I uploaded an example. I posed this question to our design engineers. However they have not provided the standard that references how the chamfer should be measures
I can see why you're perplexed. I've never seen a chamfer dimensioned that way, and there's not much tolerance. For what it's worth, ANSI/ASME Y14.5M 1994 (an obsolete version but it's all I have at hand at the moment) says:
1.8.15 Chamfers. Chamfers are dimensioned by a linear dimension and an angle, or by two linear dimensions...
Where an angle and a linear dimension are specified the linear dimension is the distance from the indicated surface
of the part to the start of the chamfer.
Like I said earlier, the standard doesn't mean much if it's not referenced on the drawing, and even if it were, the means of callout the chamfer don't follow the requirement. Best to check with the customer, designer, or whomever might be able to make a definitive call.
