Change Control for processes & products
I have just joined a new company and they have a very complex change control process. The process is so complex that we have multiple internal audit and third party finding for not following our own procedures. The team and I have decided to simplify the process and basically start over.
My question to this group is can someone send me a basic work instruction or procedure, with applicable forms for a process and product change to help me get started?
Thanks!
Go Irish!
Maaran
Thanks!
Go Irish!
What kind of company industry you are works ?
If metal manufacturing i can provide to you for your improvement.
John Predmore
My suggestion is to put aside the multi-page documents of detailed procedural paragraphs. Make a list of inputs and outputs which you absolutely must have. Outline what you want to accomplish using a flow-chart. Start at a high level, with fewer than 10 boxes. Then add detail as necessary, showing where decision points and contingent branches are in the process. It may be quicker to sketch on a white-board, or write steps on post-it notes which can be easily moved and rearranged. Where you feel the need to annotate the flow-chart with details of roles or criteria, these details can be added on the side as text-notes. As soon as your flowchart looks like a tangle of spaghetti loops, ask yourself what is the most logical progression and are all the many steps equally crucial to successful completion of the task?
All of my company's procedures are depicted as flow-charts, and every one of these fit on a single page. Try to avoid writing a procedure to fill out a form -- the form should be self-documenting to explain what information goes on which line, with a page 2 of detailed instructions if absolutely necessary. Once a flow-chart expands and becomes too broad or complex to fit on a single page, break up into sub-procedures. There are software programs to facilitate flowcharts, so all the boxes are uniform size and spacing.
An extension on the simple idea of a flowchart is to use swim-lanes which shows the sequence moving between columns depicting who (which department) does which steps in the sequence.
Primarily for commercial products, mostly home use, with a very small amount of food grade and cosmetic applications which we run primarily on a controlled prototype area of the operation. I realize our industries are radically different but I think we can learn from best practices within an outside our industry. I would be interested to see your approach.
Thanks!
ND Fan
Tagin
Thanks!
ND Fan
You still haven't mentioned the standards and/or regulatory bodies which are auditing you and giving you these findings.
Maaran
Thanks!
ND Fan
@ND fan During an audit conducted by an internal auditor, what are the findings in your department?
Few steps that make an effective change control process as below:
1. Change request initiation - In the initiation phase of the change control process, a change is requested. For example, a creative deliverable is taking longer than anticipated. A request would then be made to adjust the deliverable due date. Various fields you might include in a change request form such as Project Name, Date, Request description, Requested by, Change owner, Priority, Impact of change, Deadlines. comments, etc. The fields you include will depend on how thorough you want your change log to be and the type of changes you come across.
2. Change request assessment - Once the request has been filled out and the initial form has been submitted and approved, the request will then be assessed. This is different from the initial form submission since the assessment is when the actual change will be evaluated. The information will likely be assessed by a project or department lead, who will review details such as the resources needed, the impact of the request, and who the request should be passed on to. If the change request passes the initial assessment, it will then be passed on to the analysis phase where an actual decision will be made.
3. Change request analysis - The change impact analysis phase is where there will be a final decision on whether the request is approved or denied by the appropriate project lead. An approved change request will require sign off, and from there, be communicated to the team and continue through the rest of the five-phase process. If the change request is denied, it should also be documented on the change log. While communicating a denied request to the team isn’t necessary, it could be helpful in order to prevent confusion.
4. Change request implementation - If the change request is approved, the process will move on to the implementation phase.
5. Change request closure - Once the request has been documented, disseminated, and implemented, the request is ready to be closed. In the closing phase, any documentation, change logs, and communication should be stored in a shared space that can be accessed later on.
Y Change Control - General Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Crimpshrine13 Bulk Process (Electroplating), Control Plan, and Process Change IATF 16949 - Automotive Quality Systems Standard 0
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
Quality Specialist Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 7
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
D Engineering Change order vs. Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
D GAMP CAT 5 Change Control Qualification and Validation (including 21 CFR Part 11) 9
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
U Change Management vs Change Control? Design and Development of Products and Processes 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 13
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
S DHF File Change Control Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Medical Device Website Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 25
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M Document Change Control for a Very Small Business Document Control Systems, Procedures, Forms and Templates 12
S How to connect NCMR, Deviations and Change Control ? Nonconformance and Corrective Action 2
V Can Regulatory Head Initiate/Trigger the Change Control for Quality Procedures US Food and Drug Administration (FDA) 9
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
L Use of checksum(s) to control product change(s) Misc. Quality Assurance and Business Systems Related Topics 1
C Change Control Forms Post Software Validation Medical Information Technology, Medical Software and Health Informatics 2
T Searching for books which have content of 7.1.4. Change Control topics Book, Video, Blog and Web Site Reviews and Recommendations 2
C Change Control in a SCRUM World Misc. Quality Assurance and Business Systems Related Topics 3
J Change in our SharePoint Document Control Process - Is this ok? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
H Blood Banking (CFR 21 PART 606) Change Control Requirements US Food and Drug Administration (FDA) 8
K Change Control for Software System that Controls Aspects of GMP Quality Assurance and Compliance Software Tools and Solutions 5
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
L Engineering Change Control Software Systems - Recommendations? Document Control Systems, Procedures, Forms and Templates 2
T TS 16949 compliant Change Control Management Process IATF 16949 - Automotive Quality Systems Standard 3
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
