CFAT (Component First Article Test) - Requirements and Information
5
56flh
I did a search on CFAT and came up blank so I hope this is the correct place to post this thread.
I am in the middle of setting up testing for a part to be supplied to the military and they have required a CFAT Test Plan, a seven page document that describes the test I am going to perform on this first article (plus verification of all print notes) along with the date of the test, and, once the test is completed, the Test Report that is to be completed within 50 days of the test. My plan was approved and I have been informed the test does not have to be observed by a government rep. The test will be performed without a problem so that is not my concern.
In the template instructions for completing the report once the test has been completed, there are directions that indicate the format/numbering system must be maintained, etc...etc...or the test report will be failed and you start the entire process over. What I'd like to know is if anyone here has completed a CFAT report in the past and could steer me to an example of a completed report. I'm looking for something I can use as a guide.
I've done PPAPs and ISIRs but this CFAT thing is a whole new animal for me.
Marc
Re: CFAT Component First Article Test
Are you referring to a Customer Factory Acceptance Test?
5
56flh
Thanks Al, that is exactly what I was looking for.
After going through this exercise I understand why hammers and toilet seats are as expensive as they are for the military.
jh23j0b
I've had the same difficulty in trying to find information on the web about CFAT plans and reports. In fact, when I saw the originating thread this morning, I wondered if I was the one who posted it because it is exactly the problem I'm having right now! The core of my problem is the set-in-stone outline numbering system. If there is only one test, then I can use the outline just fine, but I have four different tests that will naturally stretch the outline. Did you (56flh) successfully finish your CFAT report? If so, I'd love to see it.:frust:
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
D Standard guide for shelf life determination of non sterile component with degradation materials Reliability Analysis - Predictions, Testing and Standards 1
F Component Molding and Over-molding - Handling Resin Inventory Manufacturing and Related Processes 2
S REF and CE mark symbols on multi-component device EU Medical Device Regulations 3
J EC REP information and CE Mark - Component of a system that is not a medical device EU Medical Device Regulations 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
S Medical Device Supplier Component Qualification Service Industry Specific Topics 0
A Is a Manufacturing Process Sheet required for each Component? Manufacturing and Related Processes 4
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
I Medical device manufacturer and component supplier miscommunication Other Medical Device Related Standards 5
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
B Non Applications in ISO 13485:2016 for component contract manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 3
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
M Cleanliness and Contamination question (Medical Device Component Manufacturer) ISO 13485:2016 - Medical Device Quality Management Systems 2
M Component Manufacturer of Food Stuffs Mfg. Equipment Parts - Eat Drink Policy ISO 13485:2016 - Medical Device Quality Management Systems 1
E Updating DHF (Design History File) to include Alternative Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 13485 Definitions - Medical Device Component Supplier ISO 13485:2016 - Medical Device Quality Management Systems 4
M ISO 13485:2016 - IQ/OQ Requirements applicable to Electronic Component Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 4
MDD_QNA Medical Device PCB component change IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R Is pre-conditioning supplier component before incoming inspection tests allowed? Quality Manager and Management Related Issues 16
M Component Lot Number Traceability - Class I reusable and "resposable" Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 10
R USB power between Medical Device Data Collection Device Component IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
O What is the definition of d.c component in standard IEC 60601-2-10? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Who's name should be on component certification? Other ISO and International Standards and European Regulations 2
R RoHS Compliance Problem with One Component RoHS, REACH, ELV, IMDS and Restricted Substances 5
J Biocompatibility Evaluation component other than Testing Other Medical Device Regulations World-Wide 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
V AQL for Component Level and Assembled Finished Product AQL - Acceptable Quality Level 1
alonFAI Solderability test and component's life expectency Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R ERAI - Counterfeit Component Database (Listed on page 39 of AS5553A) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
