CFR (Code of Federal Regulations) with Colorants
snowball852
#11
Re: CFR (Code of Federal Regulations) with Colorants help wanted
BerryBerryGud-
Were you able to get your issues resolved with FDA? We have recently received the same questions. Were you able to get the required information from your supplier? Did you end up having to run the toxilogical testing?
We are about to also contact NAMSA for input/advice. However, I'm beginning to be concerned that we chose the wrong ink.
Any help/advice/direction you (or others) can provide would be helpful. Does any know FDA's rationale for asking these questions?
Thanks!
Amy
BerryBerryGud
#12
Hi Amy,
I did indeed end up getting this issue resolved, and succeeded in getting my submission approved. We ended up needing to do a series of extractions, followed by a toxicology risk assessment. You mentioned that you will be calling NAMSA; if you get in touch with the toxicology folks there, they can guide you through this.
While I was working through this issue, I received the same question, verbatim, from a different examiner on a completely different submission for a different client. In that case I had used a colorant from a supplier (Clariant) who had a Master File for their colorant. I obtained a MAF access letter from the supplier, and I am hopeful that I will not need to go the extraction route on that one. No word yet.
I have a third project underway, and I am pre-emptively selecting a Clariant colorant because I think having the Master File is an advantage.
The word on the street is that this is a new focus area and submitters can expect to see this question.
Good luck!
:cfingers:
AnaMariaVR2
#13
Color Additives: FDA's Regulatory Process and Historical Perspectives
http :// www. fda .gov/ForIndustry/ColorAdditives/RegulatoryProcessHistoricalPerspectives/default.htm
The Chemistry of Color Additives
http :// learningcenter. nsta .org/ products/symposia_seminars/fall08/FDA/webseminarI.aspx
How Safe are Color Additives
http: // www. fda. gov/downloads/ForConsumers/ConsumerUpdates/ucm048960.pdf
Color Additives
http :// www .fda. gov/ForIndustry/ColorAdditives/default.htm
Color Additive Inventories
http :// www. fda .gov/ForIndustry/ColorAdditives/ColorAdditiveInventories/default.htm
ALL THESE LINKS ARE NOW DEAD
Julien_Baie
#14
Hi BerryBerryGud,
We recently received something similar regarding colorants. We use a black dye in our polymer matrix for a body fluid contact device that we make. We did find that our black colorant is listed under 21 CFR 74.2052 D&C Black No. 2. However it was listed only for use for cosmetics such as eyeliners.
So my question is, how do we explain that the use of the black colorant in our medical device is equally safe as the listed use as cosmetics? How do we prove this? If we cannot prove this, then what? Still need a toxicity study?
Here is the origianl comment from the 510k deficiency letter:
"You state that the polymer matrix is black in color. Please clarify, what colorants , additives , or residuals are present in the matrix by chemical names, as these components will contact an open wound/skin. Please state whether the colorants are FDA certified. If the colorants are not FDA certified ,they may require a color additive petition before the device may be cleared."
:thanx:
Julien
MIREGMGR
#15
My guess is that it will be easier for you to re-formulate your material using a colorant approved for your use-specifics, and if need be totally re-develop and test your product, than it would be to get FDA to approve a colorant petition.
Colorants are an old, nasty minefield at FDA, with much bad history. There was a time, within memory of people still working at FDA, when a number of colorants in extremely broad cosmetic, food-and-beverage-container, pharma-container and medical device use were revealed to be toxic, mutagenic, carcinogenic and the like. I'm quite sure FDA would very much like to not re-open those old files.
It's unfortunate that whoever managed your current plastics formulation wasn't cognizant that it's regulated territory.
BerryBerryGud
#17
Hi Julien,
Most of the time, the colorant that is used to produce the color black in a polymer is Carbon Black. Even though there are ostensibly medical grade versions of Carbon Black, I believe that it is considered to be a carcinogen - so you might be fighting an uphill battle. I think the fact that the colorant you used is approved for another application doesn't help you that much.
If I were in your shoes, I would probably perform some extractions to show that the colorant is bound within your polymer and doesn't come out. Then I would follow that up with a toxicology risk analysis. As I alluded in one of my earlier posts, I tried doing this risk analysis myself and it didn't fly. Then I found a board-certified toxicologist from a well known test lab who was experienced in such analyses and I had him write it for me.
I think my product had much less contact than yours; but I had several colorants including carbon black - and with the approach I am suggesting I did get approval.
I think the suggestion to just go to a "natural," i.e. colorant free, polymer is probably the most solid idea, but I understand that sometimes it can be very difficult to make such a change.
I wish you good luck.
BBG
MIREGMGR
#18
I think the technical challenge with carbon black is that it's normally produced by pyrolysis of a hydrocarbon feedstock, and the pyrolysis process is highly non-theoretical and results in all sorts of complicated carbon-hydrogen-whatever molecules being formed...and such a broad array of complicated carbon-hydrogen-whatever molecules inevitably will include molecules with biological functionality that makes them toxins, carcinogens, mutagens, teratogens and so forth.
Note that there also are iron-based black pigments, in addition to pigment-free black dyestuffs. Carbon black is not the only way to make substances black. And, I believe there are carbon blacks that are produced via processes other than pyrolysis and are essentially chemically pure, though they are much more expensive.
Of course, these alternatives to pyrolyzed carbon black might not work the same way in regard to dispersion and other process parameters, since the chemically complicated molecular mix of pyrolyzed carbon black makes it much more reactive and therefore aids dispersion and sometimes even strength.
BerryBerryGud
#19
It is precisely this complexity which has motivated me to stay away from Carbon Black in future products. For products that need to be colored, I am trying to use colorants that at least have a MAF file with the agency.
This year I had 2 510(k)'s approved where I had detailed colorant questions. On one I took the extraction / risk analysis route; and on the second I used the master file route. In the long run,the master file route is more expensive because the colorants with master files are expensive.
BBG
Julien_Baie
#20
Hello BerryBerryGud,
Thank you for your informative reply!
Here are two more questions based on what you said the other day:
1) Because our product has to be black, there isn't much choice out there. By looking at 21 cFR 73 and 74 listings, most of them are for contact lenses, sutures, or other very specific uses, which doesn't help me to decide whether the FDA will accept my selection. When you were selecting carbon black, did you try to explain to FDA that because for example DC Black No.2 is good for eye area use, it could be reasonable that it would be good for your product?
2) I saw some other organic black coloring that are listed under 21 CFR 73, such as 73.1410 logwood extract, 73.125 Sodium copper chlorophyllin, can be made into black. I wonder if those can be a substitute to carbon black. but once again, I am no polymer chemist, so I am not sure. Did you come across those?
3) you mentioned extraction study? how long does an extraction study take? how many more items did you have to do?
4) For getting an MAF file, are companies willing to give you the file? or did they just give you an authorization that FDA can look at their MAF that is on file with FDA?
:cool:
Julien
C Chinese Version of FDA Code 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D FDA Guidance on Computer Software Assurance versus 21 CFR Part 11 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A TUV Audits - 21 CFR 820 General Auditing Discussions 6
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
C 21 CFR 803 malfunction detected during packaging - report? Other US Medical Device Regulations 1
J 21 CFR 821 Medical Device Tracking Requirement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
E 21 CFR 211.103 Calculation of Yield Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
Q 21 CFR 821 Medical Device Tracking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Mislabeling - Consider this an FDA notified recall? CFR 806.10 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
P 21 CFR 807.81 When a premarket notification submission is required Other US Medical Device Regulations 0
F 21 CFR Part 11 - Implicit requirements - Validation plan for a Software as a Service Other US Medical Device Regulations 1
C 21 CFR Part 11- What about handwritten signatures? Other US Medical Device Regulations 1
Z 21 CFR and Annex 11 mapping document Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ed Panek Do Cloud services require 21 CFR Part 11 compliance? Qualification and Validation (including 21 CFR Part 11) 7
QIE FDA 21 CFR Part 11 "Meaning of Signature" Other US Medical Device Regulations 6
J Business Intelligence and 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 1
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S 21 CFR 810 - Medical Device Recall Authority - Contract Manufacturing Other US Medical Device Regulations 1
S Is Adobe Sign - E-signature for QMS documents - 21 cfr part 11 compliant? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Design developer - 21 CFR 807 - do we need to register? Other US Medical Device Regulations 0
C Signature manifestations - 21 CFR Part 11 Qualification and Validation (including 21 CFR Part 11) 4
C Informational CFR 21 Definition for Data or Raw Data Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
D Use of password managers on validated computer systems (21 CFR Part 11) Medical Information Technology, Medical Software and Health Informatics 2
Q 21 CFR Part 111 - Requirements for Dietary Supplement Manufacturing Water Quality Document Control Systems, Procedures, Forms and Templates 1
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K 510K statement Questions 21 CFR 807.93 - Discontinued or never released for sale US Food and Drug Administration (FDA) 0
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
R RUO audits - CFR 820.22 and ISO 13485 8.2.4 Internal Auditing 3
B 21 CFR 803 Definition for 'Substantial Harm" Other US Medical Device Regulations 1
A Training as well as certifications for ISO 13485:2016, 21 CFR 820... Training - Internal, External, Online and Distance Learning 5
K Production Unit Labeling - 21 CFR 820.184.e 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D 21 CFR Part 11 - Electronic Signature Management SOP Other US Medical Device Regulations 0
