Certificate for In-House Calibration
BradM
A poster had asked some questions regarding in-house calibrations, and I inadvertantly deteled the post. Sorry!:eek:
Anyway, it was a pretty good question, so I figured it would build our BOK here at the Cove. I am going from memory, here, so I may have missed a few things here and there.
This particular facility performed in-house calibration using gauge blocks that are calibrated by an external source. There are several micrometers, calipers, etc. that are verified. Questions:
1. Do these instruments require a certificate of calibration?
2. What information is required on the certificate of calibrations?
2. Do the measurement uncertainties need to be listed?
If I remember correctly, the poster was nearing an external ISO 9001 audti, and was worried about getting an NCI for the calibration.
Your thougths and suggestions, please.
BradM
IMO, if you are performing calibration/verifications, they should be documented. I would think you need to have a certificate of calibration. This would list the calibration date, possibly due date, standards used (and their relevant information like due date ID#), procedure, data, who performed the calibration, and possibly a reviewer (if that is required).
As far as listing the uncertainty, I would expect that an analysis has already been performed, and that information can be put on the certificate. If no analysis has occurred, minimally I would think the accuracy rating of the gauge blocks and the required instrument accuracy should be listed on the certificate. You will want to assure you at least have a 4 to 1 ratio for accuracy.
Also, the as-found as-left data should be recorded. I'm not sure about any of the other Covers, but a certificate of calibration without any data just seems of such little value.
Finally, you will want to list the environmental conditions on the certificate, if they could impact the measurements. I would think for gauge blocks, they could affect the readings. Thus, temperature and humidity should be monitored.
Whatever you put on the certificate, I would not put anything on there you are not familar with, or that you don't understand.
Anyone else with some feedback on in-house certificates of calibration?
madannc
My thoughts
#1 No but a record of them being checked with the calibrated blocks (which do require COC) is required
#2 The blocks COC should they have been tested to traceable standards and each block must be uniquely identified and a calibration schedule/frequency established, and an expiry date for COC. The record that is used internally will have schedule for checking calibrators (either one sheet for all that has column for equip no. or one record for each peice of equip which ever is easiest to manage) and which block was used to check equipment.
"Life is not measured by the number of breaths we take, but by the number of times our breath is taken away"
#3 Not sure what the question is asking? tolerances will be recorded as in an acceptable std e.g. between 0.0001 and 0.0005 is acceptable tolerence and the the block's actual will be recorded e.g 0.0002
BradM
Great response, BTW. I hope to see you contributing to the Cove more.
I believe the gauge blocks are calibrated by an external lab.
The original poster was inquiring about what information should go on a certificate of calibration. So for example, would you put the measurement uncertainty, standard accuracy, U.U.T., accuracy, etc.?
E
Esthyl - 2010
Hi Brad,
Thanks for your suggestions! FYI, I am the one who put up the poster :)
The questions stated are quite close to mine though. Additional is:
How could I justify whether the calibrated inspection instruments passed or failed? Referring to the std, eg. BS 870:1950 (for outside micrometer)? Micrometers, digital calipers and height master that we have can be reset / adjusted to zero.
Madannc, thanks for your suggestions as well! By the way, is COC means Certificate of Calibration?
Q#3 --> I would like to know if I am suppose to include uncertainty of measurement into the In-house calibration cert (as certificate of calibration by ext. agency did); so that the cert is reliable. However, what would be the tolerance? Is there any thumb of rule?
I would like to improve on the in-house cert of cal. Hopefully anyone who has experience in dealing with in-house calibration is willing to share with me. Thanks....
BradM
Hi Brad,
I'm glad you checked back in and found the new thread. I'm sorry about shooting away your other one. I learned what I did wrong, and won't do that anymore.:whip:
I'm not sure if I follow you on this one. Are you asking how you determine if the device has passed or failed? Yes, some instruments can be set to zero, and usually that is considered part of the calibration adjustment. However, micrometers and calipers are a bit different. Zero adjustment is commonplace and enabled for the user. Saying, the device will need to be zeroed before reading gauge blocks (just as you would zero before reading material). Then, either by mfg. specifications, customers specifications, or other, you will determine the accuracy of the device and if it passes or fails.
Either you have performed uncertainty analysis or you haven't. If you have, then that information would be relevant, and should go on the certificate of calibration. If you haven't, then you won't have that information to place on the certificate.
Have you performed a gauge R&R? Are you sure what your capabilities are? What class of gauge blocks do you have?
Do you have a environmentally controlled lab to perform these calibrations? I'm just seeing how far along you are in all of this.
madannc
Hi Brad,
Apa Kaba Esthyl
COC = Certificate of Calibration (just me being lazy)
When you say in house calibration be clear about what you are doing, checking the micrometers with a calibrated standard is just that confirming that the micrometer is within the tolerences acceptable. Calibration is altering or modifying internal settings to be a calibrated std. in the case you are describing I think you are just checking the equipment is acceptable... if it did not meet your acceptance level presumably you would send off for repair or buy a new one?
A calibrated std such as the blocks is used to provide objective evidence that the equipment (micrometers) you are using are acceptable... in other words you use the micrometer to perfom checks on devices you make and have confidence that the measurements taken by the micrometer are valid.
You are not using the micrometer as a calibrated std but as a tool to perform a job.
Hershal
Metrologist-Auditor
Actually, calibration is a comparison that is traceable to National or international standards.....a perfect calibration does not involve adjustment at all.....
However, even for internal cal, if you want it to be traceable, it must include the specific documeted path for traceability (e.g., the certificate number of the gage block calibration - NOT the so-called NIST numbers), and the uncertainty. Miss either of the two and the calibration is not traceable, and simply becomes verification.
Hope this helps.
E
Esthyl - 2010
Hi BradM & Madannc, thanks for your suggestions for carrying out in-house calibration and COC. Meanwhile, I have asked a ISO consultant for opinion on the In-house calibration and COC. She came back to me that we can have in-house calibration, but we cannot produce COC as we are not SAMM certified. In-house calibration merely means those MMDs are VERIFIED
FYI, our company is implementing ISO 9001:2000 QMS. My concern is --> is it all MMDs in the factory should be calibrated? Our company is small with around 10 ppl, we can't afford to send out all MMDs for calibration and have another spare set while MMDs sent out for calibration; we do in-house calibration. On the other hand, we sent only all MMDs used by QC Technician for external calibration.
Is this approach acceptable for ISO 9001:2000 QMS?
BradM
I am intrigued by this SAMM. Can you give me a little more information?
Hershal is one of the foremost experts (IMHO) on calibration. Let me encourage you to go to him name, and search through his last 100 or so posts. It will really be beneficial to you.
Most everyone else here is quite good too (except me, I'm just their agent:tg:). You have an appropriate standard, a decent procedure, the right numbers... You have a calibration. I hope you know what I mean. I just want to suggest a middle ground, reasonable approach. Calibration (and CoC) is not something everyone can do, and not something too difficult for anybody. Make sense.
As far as ISO 9001 is concern, the system is yours to decide. Basically, if it is an instrument utilized for impact, quality decision, measurement, etc., it will need a verification/ calibration, etc. to determine fitness for use. You will need to establish a program to ensure the equipment is adequately calibrated, and fit for use.
Please, I don't mean to come across too strong, so forgive me if it does. But... if you're company cannot afford a good calibration program, it needs to re-evaluate being in business (or at least going into an ISO initiative). If you are MFG. a product and you have instruments for quality assessment, IMO it's pretty important that they be accurate.
How many instruments are we talking about, and of what kind? I bet if you added it all up, you would save money sending it out for calibration. So I don't bore you do death, search on the Cove for internal calibration, and you'll find some detailed analysis by several people here.
Ok, enough of my rambling. I hope there's something here to help you.
J In-House Calibration Certificate wording - Confidence Level or Level of Confidence? Document Control Systems, Procedures, Forms and Templates 3
V Who should sign the Certificate of Attendance for In-House Training Training - Internal, External, Online and Distance Learning 7
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
S Certification Body Changeover - Transfer of Certificate Registrars and Notified Bodies 9
J How to keep MDD certificate valid when legal manufacturer has liquidity problem EU Medical Device Regulations 0
D ISO 17021 Certificate Registrars and Notified Bodies 1
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
Louddogsbark When your 13485:2016 certificate has been pulled ISO 13485:2016 - Medical Device Quality Management Systems 2
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
U Certificate of Free Sale Other US Medical Device Regulations 7
A Scope of ISO 13485 certificate ISO 13485:2016 - Medical Device Quality Management Systems 1
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
E Adding models to an approved Russian Registration Certificate Other Medical Device Regulations World-Wide 1
S Philippines CMDL (Certificate of Medical Device Listing) Elsmar Cove Forum ToS and Forum Policies 0
A Is it mandatory to obtain ISO13485 certificate prior to CE marking? EU Medical Device Regulations 8
R External Audit and Certificate prorogation due to the pandemic General Auditing Discussions 10
A How to make sure whether the predicated device is marked with EC certificate? EU Medical Device Regulations 8
I Is the contract mfg. mentioned in legal manufacturer EC certificate? CE Marking (Conformité Européene) / CB Scheme 4
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Certificate Suspension? Shut down due to Covid-19 IATF 16949 - Automotive Quality Systems Standard 14
L Appears to be a certificate mill certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
J CE Certificate and additional processing EU Medical Device Regulations 4
bryan willemot Chemical / physical certificate of conformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B IATF certificate suspended - Who do we notify? IATF 16949 - Automotive Quality Systems Standard 6
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
H What is different between PED certificate and CPR certificate? Manufacturing and Related Processes 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
M How to read a calibration certificate for thermo hygrometer General Measurement Device and Calibration Topics 2
V Calibration certificate verification Qualification and Validation (including 21 CFR Part 11) 3
A Calibration Certificate Results General Measurement Device and Calibration Topics 3
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
E Calibration Certificate Content Requirements General Measurement Device and Calibration Topics 3
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S Boeing D6-51991 Product Acceptance Software certificate and Artefact? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J COC (Certificate of Conformity) when NOT purchasing medical devices direct from the Manufacturer Other Medical Device Related Standards 2
P List of ISO certificate registrars around the world - ISO certification databases ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
F EC in EC certificate - Is it an EC Certificate or a CE certificate? CE Marking (Conformité Européene) / CB Scheme 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
R Certificate of compliance to RoHS/REACH/WEEE - any such animal? REACH and RoHS Conversations 18
D CB Certificate - Distributor for a product with electrical components CE Marking (Conformité Européene) / CB Scheme 4
P Non-Active Suppliers on CE Certificate EU Medical Device Regulations 2
A Interpretation of Article 16 (2b) - Packaging, samples and Certificate EU Medical Device Regulations 10
R List of countries that require only CE Mark certificate for product registration Other ISO and International Standards and European Regulations 2
K CFG (certificate of foreign government) Requestor Other US Medical Device Regulations 0
