Informational CFR 21 Definition for Data or Raw Data
ChemistAnalytical
I'm having trouble finding a definition for data per CFR 21. Specifically in regards to nonclinical studies or cGMP manufacture.
For context, I'm working on a risk assessment of a dissolution instrument.
Best regards,
Chemist
ChemistAnalytical
Found an adequate answer:
Guidance for Industry
Good Laboratory Practices
Questions and Answers
US Dept of Health and Human Services
FDA, ORA 1981
Page 4
Raw data is defined as "any laboratory worksheets, records, memorandum, notes that are the result of original observations and activities and are necessary for the reconstruction and evaluation of-the report of that study."
Marc
Sorry you didn't get an answer when you posted. Thank you for coming back and letting us know what you found.
v9991
also look out for other definitions of raw data in data integrity guidances.,
DATA:-
MHRA - Information derived or obtained from raw data (e.g.a reported analytical result) Data must be:
A - attributable to the person generating the data
L – legible and permanent
C – contemporaneous
O – original record (or ‘true copy’)
A – accurate
WHO:
data - Data means all original records and certified true copies of original records, including source data and meta data and all subsequent transformations and reports of this data, which are recorded at the time of the GxP activity and allow full and complete reconstruction and evaluation of the GxP activity.
Data should be accurately recorded by permanent means at the time of the activity. Data may be contained in paper records (such as worksheets and logbooks), electronic records and audit trails, photographs, microfilm or microfiche, audio or video files or any other media where by information related to GxP activities is recorded.
Metadata :-
FDA :-
Metadata is the contextual information required to understand data. A data value is by itself meaningless without additional information about the data. Metadata is often described as data about data.
Metadata is structured information that describes, explains, or otherwise makes it easier to retrieve, use, or manage data.
Among other things, metadata for a particular piece of data could include a date/timestamp for when the data were acquired, a user ID of the person who conducted the test or analysis that generated the data, the instrument ID used to acquire the data, audit trails, etc.
MHRA :-
Metadata is data that describe the attributes of other data, and provides context and meaning. Typically, these are data that describe the structure, data elements, inter- relationships and other characteristics of data. It also permits data to be attributable to an individual.
Example: data 3.5 and metadata, giving context and meaning, are: sodium chloride batch1234, 3.5mg. J Smith 01/07/14
Metadata forms an integral part of the original record. Without metadata, the data has no meaning.
WHO :-
Metadata are data about data that provide the contextual information required to understand those data. Typically, these are data that describe the structure, data elements, interrelationships and other characteristics of data. They also permit data to be attributable to an individual.
For example, in weighing the number 8 is meaningless without metadata, i.e. the unit, mg. Other examples of metadata may include the time/date stamp of the activity, the operator ID of the person who performed the activity, the instrument ID used, processing parameters, sequence files, audit trails and other data required to understand data and reconstruct activities.
PRIMARY RECORD :-
The record which takes primacy in cases where data that are collected and retained concurrently by more than one method fail to concur.
In situations where the same information is recorded concurrently by more than one system, the data owner should define which system generates and retains the primary record, in case of discrepancy.
The ‘primary record’ attribute should be defined in the quality system, and should not be changed on a case by case basis.
Risk management principles should be used to ensure that the assigned ‘primary record’ provides the greatest accuracy, completeness, content and meaning.
For instance, it is not appropriate for low-resolution or static (printed/manual) data to be designated as a primary record in preference to high resolution or dynamic (electronic) data. All data should be considered when performing a risk based investigation into data anomalies (e.g.out of specification results)
ORIGINAL RECORD :-
MHRA :-
Original record: Data as the file or format in which it was originally generated, preserving the integrity (accuracy, completeness, content and meaning) of the record, e.g. original paper record of manual observation, or electronic raw data file from a computerized system.
True Copy: An exact verified copy of an original record. Data may be static (e.g. a ‘fixed’ record such as paper or pdf) or dynamic (e.g. an electronic record which the user/reviewer can interact with).
Example1: a group of still images (photographs – the static ‘paper copy’ example) may not provide the full content and meaning of the same event as are recorded moving image (video – the dynamic ‘electronic record’ example).
Example2: Once printed or converted to static .pdfs, chromatography records lose the capability of being reprocessed and do not enable more detailed viewing of baselines or any hidden fields. By comparison, the same dynamic electronic records in database format provides the ability to track, trend, and query data, allowing the reviewer (with proper access permissions) to reprocess,view hidden fields,and expand the baseline to view the integration more clearly.
Original records and true copies must preserve the integrity (accuracy, completeness, content and meaning) of the record. Exact (true) copies of original records maybe retained in place of the original record (e.g.scan of a paper record), provided that a documented system is in place to verify and record the integrity of the copy.
It is conceivable for raw data generated by electronic means to be retained in an acceptable paper or pdf format, where it can be justified that a static record maintains the integrity of the original data. However, the data retention process must be shown to include verified copies of all raw data, metadata, relevant audit trail and result files, software/system configuration settings specific to each analytical run*, and all data processing runs (including methods and audit trails) necessary for reconstruction of a given raw data set. It would also require a documented means to verify that the printed records were an accurate representation. This approach is likely to be onerous in its administration to enable a GMP compliant record.
Many electronic records are important to retain in their dynamic (electronic) format, to enable interaction with the data. Data must be retained in a dynamic form where this is critical to its integrity or later verification. This should be justified based on risk.
*computerized system configuration settings should be defined, tested, ‘locked’ and protected from unauthorized access as part of computer system validation. Only those variable settings which relate to an analytical run would be considered as electronic raw data.
its interesting through about the relevance of raw data definition with the original post on risk-assessment of dissolution instrument.
http://ncs-conference.org/download/...400_1530_bayesian_approaches/2_Coppenolle.pdf
Dissolution Method Development for Fixed-Dose Combination Drug Products – Challenges and Strategies
https://www.fda.gov/downloads/Drugs/Guidances/UCM456594.pdf
The idea is to cover the activities related to development - validation vs the qualification and operation of the equipment.
Marc
@supadrai - As a lawyer you may not have touched on this before, but probably should have, and probably have but didn't think of it in this way. Law documents are much the same.
I really like this definition, one could build an entire course around it.
Not to detract from @v9991 's post above, but the above definitions go back many years. I learned them in college in chemistry and biology (we called them Good Laboratory Practices, even though Wikipedia says GLP was introduced in the US in 1978: Good laboratory practice) in the early 1970's, and in aerospace the same applied when I worked in that field in the 1980's, and in automotive when I was involved in anti-lock brake and air restraint system design & development.
Historically, this goes back to the seventeenth century, at least: Scientific method
While some things have changed, such as computers, not much has changed over the years with the exception, to some degree, of what is defined as metadata.
@v9991 - Thanks for the above as it brings a great amount of detail applicable to data in today's world.
EDIT ADD: If you ever watch a complete documentary of the ValuJet Flight 592 investigation, you will see the discovery of falsified data by airline employees. You will see this from time to time. Legally this is fraud. I myself spent 2 days with two DIA (Defense Intelligence Agency) agents around 1986 because someone complained of suspected test data manipulation. Most the tests were outsourced to Wyle test labs. Having followed what we're calling GLPs here, I could show every interconnection, every document (including original data, all outputs such as reports and data analysis). In a way, it was kind of fun. I knew everything was done correctly and it was a bit entertaining as they did the "Good Cop - Bad Cop" routine. I had worked at Sealtron as QPL laboratory manager: Sealtron Completes AS9100 Standard Audit - The complainer did get an FBI and DIA 'raid' on Sealtron, and a lot of whistle blower 'reward' money, but in the end Sealtron was only charged with "...announcing for sale QPL products on a few products which were awaiting official QPL approval papers from the DLA " (US's Defense Logistics Agency). The DIA HAD to do something to save face, so they ended up with a really stupid, expensive charge. In short, sales screwed up. Big whoop...
As an additional 'quickie', read: Piltdown Man - Fraud is fraud.
B 21 CFR 803 Definition for 'Substantial Harm" Other US Medical Device Regulations 1
S FDA Device Listing Question - "Each Device" Definition - 21 CFR Part 807 Other US Medical Device Regulations 4
A Rule for Complaint Definition - 21 CFR Part 820.3(b) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R Definition Aware Date - What's the definition of Aware Date in plain English - 21 CFR Part 803.3 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
C Definition Finished Medical Device - Definition of - FDA 21 CFR Part 820.1 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
D FDA Guidance on Computer Software Assurance versus 21 CFR Part 11 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A TUV Audits - 21 CFR 820 General Auditing Discussions 6
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
E 21 CFR 211.103 Calculation of Yield Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
Q 21 CFR 821 Medical Device Tracking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Mislabeling - Consider this an FDA notified recall? CFR 806.10 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
P 21 CFR 807.81 When a premarket notification submission is required Other US Medical Device Regulations 0
F 21 CFR Part 11 - Implicit requirements - Validation plan for a Software as a Service Other US Medical Device Regulations 1
C 21 CFR Part 11- What about handwritten signatures? Other US Medical Device Regulations 1
Z 21 CFR and Annex 11 mapping document Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ed Panek Do Cloud services require 21 CFR Part 11 compliance? Qualification and Validation (including 21 CFR Part 11) 7
QIE FDA 21 CFR Part 11 "Meaning of Signature" Other US Medical Device Regulations 6
J Business Intelligence and 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 1
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S 21 CFR 810 - Medical Device Recall Authority - Contract Manufacturing Other US Medical Device Regulations 1
S Is Adobe Sign - E-signature for QMS documents - 21 cfr part 11 compliant? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Design developer - 21 CFR 807 - do we need to register? Other US Medical Device Regulations 0
C Signature manifestations - 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 4
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
D Use of password managers on validated computer systems (21 CFR Part 11) Medical Information Technology, Medical Software and Health Informatics 2
Q 21 CFR Part 111 - Requirements for Dietary Supplement Manufacturing Water Quality Document Control Systems, Procedures, Forms and Templates 1
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K 510K statement Questions 21 CFR 807.93 - Discontinued or never released for sale US Food and Drug Administration (FDA) 0
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
R RUO audits - CFR 820.22 and ISO 13485 8.2.4 Internal Auditing 3
A Training as well as certifications for ISO 13485:2016, 21 CFR 820... Training - Internal, External, Online and Distance Learning 5
