manual for the centrifuge is really your best bet. Along with calibration, there are maintenance checks for the motors, gaskets, and other parts on the centrifuge.
Depending on the mfg., many have service manuals for the equipment you can purchase. They are not cheap, but may give you the help you need.:D
Hope that helps.:)
arios
Hi Brad
Let me please take advange of your experience for a question I have had for a long time with regards to testing using tachometers, and sorry for asking if this question has an obvious answer, but at least it does not for me yet:
How can we deal with the harmonics? I mean, Wouldn't a shaft rotating at 60 r.p.m. appear the same as another one at 120 r.p.m. when testing with a tachometer? This assuming that we are targeting for finding 60 r.p.m.
Please provide me with some clarification when you have an opportunity. This may be a useful consideration for a calibration SOP as well
Gracias! Thanks!
Alberto
BradM
Hi Brad
Gracias! Thanks!
Alberto
Hello, Alberto! :bigwave:I'm not sure what you mean. I have never observed any such problems. It does take a while to get the initial setup working correctly; getting the tape in the right place and such. On some applications, I would put black tape on first, then the reflective tape.
arios
Thanks Brad
What I meant with the question is how to differentiate a rotating speed that is a multiple of the other. That is what I call harmonics. Using a tachometer I will se a "white" spot on the same point regardless if it is rotating at 120 or 60 r.p.m.. How can we tell which is which
I hope this helps. See'ya!
Alberto
BradM
Thanks Brad
Alberto
I think I know what you're talking about. There is some inconsistency in the approach. Typically, it may take a little bit to stabilize to the correct reading.
alexandrunelu
Hi Brad
Gracias! Thanks!
Alberto
Hello, I've noticed that if you have, for example, a spinning object at 60 rpm and you have set the stroboscope at 120 rpm, in case you can observe the whole area of the spining object you will see a double image of the mark (initial mark made on the spinning object for better observation), if you increase the flash frequency at 180 you will see 3 images of the mark and soo on. as a conclusion for an adequate measuring you have to see an unique stand still image of the mark
K ISO 15189, QA & how to calibration for Balance, refrigerator and centrifuge? Qualification and Validation (including 21 CFR Part 11) 5
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
R Performance Qualification on a Table Top Centrifuge ISO 13485:2016 - Medical Device Quality Management Systems 3
B Health Informatics ISO 11073 - Centrifuge Device Requirements EU Medical Device Regulations 1
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
