Cg/Cgk - Special equipment that I'm not sure what to do
soulmas
Dear all,
I need your help. I know how to calculate Cg/Cgk's however, I have a special equipment that I'm not sure what to do. After using the same reference part several times, the part gets damaged so, I cannot complete all the measurements required. What could you suggest?
My first guess is to have several reference parts (not just one...) and measure each part only for certain number (let's say 5 times each part) to avoid damage. Is this a good approach to this study? any idea?
thank you,
Wes Bucey
Prophet of Profit
Dear all,
thank you,
Clarify, please. Damaged by your measuring instruments?
soulmas
Clarifying, the reference part is made by plastic. The equipment is a dynamometer, so the equipment apply effort on the part and the part gets bended. (20-40 N). After several times, the reference part is bended, and does not get back to the original form. or is torn or with scratches.
You are correct, the part gets damaged by the equipment. This is not a destructive test, but Customer is requesting Cgk for 50 measurements. I can probably consider this study as being "destructive" and this could be a special case where I cannot calculate Cg/Cgk. What do you think?
Wes Bucey
Prophet of Profit
I think a frank conversation with the customer (the guy at the customer who has the final say) on a workable solution at a negotiated price is required. This is, indeed, a special case and requires special consideration AND PAYMENT for the time, effort, and materials involved.
Without seeing print and specs for both part and instrument, it's pretty difficult to suggest a quick and easy workaround.
Remember - modern quality practice suggests supplier and customer work as partners, not adversaries, for optimum results.
soulmas
Thank you!! We...just like you say..we will work with the customer to find a solution on this particular case.. it will be handled as a special case.. first, we will run the study with 25 measurements only, to see when the part gets damaged. if we cannot complete 25 measurements, we will not conduct a Cgk study, but we will do a GR&R that will be our MSA study. Thank you for your comments.
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
R Question: Cg/Cgk formula Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M How to calculate Cg and Cgk for a 2-Dimensional Area Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K R&R, Cpk, Cgk - What is the difference between methods and what method is used? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M MSA question on Cg and Cgk Calculation Method and Type of Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Capability of Gage (Cg & Cgk) for New and Repaired Gages Capability, Accuracy and Stability - Processes, Machines, etc. 10
L Validation through Cgk Excel .xls file needed Excel .xls Spreadsheet Templates and Tools 4
P Cgk - The Kolmogoroff (Kolmogorov-Smirnov) Method Statistical Analysis Tools, Techniques and SPC 9
A What is Cgk? (Index of Testing Means Capability) Statistical Analysis Tools, Techniques and SPC 18
L CQI-9 Special Process: Heat Treat System for Sinter parts IATF 16949 - Automotive Quality Systems Standard 0
J Special Characteristic Symbols On FCA Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L CQI-30 Special Process: Rubber Processing System Assessment - Mixing & Molding IATF 16949 - Automotive Quality Systems Standard 4
V Sample Size rationale to reduce size and use special levels EU Medical Device Regulations 6
Z 10993-7 Special Populations and Area Other Medical Device Related Standards 1
S Defining special characteristics beyond customer drawing FMEA and Control Plans 11
N 8.3.3.3 Special characteristics - Auditor said we are required to create our own, if no customer char. exist. IATF 16949 - Automotive Quality Systems Standard 10
G Special needs operators : how to treat trainings and etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Traditional or Special 510(k) US Food and Drug Administration (FDA) 7
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Casana Mentioning Special Characteristics in SOP FMEA and Control Plans 4
M Contact with special interest groups IEC 27001 - Information Security Management Systems (ISMS) 1
B SPECIAL PROCESS VALIDATION & REVALIDATION Qualification and Validation (including 21 CFR Part 11) 5
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Special Controls and Standards Other US Medical Device Regulations 0
A Special Characteristic question from Automotive CSR Customer and Company Specific Requirements 9
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
John C. Abnet Special Status Notification IATF 16949 - Automotive Quality Systems Standard 1
D Special IATF audit of sub-supplier IATF 16949 - Automotive Quality Systems Standard 18
A IRIS audit - Discussion about Special Processes General Auditing Discussions 11
S SOP Identification of Special Characteristics IATF 16949 - Automotive Quality Systems Standard 9
B AS9102 - 3D printing a special tool required for assembly (counterfeit risk?) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
P Letter to file or special 510k or traditional 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
S Special 510(k) for orthopedic implant 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Riveting - special process Manufacturing and Related Processes 12
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
L Special Processes for SERVICES AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
