Change Control Decision Tree - When medical devices that are approved with a PMA
totally
When medical devices that are approved with a PMA are affected by changes in an organization it would be nice to have a decision tree to help determine who needs to review the change. Can anyone point me to change control decision tree examples for PMA products?
Thanks!
Stijloor
Thanks!
Any medical device expert who can help here?
Thank you.
Stijloor.
I’m looking for a template that provides thought provoking questions in a decision tree for yes/no to lead to whether a change order is required or a change order is not required.
This would be for change control to help guide employees on proper decision making where a change order may not be needed and only document change request is all what’s required.
indubioush
Since you have a process for changing documents and another process for "change orders," then the easiest way is to have a set list of document types that need a change order prior to going through the document change process. For example, if you are changing a history record, even if the change is minor, you will still have to document decisions regarding the effect on verification/validation, risk management, and regulatory filings. You will also have to document the disposition of your current inventory, which will be "use current stock" or something like that if the change doesn't actually affect the product. Much better to have a clear line like this versus leaving this decision to a change originator who may or may not have a proper understanding change control. In my opinion, every change to a document referenced on the DMR would require a change order.
We actually have 1 process and everything goes through change orders. My boss was asking if document changes have to go through the change order process every time to LEAN out the process and I’m not sure if it’s possible since we are a regulated company.
My boss is Interested in putting together a decision tree with a yes or no so somebody can figure out what direction they need to go in. Implementation plans seem to fail because something gets overlooked which is the biggest problem. So I’m being asked to make a decision tree with a yes/no format based on facts to guide an employee down the right path without them trying to guess. If there is a good decision tree out there on change control it would be much appreciated!! Thanks
indubioush
I am a little confused because you mentioned change orders and document change requests, but then you said you only have one process. Do you mean that every document change goes through the change order process and also the document change request process?
I urge you to not have a decision tree. What will happen is that people will not look at it, and your document control person will become the bad guy telling people they are doing things wrong. It is better to build the decisions into the form. Here is my suggestion, which worked well at a previous company:
There was a change request form and a document change order. Not every change required a change request. On the document change form, this question was listed: "Is this a change to design, equipment, labeling, manufacturing process, material, software, specification, supplier? __ No __Yes, CR#__________.
If the answer was yes, the originator of the document change needed to list the change request number. The change request form had questions like, what is the verification/validation plan?, what is the affected product?, what is the proposed disposition?, which risk management documents were reviewed?, what is the proposed change to severity rating and occurrence rating?, etc. It also had an indication of whether all required actions had been completed.
If the answer on the document change order was no, the originator just continued working on the document change order.
Hope that helps.
It helps but my boss wants a decision tree with yes/no. I had a decision tree more in a flow chart and it drilled down into the details a bit to much apparently. I need to make it very high level so a second grade student can follow it.
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
U Change Management vs Change Control? Design and Development of Products and Processes 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
S DHF File Change Control Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Medical Device Website Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Change Control - General Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M Document Change Control for a Very Small Business Document Control Systems, Procedures, Forms and Templates 12
S How to connect NCMR, Deviations and Change Control ? Nonconformance and Corrective Action 2
V Can Regulatory Head Initiate/Trigger the Change Control for Quality Procedures US Food and Drug Administration (FDA) 9
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
L Use of checksum(s) to control product change(s) Misc. Quality Assurance and Business Systems Related Topics 1
C Change Control Forms Post Software Validation Medical Information Technology, Medical Software and Health Informatics 2
T Searching for books which have content of 7.1.4. Change Control topics Book, Video, Blog and Web Site Reviews and Recommendations 2
C Change Control in a SCRUM World Misc. Quality Assurance and Business Systems Related Topics 3
J Change in our SharePoint Document Control Process - Is this ok? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
H Blood Banking (CFR 21 PART 606) Change Control Requirements US Food and Drug Administration (FDA) 8
K Change Control for Software System that Controls Aspects of GMP Quality Assurance and Compliance Software Tools and Solutions 5
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
L Engineering Change Control Software Systems - Recommendations? Document Control Systems, Procedures, Forms and Templates 2
T TS 16949 compliant Change Control Management Process IATF 16949 - Automotive Quality Systems Standard 3
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Internal Auditing of Area with Active Change Control Internal Auditing 14
M Change Control Process - Deviation from Standard for Parts Document Control Systems, Procedures, Forms and Templates 1
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Change Control Review Management Success or Effectiveness Metric Quality Manager and Management Related Issues 3
C Change Control Plan/Procedure for Slickline/Wireline Services (Oil Field) Quality Manager and Management Related Issues 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
A Implementing a change for a particular Process - Document & Change Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
