Change Control for Test Samples
ga2qa23
Howdy :bigwave: We're a medical device company that will soon transition from R&D to testing of our medical device components/assemblies. The FDA requires that our test samples are "representative of the final product". But we have a very expensive circuit board, sealed inside of our medical device, and it's not actually relevant to most of our testing (biocompatibility, cleaning, sterilization).
So we will make a separate "non-functional" model that is the same shell, but no guts inside (no expensive circuit board) to use for these kinds of testing. Our real/functional medical device goes through our change control process and is assigned an document ID number and a version number. So should this fake "non-functional" model also go through our change control process to get a separate document ID number and version number?
In my mind, we could either A) put the "nonfunctional" model through our change control too, or B) don't do that but instead write any explanation of differences in the separate test protocol documents for biocompatibility testing, cleaning testing, sterilization testing, etc.
Any input would be appreciated. Thank you!
Either way is fine, but here are some "shoulds" for you:
You should have an approved test protocol that justifies the use of these shell-only assemblies and describes how they are different from the clinical device. The protocol should be approved prior to building these units.
The build plan for these units should be approved to ensure the build will be in line with the protocol requirements.
You should have a complete device history record for these units that meets the applicable DHR requirements in 21CFR820.
An additional consideration: Prior to performing design verification testing, develop a test plan and try to use devices for more than one test where possible. This little bit of planning can save a lot of money.
ga2qa23
I understand what you mean. You're basically saying that I have two options:
  • Either approve the "shell-only assembly" as its own print with a document ID number and version number. Then save a DHF folder for it. Then reference it in the test protocol;
  • Or instead I save the "shell-only assembly" print in the Appendix of the test protocol. Then in the resulting test report, I'd save the DHR documents as an Appendix in the test report.
Actually no, that is not what I am saying. You can go about documenting the modified assembly in many different ways. I am just saying that you need to document it and justify its use. The modified assembly does not need a design history file. It is not a device. It represents a device. You need to be very clear on how it represents the device in the correct way in order to show that the results of your design verification test are applicable to the actual device.
Crimpshrine13 Bulk Process (Electroplating), Control Plan, and Process Change IATF 16949 - Automotive Quality Systems Standard 1
Z Change color or shape of individual data point in control chart Using Minitab Software 6
N Change Control for processes & products Manufacturing and Related Processes 7
Quality Specialist Change Control Numbering system Document Control Systems, Procedures, Forms and Templates 7
M Change control on Tracking Sheet ISO 13485:2016 - Medical Device Quality Management Systems 11
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
D Engineering Change order vs. Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
D GAMP CAT 5 Change Control Qualification and Validation (including 21 CFR Part 11) 9
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
U Change Management vs Change Control? Design and Development of Products and Processes 4
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 13
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A Can change control can be closed if the CAPA is still open? Nonconformance and Corrective Action 3
S DHF File Change Control Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Medical Device Website Change Control ISO 13485:2016 - Medical Device Quality Management Systems 3
Y Change Control - General Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 25
R Does anyone have any experience on change control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M Document Change Control for a Very Small Business Document Control Systems, Procedures, Forms and Templates 12
S How to connect NCMR, Deviations and Change Control ? Nonconformance and Corrective Action 2
V Can Regulatory Head Initiate/Trigger the Change Control for Quality Procedures US Food and Drug Administration (FDA) 9
T Change Control Requirements when changing Suppliers IATF 16949 - Automotive Quality Systems Standard 4
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
L Use of checksum(s) to control product change(s) Misc. Quality Assurance and Business Systems Related Topics 1
C Change Control Forms Post Software Validation Medical Information Technology, Medical Software and Health Informatics 2
T Searching for books which have content of 7.1.4. Change Control topics Book, Video, Blog and Web Site Reviews and Recommendations 2
C Change Control in a SCRUM World Misc. Quality Assurance and Business Systems Related Topics 3
J Change in our SharePoint Document Control Process - Is this ok? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Is it possible to have a General Change Control SOP and Form? Document Control Systems, Procedures, Forms and Templates 6
H Blood Banking (CFR 21 PART 606) Change Control Requirements US Food and Drug Administration (FDA) 8
K Change Control for Software System that Controls Aspects of GMP Quality Assurance and Compliance Software Tools and Solutions 5
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
A Change Ratio [Guideline in Control Limit Update] Statistical Analysis Tools, Techniques and SPC 3
L Engineering Change Control Software Systems - Recommendations? Document Control Systems, Procedures, Forms and Templates 2
T TS 16949 compliant Change Control Management Process IATF 16949 - Automotive Quality Systems Standard 3
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
