Hello all,
In CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM, §120.105 Employees who must be tested it lists DOT FAA employees that must be tested for a 'Safety Sensitive Function'.
I work for a 145 Repair Station and just got a finding for hiring an individual without receiving negative test results that will not be performing any airframe maintenance. The way I read it, even though pre-hire tested and part of our drug pool, he is not subject to the below list. We received negative test results the very next day after hire and he was in orientation that first day and will be in an administrative assistant type function.
He worked previously for another 145 and I have 180 days once we get him a Repairman's Certificate to move him into an inspectors role without additional UA testing per the CFR.
What is everyone's consensus or take on the finding?
I think they are overreaching myself.
Comments please and thank you in advance.
re.
"Each employee, including any assistant, helper, or individual in a training status, who performs a safety-sensitive function listed in this section directly or by contract (including by subcontract at any tier) for an employer as defined in this subpart must be subject to drug testing under a drug testing program implemented in accordance with this subpart. This includes full-time, part-time, temporary, and intermittent employees regardless of the degree of supervision. The safety-sensitive functions are:
(a) Flight crewmember duties.
(b) Flight attendant duties.
(c) Flight instruction duties.
(d) Aircraft dispatcher duties.
(e) Aircraft maintenance and preventive maintenance duties.
(f) Ground security coordinator duties.
(g) Aviation screening duties.
(h) Air traffic control duties.
(i) Operations control specialist duties."
re.
