Certificate of calibration from Manufacturer allowed?
A6Intruder
#11
I always used the manufacturer's cert; I paid for calibration to NIST, and never had an issue with any auditor. One side note: I also found it cheaper to buy a new caliper, scale, dial indicator than to have the old ones cal'ed each year. so each year there were old tools sent home; employees were ok with that for garage work, so I boosted morale, had cal'ed tools in the shop and saved money.
SpinDr99
#12
I agree with Hershal. I've NEVER used the generic "certificate" from a manufacturer. They usually don't say more than they comply with their requirements. I can't ever see how a third party auditor would accept that. I've always had a gage block set and would either pay to have them calibrated when purchased, or calibrated the instrument (whenever possible) myself. Even when the boss would complain about cost, I found the lowest cost calibration service that could provide traceability, and justified it by explaining it's cheaper than having a number of instruments with the manufacturer's "cert" and having the opportunity for a major finding during an audit.
howste
Thaumaturge
#13
The problem with this scenario is that you'll never know if a tool goes out of tolerance some time before you dispose of it. If you calibrate/verify the tool periodically it shows evidence that the tool was suitable for use during the previous period. If you replace the tool without checking it then it could have gone out at any time during the year and you'd never know.
qualprod
#14
If you are 9001, it is supposed instruments have to be calibrated by a reliable supplier, it is expected having 17025, when you say "little " what do you refer to?
dwperron
#15
All of these calibration "requirements" depend on what standards you are being held to.
The ISO 9000 series, including AS9100 and such, has the simple requirement:
"Where necessary to ensure valid results, measuring equipment shall be calibrated or verified, or both, at specified intervals, or prior to use, against measurement standards traceable to international or national measurement standards"
Nothing about reliable, nothing about 17025. Just a traceable calibration. I know that according to the VIM that means an accredited calibration with uncertainties, but the real world just requires that you are able to show traceability.
Thus, those little certificates that come with equipment may be adequate to use. ISO 9001 doesn't require much except the traceability statement.
In the ISO 10012, 17025, 13485, ANSI Z540 , etc. worlds then the calibration requirements get much stronger. Accredited calibrations with uncertainties, reports with required information, stuff like that. But most people do not work in those worlds.
Also, Howste nailed it in stating that replacing your tools with new ones is bad mojo: what if the tool has gone out of tolerance and you just hand it off to someone to take home. You would never know you had an OOT condition. That's the same as never having it calibrated in the first place!!!
It is mandatory to calibrate / verify all calibrated items when they are put into service and when they are taken out of service.
E Calibration - Manufacturer's Calibration Certificate Date ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
M How to read a calibration certificate for thermo hygrometer General Measurement Device and Calibration Topics 2
V Calibration certificate verification Qualification and Validation (including 21 CFR Part 11) 3
A Calibration Certificate Results General Measurement Device and Calibration Topics 3
E Calibration Certificate Content Requirements General Measurement Device and Calibration Topics 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
G Is the calibration due date of equipment used to be on calibration certificate ISO 17025 related Discussions 38
G Calibration Certificate, fancy paper or not? General Measurement Device and Calibration Topics 9
T Calibration Certificate Readings After Adjustment General Measurement Device and Calibration Topics 5
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
M ILAC Regulations - Expression of Units on the Calibration Certificate General Measurement Device and Calibration Topics 6
A Coverage factor in calibration certificate for a multimeter General Measurement Device and Calibration Topics 4
N Client Request for Reference Equipment Calibration Certificate General Measurement Device and Calibration Topics 3
T Microsoft Access Database to create a Simple Calibration Certificate General Measurement Device and Calibration Topics 6
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
T Uncertainty in Hygrometer Calibration Certificate General Measurement Device and Calibration Topics 4
O How can I use reading from calibration certificate in measurement Calibration Frequency (Interval) 7
K New Gauges calibration certificate shows deviations from the measurement uncertainty IATF 16949 - Automotive Quality Systems Standard 5
Q Can we go by different Calibration Frequency vs. What's on the Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Torque Tester Calibration Traceability and Certificate question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S No Calibration Due Date on a Calibration Certificate unless requested by a customer? Calibration Frequency (Interval) 9
P Rounding Uncertainty to Zero on a Calibration Certificate Measurement Uncertainty (MU) 7
N Calibration Lab unable to issue Accredited Certificate when error is too high? General Measurement Device and Calibration Topics 3
S How to Evaluate a Calibration Report Certificate General Measurement Device and Calibration Topics 8
R LCP 01201P and ICPF2P Calibration Methods Stated in Calibration Certificate General Measurement Device and Calibration Topics 2
M ILAC p14:12/2010 - Accredited Calibration Certificate Uncertainty General Measurement Device and Calibration Topics 2
A Can any organization issue a Calibration Certificate? General Measurement Device and Calibration Topics 5
A No Uncertainty Listed on Calibration Certificate: Is it traceable calibration? General Measurement Device and Calibration Topics 8
M External Calibration Certificate Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Calibration Certificate Requirements for Pressure Gauges General Measurement Device and Calibration Topics 9
A Fluke Digital MultiMeter Calibration Traceability and Certificate General Measurement Device and Calibration Topics 11
S Reference to original Calibration Certificate - ISO 17025 Section 5.10.9 ISO 17025 related Discussions 4
howste Calibration Certificate Contents: How to report Measurement Uncertainty? Measurement Uncertainty (MU) 18
C Accredited Calibration Certificate Content - ISO 17025 Section 5.10.4.2 Question ISO 17025 related Discussions 7
D Calibration Certificate - 'test report shall not be reproduced except in full' General Measurement Device and Calibration Topics 2
howste Condition of Item Calibrated - ISO 17025 Clause 5.10.2f - Calibration Certificate ISO 17025 related Discussions 13
C Interpreting Outside Laboratory Calibration Certificate Measurement Uncertainty (MU) 3
A Calibration Certificate content for New Equipment General Measurement Device and Calibration Topics 8
R What to do after I receive a calibration certificate General Measurement Device and Calibration Topics 4
S Verification of calibration certificate Miscellaneous Environmental Standards and EMS Related Discussions 1
B ISO 17025 logo & ISO 9001 logo on calibration certificate/report ISO 17025 related Discussions 7
P Certificate of Calibration Suppliers for an ISO 9001 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Validity of 7 Year Old Calibration Certificate General Measurement Device and Calibration Topics 19
BradM Certificate for In-House Calibration General Measurement Device and Calibration Topics 25
Wayne Never put an Expiration (Due) Date on a Calibration Certificate Calibration Frequency (Interval) 41
J In-House Calibration Certificate wording - Confidence Level or Level of Confidence? Document Control Systems, Procedures, Forms and Templates 3
A Measurement uncertainity is not mentioned in the calibration certificate Measurement Uncertainty (MU) 4
