CFR 21 Part 820.72--Have you heard of "Once Only Calibration??
MIREGMGR
#11
Re: CFR 21 Part 820.72--Have you heard of "Once Only Calibration”?
I’m concerned that this practice would not stand up to the full rigors of an audit particularly when one reads CFR 820.72(a) “Each manufacturer shall establish and maintain procedures to ensure that equipment is routinely calibrated, inspected, checked and maintained."
Maybe I'm reading this wrong, but I infer that the underlying assumption of the OP is that FDA regards "routine" as meaning "every year", or as having some other short-period meaning.
I understand that statement to require a definite periodicity, but not necessarily a short periodicity. I don't know why it would be unacceptable upon acquisition of an instrument that the manufacturer's spec or your analysis determines requires calibration and maintenance every ten years, to establish a procedurized routine for calibration and maintenance of that instrument every ten years.
The same approach would be used if the period needed to be ten minutes. Whatever period is needed, set up a procedure to make it routinely happen.
I think the FDA's point in that requirement was/is that maintenance and calibration should occur regularly and automatically, not only after it's been discovered via manufacturing bad product that something is out of calibration.
So, have a documented analysis of what the calibration/ inspection/ checking/ maintenance interval(s) need to be, then make sure that you have a procedure in place so each of those operations happens routinely.
For some instruments, I don't see why your analysis might not conclude that they need to be checked daily, inspected monthly or if check is failed, maintained never (i.e. replace if inspection failed), and calibrated once.
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C 21 CFR Part 820.184 - Label Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
R Managing Employee Training Files - 21 CFR Part 820.25 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Interpreting Process Controls - 21 CFR Part 820.70(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
S 21 CFR Part 820.40(b) Clarification on Required Document Approvers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Does FDA expect suppliers to be independently assessed to 21 CFR Part 820 ? US Food and Drug Administration (FDA) 4
A Effective Date (of Documents) issue outlined in 21 CFR Part 820.4 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
L Mobile Medical App - Understanding 21 CFR Part 820 Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
shimonv Storage of finished medical devices per 21 CFR Part 820.150 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
A Help me understand the applicability of 21 CFR Part 820.198 (Customer Complaints) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T 21 CFR Part 820.30 Design Controls for Class 1 Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
T Can I approve my own Documentation per FDA QSR 21 CFR Part 820? ISO 13485:2016 - Medical Device Quality Management Systems 1
G Original Data Copying to Maintain Compliance with 21 CFR Part 820.180 US Food and Drug Administration (FDA) 2
A Finishing Design Validation per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Difference between 21 CFR Part 820.72 and 820.70(i) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
M 21 CFR Part 820.184 Product Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T One Man Medical Devices Company implementing 21 CFR Part 820 in order to sell to US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C 21 CFR Part 820 - Question About Calibration Procedure Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Does any one have FDA 21 CFR Part 820 QSR training material? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
A Question about FDA 21 CFR Part 820.90 Nonconforming Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
D Quality Management Systems - Differences between ISO 13485, 21 CFR Part 820 & ICH Q10 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M Distributor and 21 CFR Part 820.50 Purchasing Controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
T What SOP's are needed to cover 21 CFR Part 820.70, f and g 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B FDA 21 CFR Part 820 Medical Device Audit Criteria US Food and Drug Administration (FDA) 5
S 21 CFR Part 820.198 - Complaint Files & Electronic Signature 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Q Books that have a combination of ISO 13485 and FDA Title 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 9
S Comparison between 21 CFR Part 820 and Eudralex Vol 4 US Food and Drug Administration (FDA) 3
I 21 CFR Part 820 in English - We are an `In vitro? Medical Device European company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
G Recent Updates to 21 CFR Part 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
somashekar Document Approval per Sec. 820.40 (a) of 21 CFR part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Validation Method Requirements - 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
A Rule for Complaint Definition - 21 CFR Part 820.3(b) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
N Presentation Content for Seminars related to 21 CFR Part 803 & 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Chinese Version of FDA Code 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S 21 CFR Part 820.30(h) Design Transfer Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
